Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
My chainsaw starts up runs good a few seconds and dies like its out of fuel which it is not
al_kupchella
  • 843 Answers
SOURCE: I have a Poulan 14"
Inside the fuel tank, there is a small flexible fuel line with a float (or sinker) attached. The float (or sinker) is supposed to keep the end of the fuel line submerged in the fuel. The float (or sinker) may be detached, or stuck, or it may be saturated and won't float (if it's the floating kind).
Good luck, Al K
Posted on May 20, 2011
  • 2239 Answers
SOURCE: runs for a few seconds & dies
Fuel starvation, start by replacing the fuel filter in the tank on the end of the fuel hose, check the hose for cracks or slits.
Posted on Aug 21, 2011
SOURCE: Chainsaw won't start. Replaced carburetor, fuel lines, fuel filter, ignition module, spark plug. Using new gas and oil. Has good spark but won't pop.
try priming it mite work lol
Posted on Mar 29, 2012
  • 6468 Answers
SOURCE: Poulan Pro Chainsaw, PP3516AVX
is the cap vent plugged?
Posted on Sep 22, 2012
  • 743 Answers
SOURCE: poulan 2600 chainsaw. the saw starts ok but then
If the carburetor has been rebuilt that leads me to believe that there was an adjustment made. The problems that can be encountered is that we like to adjust the carburetor to reach maximum performance. However, this ends up blowing the engine since there is a prescribed RPM for each saw, which is probably around 7k rpms. Now, we don't have enough vacuum to draw the fuel. There is another important area to check though before rebuilding the motor, and that is the adapter, or gourmet, that goes to the engine from the carb. Inspect it for leaks...you can do that by taking it off and turning it inside out to see if you have any holes or simply looking to see if it is dry rotted. If you have a hole, you can get the Black Sealant RTV at Advance Auto and fix it since no company no longer supplies that part for the Poulan Chain saw. If the motor is blown, you can rebuilt it rather simply, but unless you had a good ring tool to put the ring in the cylinder, you will want to place the piston/ring in the cylinder prior to putting the wrist pin and snap ring on wrist pin to avoid breaking the ring. You will need a good vice to hold the chainsaw in place though. This can be done by leaving the piston out far enough to get the wrist pin in with one snap ring on the one side then place bearing in then slide wrist pin in, then be careful no to pull the cylinder head off too far and now place the last snap ring in...of course you will need some sealant on the head gasket first prior to all of this. The reason I am telling you all of this is because on a chain saw, you must be willing to go the whole way since one problem leads to another and the truth of the matter is that if you are willing to go the whole distance, you can get that saw back running perfect...make sure mixture is good even if you need to make up a new mix... Good luck.
Posted on Oct 03, 2012
Chainsaw won't start?
2 possibles
coil is getting hot and failing
do you have spark straight after it stops
is air filter clean
carby diaphragm or carby rebuild required
May 31, 2016 | Garden
Chainsaw will not continue to run
Their should be 3 to 4 Carb adjustments "L" for low "H" for high the "I" for Idle, adjust the screws till their all the way shut and 1/4 turns each till it starts up, but if it starts as you say it does just adjust the Idle speed.
Dec 31, 2013 | Homelite Garden
Poulan woodsman 2150 starts & runs for a few
This is fuel starvation, start by replacing the fuel filter inside the fuel tank, use a piece of bent wire to hook the fuel line and filter out of the tank, check the condition of the fuel hoses up to the carb, any signs of leakage and you will have to change the hose. See if this works before we go into the carb to locate the blockage.
Jun 09, 2013 | Garden
Starts but only runs for a few seconds. Can put choke back on, pull a few times and it starts again. Put choke in off position and it will run for a few more seconds reviving the engin then dies.
This is fuel starvation, start by replacing the fuel filter in the fuel tank, check the fuel hoses up to the carb for signs of leaking or cracks, if this does not help, then there is a fuel screen in the carb, it is situated ubder the fuel pump cover, this is the alluminium cover held with a single screw, you may be able to remove this cover without removing the carb, depends on the orientation of the carb on the machine.
Sep 21, 2011 | Poulan 14" Chainsaw
Runs for a few seconds & dies
Aug 21, 2011 | Poulan 14" Chainsaw
Husky 51 runs for a few seconds dies than when i open gas cap and put it back on saw runs a few seconds than dies
Check the fuel filter for plugging. Check the fuel lines for decay or other damage. If the cap vent was stalling the machine, removing it should allow about a minute or so of running before it quit again. Hope this helps!
Dec 14, 2010 | Garden
I have a husqvarna 55 chainsaw was running fine I was cutting a log then the saw just died checked and cleaned magneto. Now I get the saw to start and run but only for a few seconds then it dies.
it sounds like a small piece of dirt is in the main jet of the carb assuming you have good spark. you may need to remove the carb and clean it. if it has a float then the needle may be sticking especially if it had older gas in it over the winter as it gets thick and plugs up the fuel passages. good luck.
May 17, 2010 | Garden
Saw starts and runs for a few seconds (while warm) then dies like starved for fuel. Will restart with choke, but does same thing again. Sometimes it will run for a few seconds longer at full throttle, but...
Air filter clean?
Air filter port set for summer or winter ?
Check the fuel filter inside the tank to ensure that it is not dirty or hasn't fallen off.
Aug 16, 2009 | Garden
Chainsaw starts and runs fine for a few minutes
Try fresh fuel making sure oil and gas mixture is correct. Carb might need cleaning and adjustment.
Jul 26, 2009 | Garden
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
160 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
