Question about Radio Shack Pro-95 Handheld Scanner
Getting scanner to scan
I am trying to get my pro scan 95 to scan. It says the banks and memory are full but keeps going back to locked out status.
  • Radio Shack Expert
  • 509 Answers
Make sure that the keypad isn't locked. See if there is a little key in the display. If yes, then hold down the lock key to unlock the keypad. Next, hit 'scan' and you will have to select a group to scan, so press the #1 or #2 button IF you have frequencies loaded into it. Can you press the WX button to hear the weather? Let me know. Good luck.
Posted on May 01, 2017
sir fixalot
  • 146 Answers
SOURCE: Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
http://support.radioshack.com/manuals/ome20-525.pdf
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Posted on Jan 04, 2008
  • 27 Answers
SOURCE: all channels locked on my radio shack pro-95 scanner
You are pressing the "scan" button in the upper left hand position and getting all channels locked out? Correct?
If you haven't programmed any frequencies the channels will stay locked out. Get your local frequencies by doing a search for police scanner frequencies. Once you have gotten the information for your area press the "PGM" button on the lower right hand side of the key pad. Input your 1st frequency ###.#### then press "ENTER". Press "PGM"key again and enter your 2nd frequency then "ENTER" again. Repeat as often as you wish to enter more frequencies.
Make sure you are entering your frequencies in empty channels unless you want to over write one that you don't want to use any longer. Press "PGM" until you get to an empty channel.
When you are done, (you can stop any time) press the "SCAN" button in the upper left hand position and you are in business. You are supposed to be able to choose which memory position you wish to use but I haven't tried to figure that one out.
If you need the manual for the radio go to radioshack site and do a search for PRO95 and it will come up in PDF format.
Hope this helps. I have owned the pro 95 for maybe 6 or 7 years and after doing a little programming yesterday the thing is much more to my liking. It scanns quicker and scans the channels I wish to listen to.
Posted on Jul 31, 2009
  • 13 Answers
SOURCE: clearing out old channels on a radio shack pro 95 scanner
Turn it on, and when "Welcome" appears, press zero, then press one. It will display a message indicating it is initializing to the factory state.
Posted on May 08, 2010
  • 8 Answers
SOURCE: Pro-96 Scanner: My pro 96 scanner says all channels locked and it ...
If there is no frequencies on your scanner it will lock all channels out. if all your frequencies are on one bank and you accidentally hit that bank number and turn it off it will lock out all channels. If that's the case just hit that bank no. back on and they will unlock.
Posted on Aug 05, 2010
TOLhamRadio
  • 509 Answers
SOURCE: 800 MHz frequency Mode problem
You have to program it TRUNKING mode when you enter the control channel frequencies. It is decoding okay as the MO shows motorola control channel and +DG means digital decoded and an OPEN group. You need to press the 'trunk' button everytime a talkgroup comes up that you want it to remember for future 'closed' group (-DG) talk groups. I suggest you go to 'RadioReference DOT com" and there are many forums there for your radio, as well as one or two YAHOO GROUPS specifically for your scanner. 73's
Posted on Aug 10, 2010
I Havel a pro-95 scanner and I have frequencies programmed into banks 1 thru 6 and the scanner isn't scanning banks 2 thru 6
Make sure the banks are enabled and the frequencies in the banks aren't locked out. If you are scanning trunked systems make sure the control channels are set up properly.
Keep in mind you cannot scan digital systems with this scanner, only analog systems and frequencies.
Pro 95 The RadioReference Wiki
Mar 07, 2017 | Radio Communications
Pro 96 locked out
Press and hold the Lock key for 3 seconds, then the 'key' should not show up in the display. Also, when you press 'scan' try pressing some of the number keys to turn-off and to switch on scanning banks. Okay?
Feb 12, 2014 | Radio Shack Pro-95 Handheld Scanner
Pro-95 scanner can't unlock key pad can't reset can't initialize
my pro-95 has a locked number on the key pad--says=mooo**adl+*30375=bank 0 ch 00 ed: none can you help me get it unlocked ?
Jul 24, 2012 | Radio Shack Pro-95 Handheld Scanner
May 17, 2010 | Radio Shack Pro-96 Scanner
Will not scan. Screen shows banks and scan up message.
Try this,press manual,turn squelch to silent,press scan. hope this helps..
