Question about Cobra Radio Communications
4 ohms amplifier speaker - Cobra Radio Communications
    Genius:
  • Cobra Master
  • 1,795 Answers
Should be 8 ohms
Posted on Sep 01, 2014
I need 4 ohm speakers for my Warrior IS600 Amplifier
It is rated as a dual 300 watt amplifier, shich strongly suggests a Class D peak value for each amplifier.
In theory- 100 watt RMS 4 ohm speakers should be adequate.
Sep 20, 2012 | Audio Players & Recorders
Put new pa speakers in church 2 1000 watt tied 2gether and 2 300 watt. tied 2gether. the pa amp only has 250 watts with 6 mics connected and a cd player which plays fine. every time the mics are used if...
hi,
You have to check the ohms of the speakers all spekers should be 8 Ohms or above. if not it will overload the amplifier at high level. The minium ohms impedence of the amplifier is 4 ohms. If you connect two 8 ohms speakers together then the effective ohms will be 4 OHMS then the amp will handle the speakers. If you connect two 4 ohms spekers together then the effective ohms will be 2 Ohms, this will overload the amplifier. You will be able to connect two 8 ohms speaker to left channel or right channel of the amplifier. Check the speaker spesifiction to know its ohms. Make sure all the speakers have an impedence of 8 OHMS or above
OK
Aug 19, 2011 | Radio Shack 250 Watt PA Amplifier...
I have a plad213 what load impendance am i running it i hook up 2 4ohm speakers in series bridged on that amp and how many watts RMS am i getting per speaker
2 4 ohm speakers wired in series is 8 ohms and then is dropped back down to 4 ohms when you bridge it.
2 4 ohm speakers wired in parallel is 2 ohms then dropped down to 1 ohm when bridged
(most amplifiers will not handle loads below 2 ohms)
hope this info helps
May 20, 2011 | Pyle Dryver PLAD213 Car Audio Amplifier
Appropriate voltage for PS-57
Speakers don't use a voltage level to determine their usage- they use an "ohms" rating, like 4 ohms or 8 ohms. Ohms is written as an omega symbol. You have to match the ohms rated output of the computer to the speakers, or you can either blow the speakers up, or overload your amplifier and burn something up (usually a transistor). The power rating is also used to match components (expressed in watts, or the letter W). You can use a higher power rated speaker with a lower power rated amplifier, but you have to be careful of the opposite case. At some point at the upper end of the volume knob, you will draw too much current and blow the amplifier. Most people do this because it used to be that loud, etc., but in reality, you will never get the same volume with a lower power rated speaker system, and trying to will jepeordize your amplifier. I searched the net, but noone had any technical info on them, but I did see some pictures. My guess is that they're 8 ohm speakers with a very high power rating. Just make sure your amplifier is rated 8 ohms too, good luck! (P.S. if you're amplifier is rated 4 ohms on the output, I would recommend getting an 8 ohm output amplifier on ebay, in the event the speakers are 8 ohms) Hope this helps.
May 04, 2010 | Kinyo PS-205 Computer Speakers
How do i install 2 ckicker cvr to my amp
Here are a couple of diagrams 2+4 ohm dual voice coil wiring.
Option 1 (parallel/parallel) = 1 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 2_4ohm_dvc_1ohm.gif
Option 2 (series/parallel) = 4 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif
Option 1 (parallel/parallel) = 0.5 ohm load
Recommended Amplifier: Stable at 1/2 ohm mono 2_2ohm_dvc_05ohm.gif
Option 2 (series/parallel) = 2 ohm load
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_2ohm_dvc_2ohm.gif
Option 3 (series) = 8 ohm load
All voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif
Apr 12, 2010 | Kicker CVR12 Car Subwoofer
How do i hook up kicker solo baric in the box
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif Option 1 (parallel/parallel) = 1 ohm load
Apr 10, 2010 | Kicker Solo-Baric L5 Car Subwoofer
How do i install my L5 solo barics to a 2 channel amp if there is only one connection on the enclosure next to the vent? If I bridge the amp to 1x1000W will the power distribute evenly between both...
Option 1 (parallel) = 2 ohm load
Speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_4ohm_svc_2ohm.gif
Option 2 (series) = 8 ohm load
Speakers wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_svc_8ohm.gif
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif Option 1 (parallel/parallel) = 0.5 ohm load
Apr 09, 2010 | Kicker Solo-Baric L5 Car Subwoofer
6 ohn wharfedale speakers on an 8 ohm TEAC amp (both old) - will that work
Yes. Most if not all speakers have impedances which vary with frequency and are rated at a nominal or average impedance. So a manufacturer who rates their speakers at 6 ohms may be more honest or chooses to quote it at a specific frequency. So a nominal 8 ohm speaker may actually measure 4 ohms at 100Hz and 12 ohms at 500Hz but averages somewhere nearer 8 ohms. It is normal for most speaker manufacturers to simplify their ratings so speakers which average at say 6 ohms would be categorised as 8 ohm, and 4.9 ohm averaged speakers as 4 ohms.
As a point of interest - some amplifiers are specified as providing their maximum power at impedances of 6 ohms, and there fore some speaker makers (including those made by same manufacurer as amplifier) will rate their speakers at 6 ohms so they appear more compatible.
Mar 05, 2010 | Audio Players & Recorders
I have Kicker ZX 650 4 channel amplifier and 4 DB drive PT6.2 mid range speaker. I want to hookup my speaker in 2 ohms. The operation manual for the amplifier can be used in 2 ohms. I need to know how to...
As far as I am aware you need to get 2 ohm speakers. I run a 4 ohm subwear as the Alpine Type R sub is 2 ohms. I'm not 100% on this though but you may get around it by bridging your speakers by connecting both speakers to the amp as normal but swapping the speakers negatives around! That may cause the amp to run as if only at 2 ohms. Hope this helped!
Feb 18, 2009 | Sony XM-2150GSX Car Audio Amplifier
Radio Communications Logo
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
