Question about Eden Bridal Eden WT550 Traveler Bass Head
Wt550 crackling and pop sounds then turns off
Noise from a Yamaha EMX 2000 Powered mixer
Sounds like it might not be cleaned enough. They may have done the pots but the internal circuit boards may not have been done enough.
May 11, 2016 | Yamaha Music
After hooking up the PA for practice, I heard a loud "pop," then followed by a burn smell, from my Mackie SRM 450 speaker, which I use as a monitor. No sound comes through but static and crackling. Is the...
The pop itself isn't necessarily a bad thing, but a burn smell and the fact that it's only outputting a crackle likely means that the built-in amplifier circuitry has been overloaded. This can happen a few ways:
1) Faulty power, either a bad cord or a bad outlet
2) Plugging the output of a power amplifier into this speaker - because it has a built in amplifier, this speaker only wants a non-powered line input
3) If the Thru output is (accidentally) plugged into anything that provides phantom power, that could overload the circuitry.
4) A short due to liquid or moisture contact - these cabinets are most certainly not waterproof
In any case, the amplifier part of the circuitry IS replaceable. If you're not comfortable buying one and replacing it yourself (I'd recommend eBay), take it to any shop that sells similar items. If you're extremely lucky, it was just a fuse that needs to be replaced, but chances are you'll need to replace the whole amp.
Aug 19, 2013 | Music
My mackie thump amp will start to have a loud cracking sound. The cracking goes away if I have the input line unplugged from the speaker but with it plugged in it has the cracking sound and it does not...
Crackling is usally one or two things my guess would be bad grounding of the amp or bad connection with the jacks or plug it self try to make it crackle on purpose by jiggling the jacks see if it has any effect on the crackling try to narrow your possibilitys
May 04, 2011 | Mackie TH-15A Active DJ Powered THUMP...
Crackling and popping during playback/recording, latency issues. Using Firestudio Project, Windows 7 and Cubase 5.
Turn OFF all resource hogs such as Anti-virus, Anti-pop-up, and other background programs. Disconnect all internet access such as wireless and Ethernet service programs. All these resource hogs and programs for instance that keep track of when to run scans just cause interrupts of the servicing of the high speed audio grabbers. Your machine should be BARE of all these hogs.
Feb 23, 2011 | PreSonus Firestudio 2626 26x26 + Cubase...
Hi there, I just changed my tubes and re -biased. When I plugged my guitar in there was no sound from the amp until I git to about 6, and the sound was popping and crackling struggling to break through. I...
If it worked before you changed the tubes, it is possible one of the replacements (probably a small tube) was bad... it happens... Another possibility is that a socket pin has gone bad or a pin has broken or bent off... again probably one of the small ones... 12AX7/12AT7 or equivalent.
Swap old ones back in one at a time.
Jan 10, 2011 | Fender Hot Rod Deluxe Guitar Combo...
I hooked up my Mackie MR5 Monitors to my MacBook Pro through an audio interface, I use it to record my band in the studio I use out of my basement. Except everytime I try to use the monitors they give me...
try hooking headphones to the output and see if the crackling is still there.
then, try it with the speakers, at a lower computer voume level and higher speaker volume level. perhaps the headphone output is too loud and distorting in the speaker inputs.
Nov 28, 2010 | Mackie MR5 MR5 Reference Monitor
My Korg c15s has a lot of grating staticky noises when played ....I'm told it cannot be repaired as Korg no longer makes parts for this model?
I have a Korg C-15s and also experiencing loud crackling sounds when I turn it on. The problems seems to be either the sliding volume control or the amplifier itself. Honestly though, I believe the issue is the volume control. I opened my piano to get a closer look and attempted to clean the contacts on the volume. Unfortunately after cleaning the contacts, the crackling sounds became somewhat worse. After I turn the piano on, the volume control is generally rendered useless......volume set to low volume and the noise is quite loud and other times the volume control is set high and get very low volume crackling noise. No real consistency. The noise does diminish after a few minutes but so does the piano sounds to an inaudible level. There were a couple of instances where I turned it on and surprising enough, no no noise and perfect sound. For these reasons I believe the issue is within the volume control and not so much the amplifier. I have an electronics background and noticed that the volume control is very unique in design and is not something that can be substituted with another volume control from other sources.
My recommendation is to check the sound quality of the audio from the RCA L/R audio outs on rear of the piano by connecting to a stereo receiver. If it sounds fine you're in luck. If the crackling sound does not diminish after a few minutes like mine does, I would suggest disconnecting the internal speakers and using the audio out only. You can connect a pair of studio monitors or high quality computer speakers, preferably with a small subwoofer to deliver the full audio range and deeper tone of a real piano. I'm currently using a basic pair of Logitech computer speakers and is quite acceptable until I can afford a high quality set of monitors or relocate my piano closer to my high quality Yamaha receiver.
I hope this info helps a bit.
Aug 18, 2010 | Yamaha Full-Size Keyboard
Marshall MG50 DFX, the volume knob OD channel crackles
Either the control is damaged (happens if they get hit) or it is possible the circuit board it is mounted on has broken solder OR worse, a crack near the control. The unit will require servicing. Parts are readily available.
Jan 28, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
My spider line six 210 suddenly stopped working. When I turn it on, all the lights come on but no sound comes out except for an occasional crackle or pop. Please help. Thanks.
Could be a few things, is there a line out or preamp out on this thing? If there is run a patch cable into that and run that to another amp, power amp, guitar amp or if you don't have those wire up RCAs to one end of an instrument cable or get a 1/4 inch converter and run it to an aux on a home stereo. Just something to see if the preamp is working. If it is then your power section is dead, if you get no sound from the preamp then your preamp is dead. Let me know what you find. Also is there a warranty on it?
Dec 16, 2009 | Fender Music
Eden Bridal Eden WT550 Traveler Bass Head Logo
21 people viewed this question
Top Eden Bridal Music Experts
Vito Vacirca Jr.
Are you an Eden Bridal Music Expert? Answer questions, earn points and help others
