Question about Binatone Icarus 2020 Twin
No ringing from handset - Binatone Icarus 2020 Twin
Handset is not ringing. Checked to make sure ringer and volume is on. What else could be the problem.
I assumed you are talking about your wireless phone.
Are you worried about handset ringing or the incoming call ring?
1. If you want to check your handset ringing, you check it by calling from your base to your handset via INTERCOM. If it rings, then your hanset ringing is working. The trunk or the Tel Company dial tone is the one not going in to your phone.
Hope this helps. Best regards.
Sep 01, 2015 | Lands Phones
Handsets don't ring?
I assumed you are talking about your wireless phone. Are you worried about handset ringing or the incoming call ring? 1. If you want to check your handset ringing, you check it by calling from your base to your handset via INTERCOM. If it rings, then your hanset ringing is working. The trunk or the Tel Company dial tone is the one not going in to your phone. Hope this helps. Best regards.
When answering mode is on I do not want to hear the ringing(4x) tones before going to answering.I've switched off the 'call screen' option. still I hear the ringing although not recording at least.
Just set the ringing volume to off.
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level. Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according to their individual settings
May 29, 2015 | Uniden DECT 6.0 Cordless Phone ID
Hanged batteries in handset but phone will not ring
Check to see if ringer is set to hi. make sure ringer is turned on. Check to see if the base and the phone are syncronized.
Jan 03, 2015 | BT FREESTYLE 750 TWIN DIG CORDLESS PHONE
One of my hand sets for my philips CD235 phone wont ring
The handsets have a set-up menu which allows you to determine the
loudness of the ring. find it and adjust the ring loudness to suit you.
If the handset still does not respond to incoming calls, you have a
problem with the handset. If so, follow the instructions on the
guaranty for a repair or replacement of the handset.
Aug 29, 2011 | Philips CD235 Twin Cordless Phone
My 2nd phone will ring bt the main one I can't seem to turn ringer on..Help Please
If this is the model I think it is, your phone line cord is pluged into the base of the main handset. So let me see if I'm understanding your problem...You have a single line phone with two handsets, and your remote handset rings, but the main handset at the base unit does not. Since your second handset rings when called,your line is working, and your unit's base is working, as well, or the other handset would not ring. Therefore your problem is within the handset itself. I will assume you've made sure the ringer is turned ON and the volume turned UP. Use the Menu button on the handset to find these variables and make sure the ringer is ON and turned UP. Place the handset on the charging cradle. Press the ON button WHILE the phone is on the cradle. You might have to use the speakerphone button to do this. This will resync your handet with its base.
Feb 01, 2011 | Panasonic KX-TG2631 Cordless Phone
Can't hear phone ringing
Adjusting the Ringer Volume (From the Uniden manual)
  1. With the phone in standby, press ArrowUp or Arrow Down on the handset or VOLUME + or VOLUME - on the base. The handset or base sounds the ringer at that level.
  2. Use Arrow Up on the handset or VOLUME + on the base to make the ringer volume louder.
  3. Use Arrow Down on the handset or VOLUME - on the base to make it softer or turn it completely off.
  4. When you hear the ringer volume level you want to use, stop pressing keys.
  5. The handset or base will use the new ringer volume starting with the next incoming call.
  6. If you set the ringer volume to Off, the handset or base won’t ring.
  7. Other handsets or base will ring according to their individual settings.
Jan 03, 2010 | Uniden DECT 6.0 Cordless Telephone...
No ringing tone on handset
Need a manual for Williams sonoma bread machine
Model # 2094
Ray
Sep 15, 2009 | Panasonic Cell Phones
Ringing problem
I assume it does not ring but just beeps to let you know another line is ringing in case you want to put the current call on hold and answer it. It's called Off-Hook Call Announce, you want to have that option turned off on your extension or possibly the entire system. Do you have someone at your location that makes programming changes to the system or do you pay a company for that?
Aug 22, 2007 | Toshiba DKT-2020 Corded Phone
Binatone Icarus 2020 Twin Logo
22 people viewed this question
Top Binatone Lands Phones Experts
jhnolson
NOEL
NOEL
Are you a Binatone Lands Phone Expert? Answer questions, earn points and help others
