Question about Salton Kitchen Appliances - Others
Salton ice machine makes just small amount of ice
SOURCE: icemaker making small amount of ice
I RESET THE SWITCH ON THE ICE MAKER AND TURNED THE TEMP TO 9 FROM 5 AND IT STARTED MAKING MORE ICE. I'M NOT SURE WHAT WAS WRONG BUT IT APPEARS TO WORKING FINE NOW.
Posted on Dec 05, 2008
  • 71 Answers
SOURCE: Ice maker is leaking small amounts of water.
Is the amount of water to much for the tray size , you can adjust it with the small screw behind the icemaker cover . is the line entering the back of the icemaker jammed up to far causing it to spray ? Or is the icemaker or refrigerator not level
Posted on Dec 14, 2008
cdarnell89
  • 16 Answers
SOURCE: small production of ice? What should be the normal production of ice?
A KM-450 MAB at 70 air and 50 water will produce approx. 460 lbs. cycle weight should be 10.4 lbs. per batch this is of course in perfect cond. time to make is 30 min. freeze and 4 min . Harvest. To give you the worst case scenario 100 air 90 water you drop to 340 lbs. cycle weight is the same but time to make is 32 min. 3.5 harvest. If you have more ?s I have included the link to the Manual for this unit.
http://www.hoshizakiamerica.com/techsupport/tech.asp?
Posted on Jun 23, 2009
  • 52 Answers
SOURCE: My Kenmore freezer won't make ice. I can feel a
water supply must be checked first, constant flow to the area confirmed. compreesor running? does the system reach temp in other compartments? Isolate system from the electrical supply pull away from the wall and clean behined unit clean coils and fan blades.
check tube for water still connected and return unit power supply. let me know what you have temp in fridge and freezer if this unit is duo.
Posted on Jun 24, 2009
  • 10865 Answers
SOURCE: Ice maker is not making ice
hello. i can help.
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Small or too few ice cubes If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly.
Posted on Jun 25, 2009
Slow ice production
If your unit is making ice and is not shutting down on any faults then you need to check to make sure the condenser coil is not dirty or the air filter. also where is the machine located? If an ice machine is sitting in a warm to hot location then the slower it makes ice.The cooler the air around the unit entering the condenser coil the faster it will make ice.
Feb 13, 2014 | Scotsman Kitchen Appliances - Others
Our ice machine does not make full ice cubes. they are small and not complete, they are full of holes.
The icemaker requires a water pressure of 1.5 - 8.5kgf/cm2. It is acceptable if the water supply fills a cup of 180cc with water in 3 seconds. The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Nov 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Small production of ice? What should be the normal production of ice?
The way I understand how Hoshizaki machines work, the model number is usually what the unit will produce, in pounds of ice. Their manual states: "Approximate production/ 24 hours @ 70 degrees air/ 50 degrees water (incoming)" So, yours should be producing 450 pounds a day, approimately. Since I can not pin point your exact model, I found one that is close. It states: "Ice Production per cycle: 6.6 pounds, 360 pcs." Again, it is not you exact machine. Their web site does not show this model either. So this is the best info I can get for you. Hope this helps.
Jun 03, 2009 | Hoshizaki Freezer Commercial Ice Machines...
The bowl doesn't freeze in my freezer.
The noise you hear from you machine is provably just the mixer but not the compressor the bowl and the mixer has different cooling systems to check the you got to see your contractor kicking in when you activate the dispenser handle. reply to Art after check that
Apr 08, 2009 | Salton Ice Cream Makers
Need info how to use
You can use a filter if you desire, or if you like finely ground coffee. A normal filter, flattened-out and a small hole torn in the middle will fit into your basket.
Amount of coffee depends on the quantity that you're making and how strong you like it. Suggested amount is 2.5 cups for a 45 (or 42) cup urn, I personally, use 3.5 cups.
Sep 19, 2008 | Salton Melitta MEU45 Stainless Steel -...
Salton model GL14 Ice Cream machine
For all of the above, you will need to contact Salton directly, as they no logner post the info on their website:
3633 Flamingo Road
Miramar, Florida 33027
Phone 954.883.1000
Jul 18, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Salton ice maker model IM-2022 bought this on Saturday, no other canadian tire in the region has any left, and will not be getting any more this year. ice make cycle is normal but no ice is...
I have the same ice machine wich I had received w/o instructions. After almost giving up I stumbled on the Polar PIM9W on http://www.greenwayhp.com/index.php/ice_makers/details/pim9w/ which had all the info I needed to start using my machine. I'm sure they can help you figure out your machine seeing as they have an identical one. Hope this helps ya making ice =)
Jul 10, 2008 | Refrigerators
Salton hand crank big chill ice cream maker
I bought one new, and it had a great recipe for Kiwi fruit ice cream, using kiwi fruit and oranges. I can't find the recipe book. You make just over 1 l of fluid ice cream mixture, the bowl must be pre=frozen for at least 15 hours, just put the liquid in the machine and crank the handle in quarter turns (the square outer box helps measure this!) every 5 min for the first 30 min, and then half turns every half hour or so.
Jul 06, 2008 | Salton ICM15 BIG CHILL 1.5 Quart Ice Cream...
Salton ice cream maker manual
I downloaded a manual for the ICM21, same picture as yours, today, August 2009, from kitchen.manualsonline.com
Click on frozen dessert maker under Member Contributed Manuals.
Click on Salton frozen dessert maker
Scroll down to Comments, get this manual
Click on instructions
Salton ice cream maker pdf
The one there is for the old ICM21 ice cream maker.
Jan 16, 2008 | Salton ICM-21 1.5 Quart Ice Cream Maker
Kitchen Appliances - Others Logo
32 people viewed this question
Top Salton Kitchen Appliances - Others Experts
Gareth Cockram
Gareth Cockram
Jerry Greenberg
Jerry Greenberg
tsalagi152
Are you a Salton Kitchen Appliances - Other Expert? Answer questions, earn points and help others
