Question about Canon imageCLASS MF8180C All-In-One Laser Printer
Error: E000 How do I fix this? I've tried taking the fuser out and unplugging and everything like that. I think this thing is a big hunk-a-junk.
  • 1,006 Answers
Canon Error Codes
L5000,5500,7000,8000: To enter service mode Data Registration, #, Ram Clear is under #8 clear
Faxphone 20 ram clear
Turn off the power switch
Turn off the memory protect switch (located on the bottom of the machine)
Turn the power on
Press function # 2 0 start
Turn the power switch off
Turn on the memory protect switch
Fax L770 fuser gear wears out easily under heavy usage. White gear with 2 sets of teeth.
Inkjet models such as the B160 will hold faxes in memory and refuse to print if excess ink has accumulated on the pad under the cartridge's nose. Remove the cartridge and wipe up excess ink with a cotton swab.
Posted on Nov 02, 2007
How do I clear an error mesage E000
The E000 ERROR is a fuser problem. this happens when the fuser takes to long to come to the right standby temp.
I think a away around this would be to keep letting it warm up to the point it has hit the right temp by keeping powercycling it. I think though you will need a new fuser
Jun 24, 2011 | Office Equipment & Supplies
Canon i-sensys MF8188OC with error E000, it can not work, what does it mean?
The error code E000 means that the fuser is not warming up correctly. You can try to unplug the copier for a few minutes. If that dose not fix the poblem, you will need to have the fuser unit replaced
Jul 26, 2010 | Canon Office Equipment & Supplies
SYSTEM ERROR CODE E000- HOW CAN THIS BE RESET? WHAT DOES THIS ERROR MEAN?
A E000, means that the fuser is not warming up correctly. You can try to unplug the copier and see if it will reset. If it will not reset, you will have to have the fuser unit replaced or the upper fuser heater unit and film. Good Luck
Jul 21, 2010 | Canon imageCLASS D761 Copier
What is error code E000 mean
Solution:
Press "Additional Functions",
Press "#", then press the "Right Arrow" button till it says, "Printer",
Then press "Set" then press the "Right Arrow" button again until it says "Printer Reset"
Then press "Set" again, the display will ask you "Yes" or "No".
Press the "Left" arrow for "Yes", then press "Set".
Now, unplug the power cord and wait 5 seconds and plug back in.
If this don't work, get a new fuser.
Feb 04, 2010 | Canon imageCLASS D880 All-In-One Laser...
System Error E000
This is a fuser error, you can try unplugging the machine and plugging it back in and this might reset the error, however if you try this and the error code pops up again, it could be one of the following which would require having the machine serviced and repaired by a professional. The fuser thermistor could be open or the heater lamp could be open or the thermal fuse that prevents the fuser from overheating could be open.
Sep 03, 2009 | Canon imageCLASS MF8170C All-In-One Laser...
Eooo
E000 is a fuser error
Thermofuse (blown)
Lamp (blown)
replace
check repair price vs new one
Oct 16, 2008 | Office Equipment & Supplies
Canon super g3 image class d880
E000 means your fuser section is having problems.sometimes you can reset but may need to replace fuser unit.
Sep 04, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
I have an old canon NP2120 Copier. I am getting an error code E000 when I turn it on. Is that something i can fix?
Are you mechanically inclined????
If yes the problem is most likely the fuser lamps are burned out.
This is to take out the fuser unit (the two heat rollers where the paper exits---------let machine cool first!!!!!!!!!!)
1-unplug machine
2-open left side door
3 open front door
4- remove the green knob on the left
5-remove the left side cover ( i beleive you need to take off the two screws on top that hold the glass also)
6-remove the back cover(it is hooked onto the side cover)
7-after removing the side cover look at the fuser left top corner unplug the connector- there should be one on the right also big black wires with a white connector remove the screws that hold the fuser in place
8- once the unit is out there is a lamp that runs the whole lenght of the roller that is the fuser lamp there are wires on each side, remove the lamp bracket holder and one wire, you should be able to tell if it is blown, it will be black and smoky looking not clear.
if you go through these steps you should take advantage and replace the thermistor, thermofuse, claws, and oil roller.
I use to love the 2120 they are one of the best machines Canon put out a true workhorse, do these things and don't worry about hte fuser for another 3-5 years .
If you don't have a parts supplier try precisionroller.com
Aug 19, 2008 | Office Equipment & Supplies
How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Jul 11, 2008 | Canon Office Equipment & Supplies
Canon IR 1600 Error message E000
You'll need to replace the fuser unit. Not exactly the cheapest part of the machine...
Unless, that it, you were taking things apart and happened to unplug something accidentally. If you take the cover off where the paper comes out, look at the connectors directly inside there under the black piece of paper that you'll see. If one of those are pulled out, it could cause the problem.
Otherwise you need to replace the fuser unit.
Erice
Nov 23, 2007 | Canon imageCLASS D860 All-In-One Laser...
Canon imageCLASS  MF8180C All-In-One Laser Printer Logo
233 people viewed this question
old marine
old marine