Mar 20, 2010 | Radio Shack Pro-95 Handheld Scanner
Pro 96 scanner only scans bank 3 and 4. i am sure
While it's scanning, press any keyboard number (0 thru 9) to activate/deactivate scanning on the corresponding bank.
Need the full manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc71/71778.pdf
For a comprehensive database of active frequencies and systems in your are,visit:
www.RadioReference.com
BillB
Jan 09, 2010 | Radio Shack Pro-96 Scanner
All channels locked on my radio shack pro-95 scanner
Jun 08, 2009 | Radio Shack Pro-95 Handheld Scanner
Pro-95 locking out channels
Hi, I would check out this site. These people eat and sleep scanners and should be able to steer you the right direction. They also have a huge database of info,,, good luck with it. Mechanic
http://www.radioreference.com/forums/forumdisplay.php?f=6
Jan 15, 2008 | Radio Shack Pro-95 Handheld Scanner
Jan 02, 2008 | Radio Shack Pro-95 Handheld Scanner
Programming channels
Hello ... IF YOU HAVE A COMPUTER YOU CAN MAKE PROGREMING, DETETINMG AND TRUNKING A BREEZE. IF NOT I FOUND THAT ALL FIRE AND POLICE TRUNKING ACTIVITIES ARE BETWEEN 840.0000 through 900.0000. WHEN YOU WANT TO SAVE A CHANEL TURN OFF RADIO AND TURN BACK ON SELECT THE DESIRED CHANNEL YOU WANT. THEN PRESS "PGM" AND ENTER YOUR FREQERNCY... PRESS ENTER AND IF YOU WANT TO ADD ANOTHER CAHANNEL ... HIT "PGM" AGAIN AND FREQ. AND ENTER. YOU CAN KEEP DOING THIS TILL YOUR DONE GROGRAMING .. THEN JUST HIT SCAN AND IT WILL SCAN ALL THE FREQ.S YOU HAVE ENTERED. HERE IS A SOFTWARE PROGRAM THAT CAN LOOK UP ALL FRQ ANYWHERE IN THE US AND WITHE A PLUGIN DOWN LOAD ALL THE CHANNELS. BuTel software home page ARC-433 software for Radioshack PRO-433 / PRO-528 / PRO-2051 'ARC433 is now available!' -------------------------------------------------------------------------------- ARC433 (US$ 29.95) is dedicated software for the RadioShack PRO433, PRO528 and PRO-2051 and is the most versatile software available for the Radio-shack PRO-433 / PRO-528 / PRo-2051. Screenshot from our memory editor: the most versatile memory editor available on the market: -------------------------------------------------------------------------------- Overview of options in ARC433: Order ARC433 now online using PayPal/credit card or call Santa at 1-800-SCANNER ARC433 supports the Radioshack PRO433, PRO528 and PRO2051 models in one single software package. ARC433 includes THE most versatile memory editor available on the market. Radioreference.com import option for conventional and trunk systems! Programming your scanner was never this easy! Enhanced CSV file import and 'mapper' Paste Frequencies DIRECTLY from any website using 'Paste Special' Setup channels in an easy, spreadsheet type interface. User Manual (45 pages, PDF file) Store Unlimited number of configurations on your harddisk. Copy/Move/Swap memory banks / memory channels Compatible with Windows 2000 / XP. All updates are free for registered users Easy cut/copy/paste data between channels and banks. Move channels up and down with quick move buttons Export CSV data Fill down/series option Full clipboard support for import/export data to/from other applications Easy data toggle with mouse double click or space bar or keyboard shortcuts Sort frequencies per bank Remove duplicate frequencies Easy Fill for setting up new banks in a few seconds (enter a start frequency and a step, and easyfill will calculate and fill the selected bank) Extra Dummy bank for storing temporary data while you are re-organizing your scanner channels. Print option System Requirements: Windows XP/2000/Vista PC interface cable 20-047 for USB or PC interface cable 20-289 for serial port Use other cables at your own risk! Use the ARC433 demo version to verify communication works before purchasing the software! All software sales are final. Order ARC433 for PRO 433 / 528 now online using PayPal or a credit card or call 1-800-SCANNER. -------------------------------------------------------------------------------- Screenshots:
Apr 16, 2007 | Radio Shack Pro-95 Handheld Scanner
Radio Shack Pro-95 Handheld Scanner Logo
96 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
