Question about Ovens
Atlas thermowave oven how to get oven door back on
Simpson Model la Stella Oven Thermowave not working Fan works and other settings OK
Burnt out element , thermostat or switch, test with meter.
Nov 10, 2016 | Ovens
Need manual to program oven
Here it is.
Atlas PDF.
Sep 07, 2016 | Ovens
Fan blowing constantly eve when oven not being used
There is a "Cavity" cooling fan on most modern ovens that cools the outside parts of the oven when it gets hot. (This is different to the one inside the oven for "Fanbake or Thermowave" cooking) This allows the fan to remain on after the oven gas been turned off and turn itdelf off when it has cooled down. The sensor may be faulty and need replacing. This usually requires a tradesman as you need to know where on the oven the sensor is. If you know how to locate it, try, but make sure the wall switch is off before proceeding.
Sep 11, 2011 | Ovens
How to remove the door on my simpson atlas oven.
Most oven doors are as follows: Open until first notch (or a little further if necessary). Grab both sides of door and pull straight up.
Jun 03, 2011 | Ovens
How do i turn on a white atlas ceramic electronic oven, the ceramic top is working,but the oven screen flashes from"0:00" to "auto" when i try and fiddle round with the oven...
Turn the oven control on. Now play with the buttons on the electronic timer/clock. Try all different combinations. Trying pressing them at the same time. This may take 5 minutes or more. If the timer is not faulty this will work, be patient. When the oven indicator light comes on the oven is on and the timer is now in manual mode.
Feb 25, 2011 | Ovens
Cant remove glass cover to replace bulb on Simpson La Stella Atlas series oven
I have a Simpson Atlas Mira. Was having a hard time getting the glass cover off too so looked on the net for a solution. Couldn't find one so I persevered and sorted it...
The glass cover has a screw-off thread (like a glass jar) which unscrews anti-clockwise (lefty loosey). I had to give it a good few wiggles and pulls before it would start unscrewing. I also had to use a damp towel to get a proper grip - it's a slippery little bugger - but I got it in the end!
Hope this helps someone - good luck!
JD Hamilton, NZ
Aug 23, 2010 | Ovens
Simpson Apollo can't set clock so oven won't work
I don't know if this will help. For the 720ef , this is what you need to do.
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remaining time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Apr 30, 2010 | Stoves 720EF Electric Double Oven
Ovens Logo
29 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
