Question about Brookstone Park It Electronic Parking Guide Valet
Parking valet operates intermittenly
The valet only works intermittently. Have changed batteries and even plugged in to an outlet.
Cant get the key to turn in the door lock
You may be trying with a valet key.
Valet keys usually can unlock the driver's side door and start the car, but can't unlock the trunk or the glove box. This key is normally used when someone else operates your vehicle, such as a valet parking attendant.
Aug 28, 2016 | 2008 Audi TT Coupe
Hi, I have a 2006 650i The display unit intermittenly goes blank shutting off the radio etc just leaving the BMW logo showing, then after about 10 minuets returns to normal
Short to power. Could be as easy as just pulling a fuse and reinsert it. Sometimes you have to access the plug and do they same thing. Sometimes you have to fix or replace the plug. If your display is the radio, It could be internal radio problems..
May 28, 2016 | BMW Cars & Trucks
Parking light and information light on
Patients and visitors may park in the Dogwood Parking Decks or the Ambulatory Care Center parking lot at a cost of $1.25 per hour or a fraction thereof, to a maximum of $8 for a full day. Parking for patients visiting the UNC Family Medicine Center is located directly beside the front entrance of the center.
Valet parking for Emergency Room patients is located outside the Emergency Room main entrance. One vehicle per patient is allowed in the lot. You must request a parking permit from the Emergency Department security officer or the admitting receptionist in order to park here. Vehicles parking at the Emergency Room and not transporting a patient are valet parked at $10.
Valet Parking is available to all patients and visitors at the N.C. Children's Hospital entrance. The cost for valet parking is $10 per visit. Valet discount coupons are available from the attendant at $45 per book of five.
Handicapped Parking is available for up to four hours in any of the handicapped parking spaces located across from the N.C. Memorial Hospital entrance. Additional handicapped spaces are located in the Dogwood Parking Decks. Handicapped-accessible shuttles service these spaces. If you need assistance from the parking deck, please contact the attendant via the call box phones.
Mercedes Parts.
May 25, 2012 | 2000 Oldsmobile Alero
The port where power cord plugs in works intermittently making it difficult to charge battery
A quick and easy solution is to take the battery out, and restart computer with the plug in.
Another solution is to either change the outlet or get a new powercord.
Nov 27, 2010 | Computers & Internet
Have had a Dei valet 561r remote on my Honda van for several years. Worked flawlessly. Recently, it began working intermittantly. Did not work for several days. Then worked for about a week. Then nothing....
sounds like your car battery was also replace or it die
believe it or not the remote start needs to be reprogram again
find the valet switch, this what you are going to do
make sure ac radio and any other accesorie are off
start the car with the key within 2 seconds or less press and hold the valet swith, and way until the
led turns on and the parking lights on the vehicle flash about 12 seconds
no turn off the car close the door and start the vehicle with the remote good luck
Nov 19, 2010 | Directed Dei Valet 561r Remote...
Nissan sentra 2002 engine goes off intermittently even when driving
check the air box if it is not closed right it will cause the motor to turn off intermittenly or idle rough, its getting to much air to fuel mixture
Jan 11, 2010 | 2002 Nissan Sentra
ELECTRICAL POWER DOES NOT SEEM TO WORK EVEN THOUGH PLUGGED IN
Try another outlet in your home. Or if it is plugged into a surge protector remove it for the surge and plug it directly into another outlet
Jun 11, 2009 | HP Compaq nc8000 Notebook
GARAGE DOOR OPENER WORKS INTERMITTENLY
Check to make sure your door sensors are properly aligned. They each have a small light and both lights will be on if they are aligned.
Jun 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to turn the valet switch off On 1999 Nissan Maxima
Look for alarm Brain box and look for wires coming out black and red going to valet switch. to turn valet on turn ignition in ON position and press-switch or flip depending on the type of switch. If it a basic alarm just disconnect the main wiring harness to alarm box- unplug and the car should start. Good luck and thanks for using FIX YA
Jan 26, 2009 | 1994 Nissan Maxima
Security system not working as it used to
i read this on the subaru tech bulletin page
i had the same problem - apparently i had inadvertently put the system into "valet" mode
to get back to normal, unlock with remote - open drivers door - hold down the unlock button on your remote for 2-3 sec - the flashing light will go out and your system should be back to normal
it's too bad the manual doesn't supply information about activating and deactivating "valet" mode
good luck
Oct 13, 2008 | 2001 Subaru Forester
Brookstone Park It Electronic Parking Guide Valet Logo
Top Brookstone Home Security Experts
Lawrence Oravetz
Are you a Brookstone Home Security Expert? Answer questions, earn points and help others
