When trying to connect a new phone to the unit a memory full message apairs.
SOURCE: Remove phone from bluetooth handsfree car unit's memory
Sorry but what do you mean by?:- 'The car unit will not allow me to use the colour previously used' It should be the phone with the memory and the search facility for finding your car headset device, not the device looking for the phone. Once you have searched for new devices and found the headset with a different phone, the headset will not be able to connect with more than one device and should lose the old phone connection.
SOURCE: VOICE RECORD MEMORY FULL
press and hold the voice recording button (located on the right side of flip up part of screen) the list of recorded things will appear after message that voice is saved, when list appears click Options (left button with - on it located on top of keyboard) and than scroll down and select Delete All than press OK button (located in the middle of cursor buttons)
SOURCE: transfer files into memory card
hello
for that you need to open message and then go to options nad over there you will find message setting
you have to change all incoming message come to you memory card not to your phone memory
SOURCE: AVH -P5900DVD /CD-BTB200 Bluetooth Connection
I just solved this problem myself. The key is to gain access to the function menu, which was grayed out on mine. On my stereo, I put in a DVD bypass, whish i had to turn on to allow the function key to work. If you do not have a bypass in place, then try setting the parking brake in the same way you do to watch movies on your dvd player.
SOURCE: MEMORY FULL !
you also have to delete from the deleted folder (or trash can) just like on a computer.
