Question about Spark Plugs BR4HS Plug 10/BX #3322
How do I change spark plugs in my 07 dodge 4.0 nitro
Driver side plugs is covered by intake
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 189 Answers
Take the intake off some times you have to strip the motor of breathers and other components just to do this
Posted on Sep 09, 2014
Firing order & Wire Routing for 2009 Dodge Nitro 3.7 w/ three coil setup
The firing order for v6 is 165432
The driver side cylinder bank is numbered from front to rear-- 2-4-6
The passenger side cylinder bank is numbered from front to rear 1-3-5
The picture is for your coil pack, hopefully. So you can see how the coil towers are numbered.
My database for 09 showed coil on plug ignition. Is this the original engine?
I did see info for 07--3.7L that did appear to show a coil pack in tune-up manual.
Apr 20, 2017 | Dodge Cars & Trucks
On my 07 doge nitro do you replace coil along when replacing plugs
Nacho, Coils are not normally replaced when changing spark plugs. Use the factory recommended plugs(OEM) . Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.nitroforumz.com/threads/changing-spark-plugs.30635
Changing Nitro Plugs 3 7 4 0L
how to change spark plugs in dodge nitro
More Information for NGK 6987
Aug 23, 2016 | 2007 Dodge Nitro
How do I take the drivers side spark plugs out on a 2010 dodge nitro 3.7 engine?
Driver side and passenger side spark plugs come out the same way. Remove the coil pack (individual coil for each plug) using a 10mm socket, then use the spark plug socket with an extension to remove the plugs from down in the tube that the coil pack was removed from.
Jan 20, 2016 | Dodge Cars & Trucks
How can I locate my spark plugs on my 2008 dodge nitro?
The spark plugs are under the coil packs. Remove the screw and pull up on the coil pack you will find the spark plugs there. On a v-6 engine there will be six coil packs three to a side. Just be careful removing the coil pack pull straight up as there is a long plastic plug under it that is the coil wire. Its is better to be safe then sorry just take your time you will be fine.
Oct 20, 2014 | 2008 Dodge Nitro
How to get to spark plugs on my 2008 dodge nitro?
Take A Of The Top Off,Is It Plastic?
I keep asking the same question for a 1971 dodge 318-1 v8 engine and get every year but what im asking
The firing order for a Dodge 318cid/5.2L is 1-8-4-3-6-5-7-2 clockwise rotation.
Cylinders are numbered like this.
Pass side 2-4-6-8 front to rear.
Driver side 1-3-5-7 front to rear.
The firing order is probably forged into the intake manifold. Number one tower on the distributor cap is the one facing the number one plug or the driver-side headlight.
Distributor rotor at Number 1 plug terminal points to front intake bolt on left side of engine.
Jul 13, 2014 | 2000 Dodge Dakota Quad Cab
How to tune it up
it's pretty easy under the hoop driver's side you have 3 black things with spark plug wire and some wire connected to it you will need a 10mm socket to remove the bolt pull up an remove the spark plug repeat for the other 5
Sep 23, 2012 | 2008 Dodge Nitro
Where is the oil filter on a 2007 dodge nitro v6
You can access the oil filter easily from underneath next to the front, driver-side wheel at the front of the engine. There is clear access to the filter there.
For more info on Dodge Nitro, visit the forum at
http://www.dodge-nitro.com/dodge-nitro/
Aug 08, 2009 | 2008 Dodge Nitro
Change sparks plugs on 06 hyundai sonata v6
You didn't specify whether you have the (4) cylinder or the (6) cylinder engine..... I have a 2004 Hyundai Sonata 2.4L 4 cylinder and I just changed the spark plugs in it. I believe that the 2005 2.4L engine is the same. To locate and change the (4) spark plugs on a 2004 Hyundai 2.4L 4 cylinder engine: Remove the (4) 12mm bolts from the decorative plastic engine cover. Remove plastic cover from engine and place it off to the side out of your way. Standing in front of the car, the (4) spark plugs are located laterally (left to right) in the recessed area underneath where the plastic engine cover was removed. Note: This engine has (2) coils....They are located above spark plugs number (2) and (3) from left to right. Starting with the fist spark plug on the left: Remove the spark plug cable by pulling straight up on the insulated connector. Using a spark plug socket, remove the old spark plug and install a new one in it's place. To access the second spark plug from the left, remove the electrical connector and the spark plug cable wire from coil number (1) and then remove the (2) 12mm bolts that secure the coil to the engine. Spark plug number (2) is located directly under the coil. Lift the coil straight up removing the insulated connector from spark plug number (2). Using a spark plug socket, remove old spark and install a new one in it's place. Repeat same procedures for spark plugs number (3) and (4). Note: If you have the (6) cylinder engine, the front (3) sparks pluge are readilly accessible but in order to access the (3) rear spark plugs, you will have to remove the intake manifold
Jul 08, 2009 | 2006 Hyundai Sonata
Trying to replace driver side parking light on dodge nitro
You will need a flat blade screwdriver and a T20  torx Open the tailgate, on the inside of the lamp cluster there are 2 plastic domed heads that look like blanking plugs, with a flat bladed screwdriver pry them out, then grasp the lamp unit and pull it backwards, the 2 balls need to pop out of the plastic sockets and you will have the unit in your hand, on the back of the lamp the bulbholder is held in with 2 T20 torx screws, undo these and pry the holder out of the lamp, get someone to operate the lights and indicators to work out the faulty bulb, re-assemble in reverse order, pat the lamp into the panel with your hand.
Apr 05, 2009 | 2008 Dodge Nitro
Spark Plugs BR4HS  Plug 10/BX #3322 Logo
69 people viewed this question
Top Ngk Vehicle Parts & Accessories Experts
Ian Kime
Ian Kime
steve morris
steve morris
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
