Question about Intermatic R8806P101C - Sprinkler-Irrigation Timer - 14-Day Skipper - NEMA
How do I turn the system OFF - Intermatic R8806P101C - Sprinkler-Irrigation Timer - 14-Day Skipper - NEMA
I have a RCA sound system with an hdmi port to plug into TV but the sound system will not turn on the tv will but not the sound system is there a fuse in the sound system to make it turn on that may have...
So to clarify, the T.V. turns on but the system doesn't turn on with it? Most external sound systems have their own and separate power supply. You will need to turn it on as well as the T.V.,
Elisa Jed ' http://www.fordtronicvideo.net.au/about-fvs.html
Apr 20, 2014 | Televison & Video
How do i disable windows restore
Steps to turn off System Restore
  1. Click Start, right-click My Computer, and then click Properties.
  2. In the System Properties dialog box, click the System Restore tab.
  3. Click to select the Turn off System Restore check box. Or, click to select the Turn off System Restore on all drives check box.
  4. Click OK.
  5. When you receive the following message, click Yes to confirm that you want to turn off System Restore: You have chosen to turn off System Restore. If you continue, all existing restore points will be deleted, and you will not be able to track or undo changes to your computer.
    Do you want to turn off System Restore?After a few moments, the System Properties dialog box closes.
Jan 11, 2011 | Microsoft Windows XP Professional SP3 Full...
Lenovo Ideapad Y510 won't turn on or off
try removing the battery and removing the adaptor press and hold down the power button for 5-10 seconds then let got this will power drain your system board noy turn the system on using the battery only without any adaptors to charge or power the system, try turning the system on if the system turnes on leave it turned on for a couple of hours then conenct your sysem adaptor monitor if the battery light and the battery indicator on the lower right of the screen in windows woll indicate that the system is chargin if it is then I believe everything should be fine the blue indicator is for your system if it is blue then your system is turned on and has power if it turned orange and blnking then the battery will be more likely be almost out of juice or may need charging.
Jun 23, 2010 | Lenovo IdeaPad Y510 Notebook
My ps3 wont turn on i tryed to turn it on but it just turns rite back off how do i gett it to stay on
It seems that your ps3 is experiencing the yellow light of doom:
Try this: 1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
Jun 14, 2010 | Sony Playstation 3 (PS3) Console
I have broken.openco after scanning with malware bytes. i have scanned several times with this but keeps comming back how can i get rid of this?
Try to download and install AVAST antivirus Home Edition. It is free. Besides, avast has an option to scan at boot time so it can detect and delete viruses and malwares before they can cling to your system memory. You can download it here.
Jun 06, 2010 | Computers & Internet
Systems properties,click on system restore.the display says:drives c & d turned off.but you cannot turn them on from this box that you are on [system restore] please why? & how can i change this to...
to get to the system restore for sure ..get to the control panel ... be sure it is switched on category view...and than click the maintenance and performance...in this moment in the left side task bar you will have the initiation of the system restore......BUT!
if the system was turned off until now..you will not have any previous point to get back to ..so ..what you have to do is turn in on and you will have a point from now on...and a point will be made each time you install or uninstall anything ..
you can also turn the system on ...by right click on my computer icon...choose system restore...and uncheck the case that says turn off he system restore..I actually believe it will be possible to turn it on from both ways..
Have a nice day ..and dont forget to rate ...!
Apr 24, 2010 | Computers & Internet
Volume is too loud
change the function to cd or aux before you turn it off and then change the volume before going to your preferred function. It is the only way around it.
Mar 16, 2009 | GPX HM3817DT Shelf System
It says file system error when i try to turn it on then it automatically shuts off. what can i do to fix the error?? It says File system error when I turn it on and then it turns itself
it says file system error when i try to turn it on then it automatically shuts off. what can i do to fix the error??
Nov 26, 2007 | Creative Labs MuVo V200 MP3 Player
Turning off the system
Demo mode is on. Read the user manual,there's suppose to have a "Demo" button on the unit. Press the button after you put the set in standby.
Dec 08, 2006 | Panasonic SC-AK630 CD Shelf System
Intermatic R8806P101C - Sprinkler-Irrigation Timer - 14-Day Skipper - NEMA Logo
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
