Question about Dishwashers
Both of the baskets are rusting and even several of the rungs have completely rusted off. This dishwasher was installed in 2003, 6 years old. Has anyone else had the same type of problem with this model? What happened to dishwashers lasting for 10-15 years? Where is the Maytag quality?
  • 71 Answers
The problem is most likely due to minerals or other impurities in your water. The nylon coating covering the metal dish baskets erodes quickly from contact with this water. It is also exacerbated by the wayers high temperatures.
Posted on Jun 19, 2009
Badger 5 is about 15 years old and is leaking from the bottom -- from the reset button, the plate on the bottom, and around the electric cord. Can I fix it or does it need replacing?
Once disposal rusts out, it needs replacement.
Usually if sink basket seal is broken or if dishwasher attachment is leaking, you can feel water near top of disposal.
Use paper towel at top to see if that area is wet.
If top area is dry, then water is coming from inside disposal, and disposal is rusted out.
If sink seal is still good, we used to buy same brand disposal and re-attach to same sink basket. That's the quick fix.
If this is inside your home, you probably want to install new sink basket that comes with disposal.
To install new disposal, also buy container of plumber's putty to seal sink basket.
Remove disposal.
Clean off old putty on sink. It will chip off easily.
Apply finger-thick amount of plumbers putty to sink opening.
Set disposal sink basket into putty and push down.
Tighten screws on bottom of sink basket.
Wipe away excess plumber's putty from sink so it looks nice and smooth.
Before lifting disposal into place, attach electric wires and attach dishwasher hose to disposal.
Use hammer and screwdriver to remove steel blocker located inside dishwasher stem ... the blocker is left in place if no dishwasher hose is attached.
Disposals can be different: But here's the usual sequence:
Lift disposal with one hand and hold level. Push up strong while rotating attachment ring until ring grabs bottom of sink basket.
If you cannot lift disposal with one hand while rotating attachment ring with other hand, use small bottle jack from auto-parts store. And put piece of wood between bottle jack and aluminum disposal so disposal doesn't break.
Here's how to handle tubular pipes below sink:
Any tubular pipe joint that moved while removing or installing disposal, has to be taken apart, cleaned and re-attached.
If washers are plastic, then clean and re-use.
If washers are rubber, then replace each washer with new rubber washer.
When reattaching tubular pipes, apply generous amount of rectorseal over each plastic or rubber washer for first-time seal of tubular pipes.
Nov 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Spots on dishes, especially silverware
Rinse additives help with the spotting, a lime descaler will help, put it in and run a cycle empty.
There are also several different types of cleaners available for sale at your grocery store.
Check your baskets for rusting, there isn't another reason for that unless your pipes are causing it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/gregg_78ecbb34e27be215
Jun 14, 2010 | KitchenAid 24 in. KUDP02CRBS Stainless...
Rust spots on bottom rack
You may need to replace the rack. Dishwasher soap is aggressive and once an area is exposed, it will rust fast. Make sure you don't place sharp objects in direct contact with a rack. The action inside the washer can cause them to move and rub through the metal rack coating.
Dec 06, 2009 | Maytag MDB6650A Built-in Dishwasher
How to repair rust on lower basket of dishwasher
Use sandpaper or brillo pad to remove rust, and paint it with acrylic appliance paint
Apr 15, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Maytag portable dishwasher, dish racks are very rusted in 2 years
This is Maytags solution
Do the dishwasher racks have chips or scratches showing exposed metal underneath?
If minor rack repairs are needed, a dishwasher rack repair kit just might work. To review this product or purchase the kit, click here.
Should you purchase the kit online, enter Promo Code F9A75Q4 in the Review Order screen when you check out to receive a 10% discount on your order.
For more severe rack damage, a replacement rack may need to be purchased; call the Maytag Customer eXperience Center toll-free at 1-866-616-2601, Monday-Friday, 8AM-6PM, Eastern Time.
I would call the toll free number and see if a free replacement is available. If not at least try to get a big discount on replacing them.
Good luck and thanks for using Fix Ya, please take the time to rate this solution (from Fix Ya, not Maytag, I didn't like their solution).
clarkco
Feb 05, 2009 | Maytag 24 in. PDC3600A Built-in Dishwasher
Do I need to descale or rust treat my Washing Machine?
  • this is a common problem with aging kenmore washers (leaving coins in your pockets speeds it up).
  •  the basket is metal with a porcelain coating. the porcelain coating wears around the edge of the holes in the basket first, leaving bare metal.
  •  when the washer spins the centrifugal force pushes the clothes against the basket and a little into the holes. this leaves little rust rings on your clothes.
  • lumpy816 is correct in saying that your basket should be replaced. it does require a special tool, and the basket is expensive.
  •  in the mean time try to take the clothes out immediately after the washer stops spinning. and if you get desperate you can clean thee inside of the tub with a rust remover like LCR or a strong toilet bowl cleaner that removes rust.
Jun 30, 2008 | Kenmore 24032\24036 Top Load Washer
Rust stains and bleach spots.
I'm sorry but the white spots will be due to bleach. It may be that there was undissolved bleach in the washer after the first load. Maybe some of it came out with the whites and lay in wait in the basket.
I doubt the makers would guarantee anything for 7 years, so no free basket or installation is likely. Seems there is a chip in the enamel and dampness / water from the previous wash days before sits there collecting iron as rust particles.
For the time being you could try rinsing the machine out before the first load. That might prevent the rust marks or reduce them.
May 01, 2008 | Kenmore 22422 Top Load Washer
Rusty dish rack
Clearly a design or manufacturing flaw. I have the same model and the rack is disintegrating after 6 years. I believe it is a manufacturing flaw. Our previous dishwasher rack lasted over 20 years in the same conditions. Same construction, vinyl covered steel. New upper and lower racks cost over 200.00 and there is no guarantee that this won't happen every six years. I recommend a new non-Maytag dishwasher as soon as you can. Meanwhile, limp along with the defective racks.
Oct 02, 2007 | Maytag MDB7100AWB Dishwasher
Rust in tub
Unfortunatly, this happens every now and agian. Sometimes a button or something will pop a piece out of the porcelain, then you have rust. The problem is, the companies will tell you (which you have probably heard a hundred times already) that if its out of warranty, its not their problem. Other than that. Unfortunatly, out of the few we have delt with, most of our customers either try to find a lawyer or replace the drum. Havent heard anyone being successful in getting satisfaction from a lawyer. Sorry, believe you me I know how you feel. The old saying "They Dont Build Them Like They Used To" really does work now-a-days. Good Luck to you. Jim
Sep 07, 2007 | Whirlpool LSR7333 Top Load Washer
Wasing machine leaves rust spots on clothes.
check the basket of the machine for rust spots on the basket if thats the case the basket should have a 10 year warranty depending on the age marks are either caused from that or the dryer. if its frigidaire the dryer then the front seals probably need to be changed make sure to find out exactly which machine its coming from
Mar 18, 2007 | Kenmore 22422 Top Load Washer
Dishwashers Logo
94 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
