Question about Yamaha 12V Air Pump
Starts with starter fluid but wont continue to run
I think it is not getting fuel. Has not been run for over a year now. Starts right up with a shot of starting fluid and then when that is burnt up it stops.
    Champion:
  • 207 Answers
What is it ? if it a ski then you will need carb kits yu can get them from riva yamaha there on the web
Posted on Jul 08, 2009
I JUST BOUGHT A NEW POULAN WOODSHARK CHAINSAW AND IT WILL NOT START
hello red.... how aggravating. Check to be sure the chain is not too tight. Check to be sure it has the right mix of fuel and oil, a clean filter, and a new spark plug. Then get a can of starter fluid and a helper. Remove the air filter and have your helper squirt a little starter fluid into the air intake. Once it starts have the helper continue to squirt starter fluid until it will run on it's own, usually a couple of minutes. Joe
Apr 15, 2011 | Garden
Wont start. some coil packs are not firing.
Replace and/or check the the coil packs for continuity associated with the cylinders that are not firing.
Also, check for fuel delivery using a fuel pressure gauge on the rail, and verify that the fuel injectors are firing using a noid tester or a stethoscope on the fuel injector to check that they are clicking.
Try to add starter fluid to the intake manifold through the throttle body to see if it starts that way, signalling a fuel delivery problem if it starts right up.
Good luck on this repair.
Oct 28, 2010 | 2002 Mitsubishi Montero
Engine turns over starts when i use starter fluid but wont stay running
IF IT STARTS WITH STARTER FLUID OR EVEN IF YOU WERE TO BUT SOME GAS IN IT MEANS NO FUEL IS GETTING TO INTAKE IT COULD BE A CLOGGED FUEL FILTEROR SOME KIND OF PROBLEM WITH FUEL LINE BUT THE MOST LIKELY THING IS THE FUEL PUMPYOU CAN TRY TAKEING OFF THE FUEL LINE AT THE EASYEST PLACE YOU CAN FIND TURN THE KEYTOSTART FOR 2 OR 3 SECOUNDS SEE IF YOUR GETTING GAS COMEING OUT OF LINE IF NOT YOU NEED TO CHCCK TO SEE IF THERE IS POWER GOING TO THE PUMP CHECK FOR FUEL PUMP RELAYS OR RELAY MOST LIKELY IS THE PUMP IS BAD THERE A WARE PART AND NEED TO BE REPLACED EVERY 10 TO12 YEARS OR SO GOOD LUCK
Oct 18, 2010 | 1990 Lexus LS 400
Has been sitting for a few years.. cleaned carb and chedcked settings on H and L screws.. still wont start.. replaced fuel lines and primer bulb.. and its a mac 3227 weedeater.. cranks but doesnt start,...
siphon out the old fuel and put brand new fuel in the tank. Change the air filter even if it looks ok. Put in a new spark plug. Then get a can of starter fluid and an assistant. Squirt some starter fluid into the air intake and start it up. have your assistant continue to spray the starter fluid for a minute or so until it runs on its own. J.
Sep 30, 2010 | McCulloch Garden
1996 izuzu rodeo wont stay running
Its not getting fuel then. Do you hear the fuel pump? It makes a humming sound
Mar 02, 2010 | Cars & Trucks
Where do I apply starter fluid in my dodge caravan? My Van starts with the lights and battery working, but the enging wont start wnen i turn the key. I bought starter fluid, but am not quite sure where to...
Please restate your problem, or confirm what I think is your problem from the following-
1) Your headlights work OK meaning the battery is charged.
2) The engine turns over with the key, but will not start.
If both conditions above are correct, then toyotech6 is very likely right. And if the engine starts but does not continue running, then be suspect of the fuel pump or fuel filter (assuming the gas tank has sufficient gas in it.). If it does not start, then be suspect of a failed igniton module or other probelm. You'll need a scan tool to find the problem.
Dec 09, 2009 | 1999 Dodge Grand Caravan
I have trouble starting my 316 JD tractor. When I
I do not have answer I will like to have an answer for my 316 JD no power no lights on dash battery new and was running shot off and wont stared again.Thank You
Aug 15, 2009 | John Deere New Tractor Starter w/ 317...
99 blazer wont start
need to check your fuel pressure...pump may be running , but not putting out enough pressure
Feb 07, 2009 | 1999 Chevrolet Blazer
Yamaha 12V Air Pump Logo
210 people viewed this question
Top Yamaha Water Sport Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
