Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
Purge bulb staying collapsed and not filling up
  • 906 Answers
You need to clean the carb system and maybe replace the bulb.
Posted on Jan 25, 2015
Echo 260 hedge clipper not showing gas in purge bulb -won't start.
If you cannot get bulb to fill then something is wrong with the valves inside the carburetor. That is not a repairable item.- you need to get new carburetor.
Aug 25, 2017 | Echo Garden
My 2004 Hyundai sante Fe will not start after gas fill up, I need to hold gas pedal down and feather the pedal till it stays running.
purge valve solenoid/ purge vent/ purge canister... NEVER TOP OFF GAS!!! ruins evap system and activated charcoal from purge canister enters lines clogging purge valve solenoid, problem often causes fuel nozzle to "click" multiple times while fueling
Dec 22, 2016 | Hyundai Santa Fe Cars & Trucks
Will not start. Bulb will not fill with gas. Hw difficult is it to fix?
Difficult to answer your question as the fault with the purge bulb could be a stuck, missing or damaged valve or a fuel blockage.
You don't say how old the unit is or how much use it has had.
I suggest you begin by removing the inlet pipe and filter assembly from the fuel tank and ensure it is clear and undamaged. If that is found to be ok I suggest you suspect the none-return valves of the purge system.
Apr 29, 2016 | Garden
When I pump the primer bulb, why doesn't it fill with fuel and stays collapsed?
new carbies start around $25.00 us on e-bay so get a new carby
take it to a mower shop for a service
rebuild the carby using a new carby kit
Nov 28, 2015 | Husqvarna 125 Bvx Leaf Blower Lawn Yard...
Why does the engine only run at full choke?
You're not telling us anything about its history or other symptoms. Given that, it's got fuel delivery problems, to possibly include: clogged fuel filter, cracked or collapsed fuel line, leaking purge bulb, clogged carb screen, stiff or leaking carb diaphragm or loose carb mt bolts, for starters. Replace lines, bulb & filter & rebuild carb first, in that order. Pay close attention to fuel line routing- take pix. You'll need a special tool to adjust carb mixture- Husqy carb tool
Jul 08, 2014 | Poulan Pro Chain Saw 46cc 20"
Canister purge solenoid stays on
Have you made sure your ground wire for the vehicle is firmly attached?
Nov 30, 2013 | Ford Cars & Trucks
Weed Eater PE550 711431, new primer bulb will not pop back after second second push.
FIXED- No start Weed Eater with the symptom of the primer bulb collapsed, not filling nor returning to pop out after pressed.
Worked in model WT-3100 with Walbro carburetor WT-583 and has to work in many others. It happened after winter hibernation, even when left with no fuel to prevent formation of fuel deposits.
FIRST, mark/scribe the carburetor fuel outlet that has the hose towards the primer purge bulb as 'OUT' and the fuel inlet coming from the fuel tank 'IN'
The problem was a fine mesh metal screen strainer blocked by contaminants, inserted at place shown as number '3' in figure 7 at
----> www.drystacked.com/Walbro%20Carburetor%20Theory%2027Jun2010.pdf
That fine mesh was removed by prying its edges around with a sewing needle held by pliers.
It you cannot see light trough it holding it against a lamp, is blocked even if looks clean.
Removed, discarded, reassembled and started. Later ordered the part or kit but was able to use the machine immediately.
Writing this as am tired of seeing responses like 'may be this' or 'try that' or 'perhaps the other' by guessers.
Aug 07, 2013 | Poulan Garden
Not getting fuel replaced primer and hoses and not
It's easy to mess this up as I've done it in the past. If the unit has an external purge bulb, the fuel line from the fuel tank that has the fuel filter on it goes directly to the carburetor...near the part of the carb that holds the fuel pump and has the grooved cover (where an inbuilt purge bulb would be). The other line coming out of the fuel tank goes to the purge bulb. The side of the carburetor that has the diaphragm and metering lever cover has the line going to the purge bulb. Remember, this is not really a primer...the purge bulb pulls air and old fuel out of the carb and when it does this, fresh fuel flows into it...and then the bulb pushes that air and old fuel back into the fuel tank. Hope this helps.
Jun 13, 2010 | Craftsman 25cc Gas Line Trimmer
Routing of fuel lines for a weedeater bv200 type 2. Which lines go where from the carb into the tank?
The line with the filter goes to the bottom of the carb. The other line goes to the outlet side of the primer bulb and the other line from the primer bulb goes to the top of the carb (The primer sucks gas through the carb).
Ps. if you are not sure which nipple of the primer is the outlet port then put your finger on one of the ports and push the bulb. If the bulb stays ridged then that's the outlet and if it collapses but doesn't fill but up then that's the inlet side.
Jul 10, 2009 | Garden
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
35 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
