Question about HP Officejet 6310 All-In-One InkJet Printer
Fax services not available from Computer
The Officejet 6310 is running fine I can use it locally for copying and faxing. I can also scan and print from PC using HP Solution Center but I can not use the fax services from the PC. I tried to set it up using HP Solution Center but it failed. Can anyone help. Please note I am running Vista Home Premium and DEP is off
  • dbodansky Jun 21, 2009
    OK How do you fix it. Please note that t was working a while ago.
    PS That also goes for copyng on the PC using HP Solution Cener but that is not an important function
  • 73 Answers
Dbodansky 's fax worked up until a couple of months ago, with Window's Vista Home. He had his HP Updates set to "automatic". It is my suggestion that he do a complete reinstall of his software and then run the updates manually, testing the fax service after each update.
allbucdup999
says:
The "reliability update" seems to fall into that timeframe. I would suggest turning off Automatic updates, uninstalling the entire software package, and then reinstalling everything manually.
allbucdup999 says:
The updates should be installed one at a time to establish which one is the culprit.
I know that sounds like a big pain in the behind but it appears to be the soundest option at this point.
I'm sorry we got disconnected sir. Good luck.
Posted on Jul 05, 2009
    Guru:
  • 224 Answers
I work with Hp
It is not that you cant fax from the solution centre
but the fact that windows vista has an updated version of the registry which
will not allow faxing from the pc unless you have windows Vista ultimate.
Im not trying to blame Microsoft instead of Hp but I have taken calls where customers cannot fax using hp solution centre in vista and I started checking the registry and there is one component in Windows Vista Ultimate that is present which willl allow you to fax but This same registry entry is not there in other Windows Vista's.
That is why I prefer using windows Xp rather to Darn Vista
Posted on Jun 19, 2009
I have attached the HP 4255 officejet with my computer and want to send the file directly from my computer via fax. how i can send directly without geting print . mubashir@ellahifabrics.com
Well, you'll need a modem to send a fax. Either that, or an online faxing service. Your printer / scanner is only intended to either print files, or scan hard copies into files that can then be printed (or faxed). The printer itself does not fax.
Might I suggest the following online fax service, free of charge:
http://faxzero.com/
There are plenty of others.
-Jon
Oct 21, 2009 | HP OfficeJet 4255 All-In-One InkJet...
There is a line across the page when I fax, copy, or scan. How can I fix this?
If it's along the page of the print the printer path needs cleaning. If it's on the scan you need to clean the scanning window.
Aug 28, 2009 | HP Officejet 6310 All-In-One InkJet...
HP officejet 6310 All-in-One When I try to print a copy of an airline reservation, from the ticket, or selected "print" on computer, it doesn't run off the ticket. It prints Page 1 of 1 on top of the page...
Make sure you're using the website's printer-friendly option when printing the ticket. Look for an option on the webpage (not in the pull-down file menu) that will correctly format the information for printing.
Aug 10, 2009 | HP Office Equipment & Supplies
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
HP 6310 won't scan from my new Dell laptop
You have to manually add scan options via settings>scan options>scan to>
that's within the HP solution center btw.
Apr 09, 2009 | HP OfficeJet 6310 All-in-One Printer...
"NO SCAN OPTIONS" in HP Officejet 6310 all-in-one
You need to install the software and driver for the version of windows that is on the new computer.
Link to you model printer/scanner below:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1119598〈=en&
Mar 19, 2009 | HP OfficeJet 6310 All-in-One Printer...
When I copy, send a fax, or scan it turns out HP 6310 all in one
this is a hardware issue..connect the printer to the wall outlet..and then try to make a copy..if its still the same then machine should be replaced..reason is scanner blub is gone bad..
Mar 09, 2009 | HP Officejet 6310 All-In-One InkJet...
Faxing a word document
hi, i would like to know if you have an HP officejet 6300 fax icon???if you have try to print the document using the fax icon DO NOT used the normal HP officejet series icon.if you did used the fax icon it will display the FAX dialog box,input the necessary information needed.just follow the window..
i believe you can now send the fax..
send me feedback for further troubleshooting....
Aug 04, 2008 | HP Officejet 6310 All-In-One InkJet...
HP 4300 officejet fax mode to print mode
Hello etilton
Are you trying to print from a pc or do a copy?
Button 11 Fax: Places the HP All-in-One in fax mode and presents the Fax Menu. Press Fax
repeatedly to scroll through the options in the Fax Menu.
Button 12 Scan: Places the HP All-in-One in scan mode and presents the Scan To menu for
selecting a scan destination.
Button 13 Copy: Places the HP All-in-One in copy mode and presents the Copy Menu.
Press Copy repeatedly to scroll through the options in the Copy Menu.
heres the rest of the manual pdf reader required
http://h10032.www1.hp.com/ctg/Manual/c00644922.pdf
If this solution was any help at all please press accept or ask more questions with the other button.
And if you need anything else let me know, you can ask me 24/7 by clicking
on the ask me button, I will ansver in most cases within 24hours.
Thanks and good luck!
May 04, 2008 | Office Equipment & Supplies
HP Officejet 6310 All-In-One InkJet Printer Logo
129 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
