Question about Canon PC-735 Copier
Canon pc-735 paper jam
Paper jam light won't go off won't feed paper
SOURCE: paper jam light constantly on.
The suggestion with the heavy stock paper worked. I used a vanilla folder but this was not heavy enough so I simply folded it in half. I had the problem where it would feed 1 sheet of paper in the auto sheet feeder upon starting the printer up. This is unusual in itself. The single sheet of paper would go through normally. But with the vanilla folder, as it was going through, I heard a loud sound like a contraption somewhere was being reset or dislodged or relodged or relocated from some stuck position. After the sound, the green light came on no problem and it all worked. Try something not so heavy like a vanilla folder that has been trimmed down. Then fold it. You might have to hold it up against the black roller wheel to get it to engage the roller wheel when you turn the printer on. Hope this helps.
Posted on Aug 25, 2007
  • 24 Answers
SOURCE: canon ip90 printer
The printer should be on,remove the paper from the printer(if there is any),press and hold the down arrow/cancel button, release the button when the power light blinks 3 times ... The printer will rollers will automatically revolce and clear all the jams.. When the power light is green then repeat the same step 3-4 times.. To confirm the paper jam is cleared then feed 8 1/2 * 11 paper in the printer and again press the down arrow button and release the button once the power light bliks for 3 times and then release the button. If the printer feeds properly it confirms the hardware of the printer is fine.
Software issue: Go to printer and faxes in computer and check the icon. If it says.. 0 paper jam then, delete the icon and chcek in the device manager if there is an entry of usb printing support under Universal Serial Bus controller .. if the entry is there then delete it. Insert the printer cd in the computer and unplug and replug the usb cable from the printer. If the setup screen comes up then exit out of it and the printer drivers will get updated. After that tried to print another tets page from the computer. It will definately print. Thank you.
Posted on Jan 22, 2008
  • 199 Answers
SOURCE: Canon ip1800 will not feed paper...One side jams
canon has a friction feed system,
clear the paper path and check if there are any small paper peace,
clean the pickup roller by a waterized cloth,
proper set the paper guide and try print again.
Posted on Jun 25, 2009
SOURCE: canon pc 420 paper feeds only part way
I had the same problem. I found a parts diagram here http://techno-parts.org/canon/220/320_220.php which showed that the springs hold the bar down. On mine, on each side, one of the spring tabs was broken.
I made a metal pin for one side and insert a screw on the other. Be sure and wrap the spring over the nylon bushing.
Posted on Apr 04, 2010
SOURCE: Paper wont feed into printer no paper jam
In the comments section Blumm suggests pushing a piece of cardboard (like the back of a legal pad) through the feeder as far as you can. Turn the printer off and then on again with it in there. Pull the cardboard out and check for any foreign objects that have been pushed through.
It worked for many people including myself - I got a piece of plastic and it works wonderfully again!
Posted on Jul 31, 2010
The paper won't feed and the paper jam light goes
Wich copier model do you using?
My wild ques would be paper feed rollers. Try to clean them with alcohol and try to copy.
But still I would want to know the model.
You can also contact me on emma.servis@gmail.com, if its Canon copier.
Jul 17, 2010 | Canon Office Equipment & Supplies
Paper dosnt feed in printer pixma mp210 photo. HELP
Either paper jammed, stuck by foreign object or DRIVE ASSY faulty.
May 25, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Canon MX310 keeps not printing and message comes up paper jam sometimes nothing happens sometimes startes to take paper then stops sometimes just feeds through without printing , there seems to be no real...
Have you ever tried printing sticky labels in the thing? You have to be careful with those because sometimes a piece will come off and stick in the corner of your printer. If you don't have long surgical tweezers to pull it out, you could be looking at an expensive repair. Also check your manual. There are two places the paper can jam in. You might have checked only one. I have a different Canon model but on mine I also have to make sure the correct light is on. Is the light for feeding from the back on, or the light from feeding on the front? If you have the same light, press it again to change the place where it will feed from.
Make sure your paper isn't curled or that you're using paper that's too thick also.
Can't answer more because I don't know what program you are using to try to print.
Sep 24, 2009 | Canon PIXMA MX310 All-In-One Printer
The jammed paper light cames on and there is no paper jammed it does not feed paper for copy
There are two ways the progress of a sheet through the machine are monitored; either photoelectronically or via a 'flag' that is pushed out of the way by the paper as it progresses through the machine. These flags also use photo sensing but if a flag is broken by someone stabbing stuff into the paper path (seen a lot of that), the flag won't reach the paper so the machine thinks there is a jam.
Sep 23, 2009 | Canon PC-735 Copier
Paper jam lights despite no evidence of a jam.
prior to the issue ,basically is your paper path sensor .1)firstly try to check all the sensor lever ,it must be at home position .i guess one of the paper path sensor lever activated paper present.this usually happen when removing jam paper incorrectly causes the lever sensor spring came off .2)it can also be the clutch and solonoid rotation timing issue.good luck ,pls rate me if u satisfy wih my clarification.!!!!!!!
Sep 08, 2009 | Canon PC-735 Copier
Canon PC-745 stopped working.. paper jam light
Sooner whole in трее there is what that subject , can broken part or scrap of the paper. Open and see attentively, in that place, where paper sticks. I for its work so much took out stranger a subject(
Sep 05, 2009 | Canon Office Equipment & Supplies
My Canon PC735 copier turns off after it grabs the paper.
Main lamp is most likely burned out or is shorting.
You can google it and find a replacement bulb. Not too difficult to replace. Remove the top cover and glass. Make sure your hands are very clean or use a clean cloth to handle the new bulb.
May 15, 2009 | Canon PC-735 Copier
Canon PC-735 Copier Logo
73 people viewed this question
old marine
old marine
