Question about Dishwashers
Have part 055 400 046 cap on end split. any idea of its name
How fix a gas line break at gas tank?
Using needle nose pliers slip the split line off the connection and pull out of the gas tank. If there is a filter on the end you need to extract through the gas cap opening. Purchase another gas line either in a repair kit or individual line and cut to fit. If the filter is bad, use a new kit. Insert through the gas cap opening and pull up through the supply line opening. Be sure the connection is clean then slip the new line onto the clean connection.
Sep 12, 2014 | Craftsman WeedWacker Gas Trimmer 29cc...
Red screen LG 32LC2R
Maybe Bad caps in power supply,Crack or splits on top of cap or leaking, Check value of caps in power supply.
Feb 04, 2014 | LG 32LC2R 32 in. HD-Ready LCD Television
I am looking for the radiator cap location on the 2007 malibu.
A lot of the newer cars don't have a cap on the radiator anymore. The manufacturers decided to move it to the overflow bottle, which I think is a stupid idea. Should the bottle split, you lose ALL your coolant, then cook the engine, as opposed to just losing a little bit of coolant.
Aug 27, 2011 | 2001 Chevrolet Malibu
The problem of my unit carrier split type air-condition are about capacitor because i can't determine the voltage and wattage its all erase so i need your help to determine the details about this kinds...
it doesnt work that way. If the cap is metal it is a run cap, if its plastic its a start cap. I need to know the compressor name and the model number and I will tell you what to buy. Hope this helps.
Jul 08, 2011 | Carrier 38CKC042 Air Conditioner
How do you take wires out of distributor cap
Hello Vinny.
The end of the wires have a split type clip that expands when you push them into the cap.
To remove them properly you need to remove the cap and squeeze the clips in gently and tug the wire.
If you are changing the wires it would be a good idea to replace the cap and rotor at the same time anyway.
If you would like further assistance with this question, please ask me in comments. Be glad to help.
Thank you for using Fixya.
KL
Feb 04, 2011 | 1985 Dodge Aries
My Ion Contour Lp only records one track of a album but if i take the tick out of the box that says split tracks it will record the whole side,it shows up in itunes as temp 1 or 2 but not the artists name...
i had a similar problem, itunes/EZ hung after trying to split the first rtack. maybe you have the same problem?. its fixed by downloading latest version of ez software
I have a second problem. the noise from the pickup ( actually on the turntable ) is very high . I can easily hear the lps playing off the needle!! this results in very poor quality recordings. any ideas?
Dec 15, 2009 | Audio Players & Recorders
Mechcanical clutch not disengaging
LEVER INSIDE TRANS FROM SHAFT TO RELEASE BRG IS SPLIT. TAKE GREEN CAP ON END OF TRANS OUT TO ACCESS REL BRG & LEVER
May 21, 2009 | 1995 Volkswagen Jetta
Safco Drawing Clamps Missing End Caps
go online type in lids or container tops, screw ends, and the size you need and see if you can get any hits or
if you know the manufacture name of product than type in there name and replacement parts
rod
Feb 26, 2009 | Safco Telescoping Document Tube, Expands...
Dishwashers Logo
15 people viewed this question
Top Dishwashers Experts
