Question about Binatone Icarus 2020 Twin
No ringing from handset icon has music note with line through it on display
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
May 27, 2016 | Uniden Cordless Phone
Phone displaying 'Out of Range', no dialling tone
This could be due to the fact that one of your phones is off the hook or unplugged. Check and make sure that all devices are operational and charged.. Don't forget to check the phone line itseft.
Cheers
Jan 21, 2014 | Uniden 5.8GHz Expandable Cordless Phone...
Bt graphite instructions
This could be due to the fact that one of your phones is off the hook or unplugged. Check and make sure that all devices are operational and charged.. Try applying a warm damply wet cloth on the back when attempting to open the battery cover..Don't forget to check the phone line itseft.
Cheers
Jan 21, 2014 | Lands Phones
Please advise as to how to increase the VOLUME on my DECT 6.0 phone.
To adjust the ringer volume:
  1. With the phone in standby, press ^ or v. The display shows the current volume level and the handset sounds the ringer at that level.
  2. Use ^ to make the ringer volume louder or use v to make it softer or turn it off completely.
  3. When you hear the ringer volume level you want to use, stop pressing keys. The handset will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset won't ring. If you have any accessory handsets, other handsets will ring according to their individual settings.
To adjust the earpiece volume:
You can choose from six volume levels for the handset earpiece. To adjust the earpiece volume while on a call, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the earpiece.
To adjust the speaker volume:
You can choose from six volume levels for the handset speaker while on a speakerphone call. To adjust the handset speaker volume, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the handset speaker.
Note: The handset earpiece and the handset speaker have separate volume settings.
Apr 06, 2011 | Uniden DECT 6.0 Cordless Telephone...
Some 816 phones won't ring on incoming calls
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
enter in 1 2 3 4 1 # (that enables programming)
enter in #62 the screen should say day ring assn
press the line you wish to program
press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
press # when finished with the line
repeat steps 2 through 5 for the remainder of the lines you wish to change
press # when finished.
Jun 05, 2010 | Samsung Prostar 816 Phone
Our samsung system only rings on one telephone- how do I get it to ring on all phones and lines
with the handset down enter #20 the screen should say MMC DISABLED
Mar 16, 2010 | Samsung 816 Keyset Display Telephone
How do I make internal calls to another Panasonic KG-TGA711E handset in the house?
Making an intercom call
1 Press {INTERCOM}
2 Select the handset you want to page
by pressing the desired handset
number ({1} – {6}).
To stop paging, press {OFF}.
3 When you finish talking, press
{OFF}.
Answering an intercom call
1 Press {handset icon} or {speaker icon} to answer the
page.
2 When you finish talking, press
{OFF}.
Note:
When the ringer volume is set to off,
the handset rings at the low level for
the intercom calls.
Feb 20, 2010 | Panasonic (KX-TG1032S) Phone
Stations don't ring even though day ring and night ring enabled.
Sounds like the ring assignmet programming has defaulted.( all lines ring at station 4 only)
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
repeat for each line
Jul 20, 2009 | Samsung Prostar 816 Phone
Phone wont ring
Per the manual, If there is a musical note in the display with a slash thru it, you have turned off the ringer. You have done this by pressing and holding the # button.
If you have the manual it's on the bottom of page 20 and continues on 21.
If not follow these steps.
Press Menu
Press CID/PBK (Personal set)
Press Menu (Handset Tone)
Press Menu (Ring Tone)
Press Menu and then CID/PBK to select the volume you want
Press Menu (Save Setting)
click this link to get the manual
http://www.p4c.philips.com/files/c/cd4452b_37/cd4452b_37_dfu_aen.pdf
Dec 28, 2008 | Philips CD4452S/05 Digital Telephone and...
New ge dect 6.0 phone receives calls but won't ring out loud
I had the same problem and it persisted for a few days. Once i sat down and found the manual at ge's home electronics website, the problem was resolved. This is a little embarasing because it's quite an easy fix. my phone handset was displaying a musical note with a line through it. This is to show that the "Do Not Disturb" function is enabled. There is an illuminated button on the base that says do not disturbe.... i hit the button and the ringer works again. If you had the same problem, you are not alone my friend. Time to double our ginko intake for the day. *laugh*
Nov 18, 2008 | Lands Phones
Binatone Icarus 2020 Twin Logo
Top Binatone Lands Phones Experts
jhnolson
NOEL
NOEL
Are you a Binatone Lands Phone Expert? Answer questions, earn points and help others
