Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Fuel to Air adjustment?
I can't get my saw to start. It fires with starter fluid but won't fire with fuel. It has a new plug and I have completely cleaned the unit..
steve_lima
  • 181 Answers
SOURCE: old homelite chainsaw, wont pull fuel
most of the time there is a air leak in one of the two crank shaft seals.to get to them you need to pull off the flywheel and the clutch assy.look for wet areas. that will be where the seal is letting out the oil and air.If you keep putting starting fluid in the carburator you will burn the rings,the piston and the cylinder up
Posted on Jan 07, 2009
clyde2j2
  • 137 Answers
SOURCE: I have a homelite 240-hg I cant get it started i
Try some starter fluid (eather) that wil give you an indication if it's ignition or a fuel problem.
Posted on Feb 28, 2009
  • 16 Answers
SOURCE: my chain saw is getting to much fuel and is stalli...
clean your air filter
Posted on Jun 02, 2010
  • 4088 Answers
SOURCE: Will not start
That seems to imply that the check valves in the primer pump and in the fuel pump section of the carburetor are bad or the air pressure just forced by the valves. The line without the filter is the tank return line from the primer pump. The primer pump is supposed to pull fuel from the fuel filter into the carburetor flooding all spaces within it it, then passing out to the primer pump and from there, back into the tank. Does the primer bulb fill with fuel after several pumps? The first try may take longer because you forced all of the fuel out of the carburetor with the air pressure. Make sure all of the carburetor fasteners are tight. It's possible that you have injured the diaphragm in the carburetor lower chamber when you blew air into the line. Go to: www.drystacked.com for a 12 page article on Walbro carburetor theory and troubleshooting. Make sure the spark plug gap is set at 0.020". Hope some of this helps!
Posted on Jul 04, 2010
suzukiracing
  • 200 Answers
SOURCE: Chain Saw Motor will not start.
Yes it is very important i would recommend also putting in a new spark plug. Thanks for asking and I hope it helps
Posted on Jul 21, 2010
MK2A Ride on mower won't start
If it will fire with starter fluid, it's about 100% that you have a carb
problem. The fuel jets don't take too much to stop up.
Re-clean the carb paying close attention to any orifices.
Jan 31, 2018 | Garden
Makita concrete saw dpc7321 won't start has fuel and spark compression seems low 60 psi what should it be?
That does seem low, but it's a 2cycle.
It hasn't been run hot or w/o proper gas/oil mix has it ?
Will it fire with a squirt of starter fluid ?
If you squirt some oil into the spark plug hole, does the compression go up very much ?
If it has spark and won't fire w/starter fluid sprayed in thru the carb, it's most likely a ring/piston/cylinder problem.
If it fires with starter fluid, it's fuel not getting into the cylinder.
Jan 05, 2018 | Makita Garden
ISO definitive eng compartment pic/diag/schematic of fuel line & line-pressure valve/access, bleed disconnects + alt intake spots 4 starting fluid, beyond air filter intake.
to remove contaminated fuel , pull a fuel line of the fuel manifold and run the pump for a few seconds
not firing is sensor , immobilizer , ignition module problem but you stat that it fires on starter fluid so that cannot be right
starter fluid is a d good way of damaging the engine
a better way is to find and fix the fault
now to try and sort out what you are saying
it is cranking so the starter is good
it tries to run on starter fluid so there is spark to the plugs
it will not run and that indicates a lack of fuel to the injectors
a lack of fuel indicates
1--- a bad fuel pump
2--a vacuum in ht e fuel system from the tank not venting properly(EVAP system)
3--- fuel pressure regulator not working and providing pressure to the injectors
4--- bad injectors --- need cleaning
dump the starter fluid , buy a workshop manual and fix the problem properly
Oct 29, 2016 | Cars & Trucks
Spec vin ecu specs
If it turns, then the battery is OK. Either spark plugs are not firing in proper order (wrong firing order), no power to spark plugs, or no fuel because of fuel restrictions (dirty fuel filter). Inspect the air filter to ascertain its not clogged air. If you smell gas, then you saturated the spark plugs, which is why it refuses to run.
Let it sit for half hour to let spark plugs dry. Inspect to ascertain its not dirty spark plugs, which will also prevent engine from running. After ascertaining its proper firing order, spark plugs are clean, and there's power to distributor cap, ascertain there's fuel in fuel lines by squirting half second (short squirt) of starting fluid into air filter. Close the air filter housing to trap flammable starting fluid gas. Turn engine without giving throttle. Let starting fluid be ignited by spark plugs. If it won't start, then spark plugs are not firing to ignite starting fluid gas. If it starts briefly, but won't run when you give throttle, but catches when a 2nd person squirts more starting fluid into air filter just before engine stalls, then its a fuel restriction issue or no fuel in fuel lines.
Nov 29, 2013 | Cars & Trucks
Need additional assistance...03 raptor 660, new plug, new oil, new fuel, clean fuel filter, clean petcock, cleaned carbs 5 times, used wire to clear jets(from one solution earlier), readjusted air screws...
how is the fuel flow? i just went rounds with a mower and it turned out the tank vent was faulty stopping the amount of fuel flow to the carb. it would flow fine for a minute until it needed air in the tank and then would stop.
Feb 11, 2013 | Garden
My s10 truck is gettin fire, gas and air.. will turn over but will not crank.. what could be the problem?
Just because it get fuel,but does the fuel injector pulse? Add fuel in the throttle body if it wants to start your problem and solution will resie in bringing the fuel injector to working level
Apr 13, 2012 | Chevrolet S10 Cars & Trucks
Saw won't start without starting fluid.
Sounds like you have a compression problem. Starting fluid will fire at a much lower compression than a gas/oil mix so that's why it will start with it. When the motor is running you get a little more compression because the piston is coming up so fast. You should check the condition of your cylinder wall and piston & ring. If they are damaged at all you loose compression which directly affects starting and running power.
Mar 28, 2012 | McCulloch Garden
Saw will not fire. has spark at plug and compression is 130 will not fire even with starter fluid
If there is fuel to the plug, and a good spark it should fire, all i can think of is the ignition timing is out due to a sheared flywheel key.
Jun 11, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Have not started saw in 4 mos. Now cannot start. Replaced fuel and still won't start.
Did the saw sit for this time with gas in it? If so, the gas in the carb has probably turned to shellac. Take the top cover off, remove the air filter, open the carb butterfly and spray some carb cleaner in it. Wait 24 hours and try to get it to fire. While you're waiting, check the plug for fouling. If it still won't fire, give it a small shot of starter fluid.
Jun 06, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Jonsered 4036 chain saw shows fire at spark plug won't fire.
Brake cleaner might not be the best choice for test firing... Pick up a can of Starting Fluid and spray a VERY SMALL amount into the air filter...
If it still doesn't turn over the engine might be worn out/damaged internally... At this point I'd compression test the engine and if the compression is lower then 80-90PSI It would be time to get a new saw.. If you can't get you hands on a compression tester you might want to take it to a Lawn and Garden shop and have them look at it..
If it does turn over with the Starting Fluid you looking at a fuel problem and I'd start with changing the gas with a fresh can and checking the (fuel filter) <-- found in fuel tank...
It will run with the bar off..
The brake only stops the chain and has nothing to do with the spark...
Hope this helps..
May 20, 2009 | Garden
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
