Question about Liebherr Refrigerators
Ice in bottom of freezer
Cs16
2 Suggested Answers
shastalaker7
  • 1515 Answers
SOURCE: fridge and freezer display shows ON and not
Hi, if the display is supposed to show the temperature of the fridge/freezer on the display then what appears to have happened is that the remote temperature bulb has come out of place. If you can get to it you may be able to put it back in place. You will have to start at the display and will see the temp. cable and follow it back to see where the bulb is now resting. If it is not exposed for you to be able to excess it, I would call asap from where you bought it as it is new and tell them about this condition! Keep me updated on this please.
Sincerely,
Shastalaker7
PS It would not be the compressors unless the unit is not cooling at all then you could have a serious problem.
Posted on Jan 17, 2010
ICE FORMS IN FREEZER BOTTOM,
Keep the bottom of your freezer free from ice. ... The water from the melted ice and frost drains through a short tube and into a pan beneath the refrigerator, where it evaporates. Should the drain line become clogged, the water has nowhere to go and it freezes, forming a layer of ice in the bottom of your freezer.
How to Fix an Iced Freezer Bottom ' Home Guides ' SF Gate
homeguides.sfgate.com/fix-iced-freezer-bottom-42777.html ICE FORMS IN FREEZER BOTTOM Google Search
Oct 23, 2017 | Refrigerators
The freezer is on the bottom of the fridge...and the bottom part of the freezer is forming a block of ice..just over 1 yr ago that i purchased the fridge. i tried moving things in the fridge forward so...
There is normally a "thing" that controls the auto defrost I had a freezer that started so it this out of the blue. Some how that "thing" got unplugged. It was in the freezer behind a panel in the back by the light.
May 28, 2017 | Maytag MBR2562HES Stainless Steel Bottom...
Fridge and freezer display shows ON and not
Sincerely,
Shastalaker7
Jan 17, 2010 | Liebherr KGBN 3846 Premium BioFresh Bottom...
Icemaker not working on a Kenmore Bottom Freezer
if the volve behind the fridg for the ice get 120v for short time when the ice maker ask for water then the volve is bad but if there is no 120v to the volve then the command not coming from the ice unit and it need to be change , the wholl ice maker unit :(
Dec 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
Jul 01, 2009 | GE Monogram ZICS360NRRH C... Bottom...
Kenmore elite bottom freezer icing up
if it has an ice maker fix or adjust the over flow for the ice try.
Jun 18, 2009 | Zanussi ZEBF250W Bottom Freezer...
Kenmore elite bottom freezer. Frost, Ice tray
The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
Mar 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bottom Freezer has ice built up
Possibly the defrost element is faulty, this is located behind a cover in the back of the freezer compartment and is attached to the fins of the evaporator. It also has a defrost limit thermostat which could also be the problem. I presume that the fan is working after you have defrosted the unit?
Mar 04, 2009 | LG LFX25971ST Bottom Freezer French Door...
Ice on bottom of the freezer
Your drain is blocked causing the ice in the bottom of the freezer.
The drain is located about 7 inches up from the bottom rear of the freezer.
Just below the back freezer panel.
Turn the fridge OFF.
Remove the bottom bins.
Take a hair dryer and thaw the ice in the drain.
Pour 1/4 cup of bleach in the drain line.
Problem solved.
Feb 24, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Apr 12, 2008 | Refrigerators
Refrigerators Logo
13 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
