Question about Kenmore 24.5 cu. ft. Side-by-Side Refrigerator with PUR Ultimate II Water Filtration
Kenmore 363.50242000 not cooling well enough. We just bought frig secound-hand and hauled home Monday installed by early tuesday but it is still 40 degress in freezer compartment and about 60 in frig compartment. Put on initial settings first 24 hrs and now on coldest settings. Lots of condensation in frig. I live in central IL. Where do go from here.
the dr
  • 447 Answers
SOURCE: My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Posted on Oct 03, 2007
capsman
  • 111 Answers
SOURCE: freezer works but frig is not cooling
I don't know this particular frig, but evidently the defroster doesn't work. Frost buildup has blocked the flow of cold air.
There is a defrost timer, under the frig, accessible from the front. You can turn it with a screw driver. Turn it till you hear a click. If the timer hasn't been turning, that should turn on the defroster, a heating element nested among the freezer coils. Wait half an hour and if it is defrosting, water should be dripping into the drip pan underneath the frig. If so, then replace the defrost timer and you're good to go.
If that doesn't make it defrost, then the problem is probably the defrost thermostat, in with the freezer coils. When the frig defrosts, the defrost heater stays on until the defrost thermostat gets warm. It should be open circuit while warm. But if it is open circuit while cold, it is bad and is the cause of your defrost problem.
If you open up the freezer coils, use a hair dryer to defrost. That is safer than hot water.
Hope you can fix it.
Posted on Aug 01, 2008
  • 117 Answers
SOURCE: I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Posted on Feb 19, 2009
  • 260 Answers
SOURCE: Kenmore side by side freezer not cooling
try removing the panel in the freezer. you will see an evaporator fan . test it and the thermostat beside it it is one of the two
Posted on Apr 09, 2009
buddymcl777
  • 67 Answers
SOURCE: Frig and freezer not cooling. Everything is thawing
1/ refrigerant leak or
2/ Defective thermostat / sensor or
3/ Burnt out compressor
Posted on May 01, 2009
Is Tuesday 17th April 2017 a bank holiday, i get paid tuesday 17 will my money go in early do to bank holidays
Tuesday is not a bank holiday, only Friday and Monday are. If you usually get paid on Tuesday then you should still get paid on Tuesday as usual unless your place of work had notified you otherwise.
Apr 16, 2017 | The Computers & Internet
Frig & freezer not cooling enough. Ice forming in back of bottom freezer.
You need to have the defrost cycle checked.( heater, limit stat, timer) If the frig can't defrost air can't move across your coils to cool properly. To temporarily get by until you can get a repairman, use a blow dryer to melt the ice build up. Once melted it will work normally for about 2 days till it freezes up again.
Nov 13, 2013 | Kenmore 73502 / 73504 / 73509 Bottom...
Compressor is hot and I hear clicking in back every couple of minutes. I understand that this indicates that the compressor is in a locked up / no start condition. the overload cools enough to reset and...
Could be bad start/over load relay, or bad compressor. Try unplugging your frig for say 30 to 40 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. When the start/over load relay fails, it can apply power to both the compressors start coil AND it's run coil at the same time for to long and it very quickly causes and over load situation. I bet your "Starting Components" (start/over load relay) are bad. Any decent appliance parts store will have what you need. Just take in the make, model, and serial number of tour frig.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 11, 2013 | Refrigerators
My frig is extremely hot to the touch on the metal face that separates the freezer and frig. Any thoughts on what might be causing this problem. If it helps, we just moved the frig from another home. ...
Likely the cooling fan has died. This happened on my unit. The fan is visible from underneath on the rear left side. Use a flashlight to see if it is spinning. I used a broom handle to tap it and it started to run, which cooled the metal you found hot. I ordered the part on line and replaced it. Heating problem went away.
Jul 08, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Used Kenmore freezer won't get cold enough
If it is running but not cooling enough the problem is in the sealed system.
If you started it up just after hauling it home it may have be moved around enough to get oil in the systems smaller tubing causing problems. Unplug the unit for 24 hours and let it sit. Try it again for 24 hours and see if it cools.
If not this means either there is a refrigerant (freon) leak in the system or a restriction causing the refrigerant to not flow properly.
Either one are an expensive repair. and will require a professional to look at.
May 09, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
My frig is running but not cooling - frig is 50 degrees,freezer 40 degrees, cleaned the coils,etc GE side by side coils in bottom if frig side feel cool, "box" between freezer and frig side is not blowing...
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Jan 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Not cooling enough per the display
I have this same model which I think I bought in 1988. My frig was overheating also and the compressor was extremely hot. I too cleaned the condensor coils again and have been cleaning them at least annually for a decade and a half by putting an adapter on my small vacuum cleaner. This time I took my 6 hp shop vac and a long bottle brush and scrubbed the coils clean running the brush over the coils many times and using a trouble light to help identify where all the accummulated dust was. Frig is working perfect again. Exhaust temperature is substantially reduced. Hope this helps.
Apr 30, 2009 | Kenmore Refrigerators
Feb 19, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
My kenmore refrigerator side by side
All the cooling takes place in the freezer and is blown over to the frig side so the frig side will start to warm up soon. Possible cause is the starting device to the compressor is faulty, compressor motor locked up or cold control faulty and not closing.
Feb 19, 2009 | Kenmore Refrigerators
Kenmore 24.5 cu. ft. Side-by-Side Refrigerator with PUR Ultimate II Water Filtration Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
