Question about Pentax Optio E50 Digital Camera
PENTAX OPTIO 050 ERROR 02X0211
PENTAX OPTIO 050 camera will stay on, it displays error message: ERROR 02X0211 before it shuts off. Can't find any information regarding this problem.
leecom72
  • 4806 Answers
SOURCE: keep getting card locked on my display screen
Hi there.
Face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg .
Please post back if you need any additional advice.
Good luck and thanks for choosing FixYa!!
Posted on May 29, 2009
simplemitch
  • 752 Answers
SOURCE: Pentax Optio 50 Digital Camera Lens Error
Not really, it sounds like the lens has been bumped while it was extended. Unfortunately, the "buzz" you hear is the gears stripping one another. The only fix is to have the lens assembly replaced, which usually costs upwards of $200. I see this problem at least 3 times a week in my shop.
Posted on Oct 27, 2007
SOURCE: Pentax Optio 60 LENS
When I turn my camera on it says lens error and shuts off. no damage to camera and new batteries did not help.
Posted on Dec 28, 2007
  • 11967 Answers
SOURCE: Camera wont stay on.
Fixing a Lens Error on a Digital Camera This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 21, 2009
SOURCE: pentax optio e60 lens error 0x04110000
je viens de resoudre le probleme sur mon pentax E70L avec un simple aspirateur domestique,a l'aide du tuyau le plus fin, en realisant un nettoyage minutieux, tout autour de l'objectif, (sans rien demonter, evidemment!), ensuite le code lens error a changé, puis j'ai continuer a ouvrir et fermer l'appareil, a tenter de changer les options "scene", et l'appareil ne s'est pas refermer !...et j'ai pu refaire des photos!...soulagé!...l'appareil n'avait pas 2 mois!..mais rappelons nous qu'il n'aime pas le sable!
Posted on Apr 07, 2010
I get a memory card error message on my Pentax Optio S40. I bought two new memory cards. Sandisk 512 mb. I get the same message on them. I tried formating the card on my computer. When I pit it in my...
Camera cards are never to be formatted on the computer....only in the camera. "card error" usually always means you need to format the card in the camera. This will erase it so download any pics you want to save first.
Jun 02, 2011 | Pentax Optio S40 Digital Camera
Pentax optio E75 lense will not go in, camera says lense error
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101;'
Dec 12, 2010 | Pentax Optio 60 Digital Camera
Lens error
This is probably THE most common failure among digital cameras.
There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 20, 2010 | Pentax Optio 60 Digital Camera
Pentax e10 shuts off The pentax optio e10
You probably set the auto power-off for energy saving
Jul 12, 2009 | Pentax Optio E10 Digital Camera
Error message on pentax optio E60 lens error :0x1110000
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 14, 2009 | Pentax Optio E60 Digital Camera
Memory Card Error on 4 Gb CF cards (80x) for Pentax Optio 430
The maximum supported memory for Pentax Optio 430 is 256mb and for Pentax Optio 430 RS is 512mb.
Check this site for more information.
Optio 430
http://www.upgradecomputermemory.com/ram.cfm//memory/P/Pentax/Pentax-Optio-430/
Optio 430 RS
http://www.upgradecomputermemory.com/ram.cfm/memory/P/Pentax/Pentax-Optio-430RS/
Jun 10, 2009 | Pentax Optio 430RS Digital Camera
Oct 27, 2007 | Pentax Optio S50 Digital Camera
Error A90
The a90 error message, relates to an electronic fault on the main printed circuit board of the camera.
Jul 05, 2007 | Pentax Optio 430RS Digital Camera
Pentax Optio E50 Digital Camera Logo
51 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
