Question about Garden
Wiring diagram ride mower kohler command 16 resort 426cc
5 Suggested Answers
  • 376 Answers
SOURCE: Belt Diagram needed on Craftsman Kohler Command 20 Hp RidingMower
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter your model #, click enter, then scroll down to the sudcomponent list and click on 'Mower Deck' if it's your blade belt you need to see or 'Ground Drive' for your transmission belt. Hope that helps. Dwain
Posted on May 15, 2009
  • 78 Answers
SOURCE: I need a diagram for a Kohler carburetor on my
I dont see any Diaphram listed. I would go to your local Yard equipment Dealer that handles Kohler. but my reference books show no diaphram or even a model ca
Sorry
Posted on Oct 22, 2009
  • 40 Answers
SOURCE: My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Posted on Nov 05, 2009
tunde007
  • 2382 Answers
SOURCE: toro ride on mower 48"
Hi, sounds like you got a wire rubbed through or loose on the operator present circuit. Which is telling the ignition circuit to shut the engine off.
Best thing to do is to start at the units battery and follow all the wires to the switches/ plugs checking for loose plugs and worn through wiring that may be shorting out. Also check all the Wires going to and from the engine. You may have a few wires on the mowing deck, also check the switches to see if they are broken, etc.
Secondly, it's also Possible you have a bad switch under the seat. This is a safety feature that kills the motor if you overturn the mower. Unless the seat switch is made, the motor will not run with the blades engaged. There is also a switch on the blade engagement mechanism so the mower "knows" when they are engaged.
Posted on Nov 17, 2010
I got a 50in cub cadet ZT came with a Briggs on it . I'm putting a 22 hp Kohler command motor on it. I need the specs for all the wiring from the Kolher command motor to the Cub Cadet
Look at the wiring color codes and their purpose in the Briggs manual, Compare to the wiring color codes and purpose for the Kohler engine in manual, connect accordingly.
Jun 15, 2015 | Cub Cadet Garden
Show me a wiring diagram for a 13ac762f755,i put a 14hp command,kolher on it tring to wire it up.
Mower side connections At engine connector.
Yellow = Magneto
Red = Alternator DC
Blue = Alternator AC = Lights
Red/Black = Afterfire Solenoid
If the Kohler only has DC output jumper Red and Blue for lighting.
Apr 13, 2015 | Garden
Need to know how to wire koler command voltage regulator
We do not have this wiring diagram. Sorry.
May 14, 2013 | Cars & Trucks
I need a wiring diagram for a 15hp command engine
Here is a link to the Kohler site. not knowing you exact model I can't get the exact URL for you.
http://www.kohlerengines.com/manuals/landing.htm
Jun 19, 2009 | Garden
May 15, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Changing from kohler 12.5 to kohler 14hp
Go to http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10051 Type in your model no. and serial no on mower. Locate correct manual, you will then have to trace wires on both motors and make them correspond.
Mar 07, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Electrical wiring for kohler engine
Perhaps you would enjoy the entire service manual. Here it is: http://www.asberry.net/files/TP-2379.pdf
Feb 26, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
