Question about Krups Kitchen Appliances - Others
How to repair Krups 117 toaster
Toast stays in down position and burns.
  • 3 Answers
SOURCE: My Krups model 288 toaster won't always latch down.
You can fix this yourself by following these instructions. Unplug your toaster before proceeding!... Clean the toaster first. Turn the toaster upside-down and shake out the crumbs. Remove and clean the bottom crumb tray. 1. Unscrew the four Phillips head screws located in the corners of the bottom base. Remove the screws completely if possible. Do this over a cloth or newspaper - that way a stuck screw won't get lost if it falls out later. 2. With the toaster right-side up, pull off the wide toast lever knob. Do not remove the round adjustment knob (it will not come off from the outside) but make a mental note of what number (1-7) is showing at the knob's adjustment mark. 3. Carefully pry up the end of the case cover with the knob on it (don't pull on the "stop" button). When the knob's plastic shaft is clear of the circuit board, gently pull off the cover. 4. On the inner part of the circuit board you will see a black plastic "cam" surrounded by two sets of electrical contacts. Rotate the cam to open the contact points if necessary. Insert a thin nail file between the points and rotate the cam to trap the file between them, then scrub back and forth several times to clean the contact points. Do this for each contact on both sides of the cam. When finished, rotate the cam clockwise so it is all the way back down to it's original position. 5. To make re-assembly easier, remove the round adjustment knob from the cover by depressing the half-round shaft flanges inside the cover with your fingernails. 6. Re-assemble the toaster by reversing steps 1 & 2. Replace the knobs, making sure that the round one is in the same position you noted earlier before you push it all the way down.
Posted on Mar 27, 2007
Ian Prins
  • 11 Answers
SOURCE: toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Posted on Dec 06, 2007
SOURCE: when i push the lever down to make toast, it does not stay
no solution, problem, my lever (sometimes) will stay down, sometimes not, but it makes a loud "ractething" noise many times when the lever is pushed down>
best, randy
Posted on Dec 12, 2007
SOURCE: Type 119 Krups toaster; toast will not stay down.
replace the circuit board
Posted on Apr 25, 2009
SOURCE: toaster won't stay in down position
We opened up our toaster and scraped some baked-on crumbs off the top of the electromagnet that controls the carriage catch. When we closed it back up, it worked again.
Posted on May 10, 2010
Control lever will not stay down
Unless you have power switch on to the toaster, the level will not stay down. Ensure you have main power available!
If the unit is powered, check that the 'toast darkeness' level is set accordingly - it is this 'thermostat' that determines when to eject the toast: if you checked that you have power and that the darkness level is not set to zero and it still does not work, then it is time to get a new toaster! If not under warranty, it is probably not worth trying to get it repaired.
Apr 08, 2014 | Bodum 10709 Toaster
Krups toast supreme 4-slice toaster stopped working
The element has burnt out, IF you can get another it is worth repairing, IF NOT, then it is time for a new one.
Apr 13, 2010 | Krups FEA212-45 Toast Supreme IV 4-Slice...
Toaster won't stay in down position in order to toast - Cuisinart CPT-160 - although it will toast if I hold the lever down as it toasts
Dec 22, 2009 | Cuisinart CPT-160 Metal Classic 2-Slice...
My toaster will not turn off. I press the toast button, it does it's job and then pops up, but the heating elements will continue to stay on.
It sounds like the temperature sensor has malfunctioned. When the sensor reaches a certain temperature it opens the contact to the heating elements shutting off the toaster. If the unit is under warranty then take it to a repair facility for Krups. I would not allow anyone to use the toaster. If left on it could cause a fire. Take care, stay safe and good luck with your unit!
Nov 10, 2009 | Krups FEC212 Toast Supreme 2-Slice Toaster
I have a Phillips toaster. It has been working
it sounds like the magnetic coil which holds the lever down to the toast position has burned out. you probably can't get the part for repairing it as it would be too costly
Oct 04, 2009 | Kitchen Appliances - Others
Toaster will not stay down in toast position
uh, don't think there's a good chance, you could try to send toaster in for repair, but buying a new toaster is probably cheaper.
Nov 24, 2008 | Back to Basics TEM-500 Egg & Muffin...
Lever will not stay down on Krups 155 ToastControl Compact
No promises, but I had a similar problem with a Breville Clasic. Toasters these days use a solenoid (electromagnet) to hold down the toast carriage. This solenoid is usually soldered to the circuit board, and is reasonably big, i.e. 1/3 a cigarette pack.. on mine, because of repeated impact when the carriage is pushed down, one solder connection developed a haiirline fracture. This meant that most of the time it wouldn't stay down. I resoldered the connections and all ok.
Oct 02, 2008 | Kitchen Appliances - Others
Problem with jaipan toaster
the release mechanism contains a bimetallic strip that snaps open when a certain amount of power goes through it based on the setting. When cold, it should trap the toast loading lever mechanism. If not, it may be broken or bent. Don't work on it with power applied
Nov 21, 2007 | Krups 288 SensoToast Compact 2-Slice...
Kitchen Appliances - Others Logo
146 people viewed this question
Top Krups Kitchen Appliances - Others Experts
Mike
ArcFlash
Level 1 Expert
Oloyede Monsuru
Are you a Krups Kitchen Appliances - Other Expert? Answer questions, earn points and help others
