Question about Panasonic NN-P794SF Microwave Oven
How to fix
At the display appers H-97
  • 6,784 Answers
Replace the touch key pad. it has failed.
If this is an integrated control design, you will need to replace the control board as well. some board designs link the control and key pad as one device.
Posted on Jun 20, 2009
My PANASONIC T945SF worked only for 4 months and died with H97. PANASONIC has a built in set parts on the board which blow up when certain time expires. Look at the manufacturing date before you buy. Best is to avoid non-American products as these products contain time sensitive parts which blowup when certain time expires so that you end up buying new one to help these companies going.
Posted on Jan 09, 2010
Kenmore microwave displaying SE error message. How do I fix it?
That error indicates a bad keypad. You will have to replace the keypad/control console assembly.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Apr 22, 2014 | Kenmore Microwave Ovens
MICROWAVE OVEN MODEL R-1405 THE INDICATOR NUMBERS ON FRONT PANEL DO NOT WORK WHAT DO I NEED TO FIX PROBLEM?
A faily common problem. You need a new display panel to fix that. The display panel comes separate from the control board.
Feb 12, 2011 | Sharp R-1405 / R-140 Microwave Oven
My GE Advantium SCA1000HSS LED display is blank. The display just went out one day when I opened the microwave door. I can microwave using the "add 30 second button". Also the timer works if you...
Sounds as though you'll have to replace it again. There isn't much else it can be. Is there a chance that the house is not well grounded? Lighting and the such can do this.
given the cost of parts....Look to price shop a new one before fixing this one.
Jan 31, 2011 | GE Advantium SCA1001HSS Convection...
I bought I microwave in the USA and I had it installed in my home in Brazil and appers working well but it doesn´t heat. What I could do to solve this problem?
Was it new? normaly when a microwave deos not heat it means the magnetron is dead (that's the part of the oven that produces the microwaves) or it could be a burned fuse, if it's a dead magnetron it is almost as expensive as a new oven.
Jan 04, 2011 | Samsung SMH9187ST Microwave Oven
My microwave just stop for no apperant reason
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 07, 2010 | Sunbeam Microwave Ovens
Good Morning, My mother-in-law tunred the microwave on for 1 hour instead of using the timer. It now appers comletely dead. Anything we can do Or time to buy a new one?
Aounds like ***********-in-law cooked the magnetron. If a microwave runs for an extended period with nothing in it, the magnetron (thing that makes the microwaves) is likely to have failed.
Help the environment and don't throw it away, find your local Maytag service center, by using http://www.servicebench.com/servlet/WebSideServlet?Request_Id=APPWhirlpoolDealerLocateBrandedGoto&Request_Server=servicebenchpublic&Request_Brand=M&Request_ReadUrl=Y to locate your local agent.
May 21, 2010 | Maytag MMV4205 Microwave Oven
I have an nn2505c microwave that powers up but displays door open
Took it to a repair shop ,cannot be fixed ,no parts discontinued microwave.
Jan 19, 2010 | Panasonic NN-2505A Microwave Oven
Ran on power for 10 minutes, thought it was on timer.
First, check the fuse usually located above the display, inside the top lid.  You can't see if it's blown, so you must test it for continuity with a meter or self powered test light.  Usually fifteen amp, and of the ceramic variety.  (available at radio shack type places) If the new one blows instantly, it's likely a door switch shorted out.  If it blows after a few seconds, it could be the magnetron gone bad, or internal arcing.  The main transformer will sometimes short out, but that's rare.   Be absolutely careful, should your fingers venture around the magnatron connections down below, as there is high voltage and current that can kill you.  This warning applies even when it's unplugged!
The door switches operate together, so if one slams the door shut it will often blow the fuse with no other damage.  Sometimes the crow-bar switch will sustain damage in the process.  Usually, if the switches click individually, they're good.  If one doesn't click, it'll almost always be shorted.  They're located behind the door catch, inside the unit beside the display board, and a bit hard to access.  You will need to reach past the magnatron for this, so be careful.
Jul 15, 2009 | Whirlpool GH6177XP Microwave Oven
How to get rid of H97
h 97 is an inverter or magnetron fault you will need an engineer to fix try 08705 678910 for help,dont try to repair yourself risk of shock stored energy.
Oct 05, 2008 | Microwave Ovens
Panasonic NN-P794SF Microwave Oven Logo
317 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
