Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
My HE3 washer fills up with about 3 inches of water on its own when it is not in a washer cycle
    President:
  • 1,185 Answers
Fill valve is not sealing correctly when it is switched off
If your machine is hot & cold fill, try turning off the cold water at the inlet and see if the machine still fills up if it does then it is a faulty hot valve if it does not then it is the cold one
They are easy to change and easy to buy from dealers or third party suppliers
Posted on Jun 19, 2009
Sears washer elite he3 fills back up with water when off
You have to shut your wall inlet pipe after your wash is over. If the leak persists you only have to change the inlet valve, which you can do yourself, see internet for spares quoting your washer number, model. It is good to keep the valve closed when the machine has finished it's wash.
For unlocking hold down "end of cycle" button at right side of panel for 3 - 5 seconds. The door remains locked when there is water in the machine, it does not want to wet your floor. Today's machines are smart. Helped?
Mar 05, 2013 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My Maytag Neptune will not go into the spin cycle, instead the letters "nf " come on the display. What can I do to prevent this and to have the cycle completed?
Bonnie,
NF = No Fill the control board receives signaling for the washer during the water fill cycle. With most cycles the depth of water is around 3.5 inches in the wash basket. I know a Bulky Wash cycle selection will fill the wash tub to a high fill which is about 7.5 inches of water in the wash basket.
Is the washer filling the machine with any water? Do you hear water entering the machine? If you are doing a cold water fill and there is no or very little water in the wash basket with the NF error code. Try a Warm or Hot fill and see if the machine will fill and start the wash cycle.
Assuming you are doing cold water wash loads. You could have a water line block at the inlet screen or a failed cold water inlet valve which will not open. Try the above and let me know the results..........Rich
Sep 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer fills with water after the cycle is over
check the pressure senser ,if this ok check the pcb assy
Jun 20, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My He3 begins to fill the drum with water (very slowly) after the cycle is done, I have to turn off the hose valves after the cycle to keep this from happening. Any ideas what is letting the water back...
sounds like you have a bad water valve..if water is come in try to unplug the washer if water stop you have a bad control if it keep filling you have a bad water valve
Sep 20, 2009 | Washing Machines
Kenmore HE3 washer
The water valve is not closing fully. You will need to replace the water valve.
Mar 31, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
HE3 front-loading automatic washer
Sounds like the water valve is not turning off 100%. Replace the inlet water valve. (where the hoses connect onto the machine)
Aug 28, 2008 | Washing Machines
Kenmore he3 series washer keeps filling with water when not in use
Remove the 3 screws at the back of the machine that hold the top on. pull back on the top and lift the top off. Remove the hose from the inlet valve and remove the screw that holds the inlet valve.
Aug 12, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 washer keeps filling with water
The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
Nov 15, 2007 | Kenmore Elite 45986 Front Load Washer
set the washer to fill. open the lid and depress the lid switch. might be in the rear of the cover or on the side. watch to see where the water level comes to. once the tub is filled, the water height switch operates the timer motor for the different cycles.
Sep 10, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
143 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
