Question about Amana Freezers
Turn on sabbath mode - Amana Freezers
How do I turn the Demo mode off of my GE Upright freezer so my food will freeze
Lisa, you may have to contact the store where you bought it or contact GE. I looked all through the manual a couple time and nothing found on Demo mode. Check the attached links to contact GE for info., last link is USA. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Home GE Appliances
Contact Information
http://products.geappliances.com/appliance/gea-literature-search?Ntt=FUF20DURWW&x=10&y=9
Apr 12, 2016 | General Electric Upright Freezer...
STAY IN DEFROST MODE
Hello Santiago;
My name is Peter. I am a retired field service refrigeration technician.
In the defrost mode everything shuts down with the exception of the light.
So, lets trip the defrost timer and get your freezer running.
You did not provide a model number which is located on a label on the inside liner wall near the top.
Your defrost timer may be part of your control board.
Let's assume it is not.
In the lower back left hand corner of you unit the is a metal plate with a small slotted shaft. With a large flat head screw driver turn the shaft clockwise on click at a time until your unit starts up. You must do the same thing every 12 hours to turn it off for 30 minutes to allow for defrost until the timer is replaced is replaced.
25570632-zjnlddqc4npjcfhwullt2vwq-1-0.jpg Note the round on the left.
Go into the following web site, put in your model number. Select the diagram with the defrost timer. Search the internet with the part number shown
Water Filters Lawn Garden Appliance Parts
Mar 14, 2015 | Everest Refrigeration Freezers
Freezer and frig not coo0ling. Blinking red lite in freezer. Sounds like fan or motor running. We had a storm come thru yesterday. we have electricity on the appliance.
It sounds like you have one of two issues there. Maybe you need to turn it off and wait for 10 minutes for it to reset (compressor has "vapor-locked" and the freon is not able to circulate through the compressor). The other option to try is that the refrigerator has entered into "demo" mode. This is the mode that it is usually put into in stores so that the compressor is not running, but all other things work for demonstration on a showroom floor. A voltage spike might have shocked it into the demo mode and will work in all ways except for a blinking light indicating the demo mode as well as no compressor activity to cool anything... Look in your operator manual to see if they mention the demo mode and how to enter and exit it.
Hope that helps.. I have seen both of these situations though.
May 29, 2014 | Kenmore 26.5 cu. ft. Side-by-Side...
Door Panel not working along with inside lights
check your owners manual to ensure it is not in the sabbath mode. if this is ok their could be a low voltage board problem behind the display or high voltage board in the rear of the refrigerator. unplugged the refrigerator before proceeding to repair it.
Nov 10, 2013 | Maytag MFI2269VEM 22.0 Cu. Ft. French-Door...
Freezer keeps beepimg
if the temp. in the refrigerator side is 20f, its to low, set the ref. to 40f and freezer to 0f.
Sep 23, 2012 | Liebherr CI1651 30" Built-in...
I can not turn on the freezer, It just keeps on blinking. It is a stand up freezer with the controels on the top of the door. Lost my manuel. It is suppose to go to -3.
Its stuck in defrost mode, find the defrost timer at the rear of the unit down near the compressor, turn the small dial clockwise and it should fire up, if so, spray that dial with lub and rotate it a few times. hope you get it sorted. Russ
Jun 27, 2011 | Freezers
Hoshizaki KM-900MAH Ice Maker it sounds like it is making ice and is freezing it but its not dropping ice any solutions?
when the machine first starts, it begins it's cycle in the harvest mode. If the float switch is stuck, it stays in the fill/ harvest mode. Compressor runs and water circulates but no ice is being made. I'd start looking there. Turn the machine on, let it run for about 3 minutes, they very lightly tap the float switch. If it starts making ice, bingo, theres your problem. Let me know if I can be of any more help.
May 12, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Turn off ice maker
OK I just figured out this must be a european model refrig!
i'm having trouble finding an owners manual in english so looking at the manuals that are in spanish it looks as if there is an on off switch on the 6th sense board. if i'm correct its the icon right above the mode button has picture of one cube next to picture of 3-4 cubes. sorry i led you on a wild goose chase. thx peyton
Jan 26, 2009 | Freezers
Freezers Logo
65 people viewed this question
Top Amana Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Gil Shultz
Charles T Nevin
Charles T Nevin
Are you an Amana Freezer Expert? Answer questions, earn points and help others
