Question about Janome Sewing Machines
Bobbin winding The thread on the bobbins are winding very loose what is the issue? I'm using janome bobbins
  • 69 Answers
SOURCE: Singer 7444 trouble winding bobbin
It sounds like you don't have any tension on the thread when winding the bobbin. Make sure that you are running the thread through the tension disc on the top of the machine before going to the bobbin winder.
Posted on Mar 01, 2009
SOURCE: janome straight stitch loose
I don't know if this is the right answer for any of you, but thought I'd put my 2 cents worth in. Often this can be the bobbin in backwards. It needs to unwind a certain way depending on the machine. I've heard a phrase for this: Mind your p's and q's which means some wind off to the right like a q, others to the left like a p. Mine has to unwind one way then be slipped backwards into a little slot or it does that loose bottom thread looping and bunching someone here mentioned. It seems everytime I get that problem I rethread the top thread 100 times before it clicks again and I remember it could be the bobbin thread. Either your manual will tell you the correct way, or you could experiment and try one or the other. Once you figure out whether you're a p or a q, mark it on your machien somewhere to remind yourself.
Good Luck and Happy Sewing!
Posted on Apr 04, 2009
Mimito7
  • 128 Answers
SOURCE: machine will not pick up bobbin thread
Sounds like your needle is in too far and it not allowing the needle to go down far enough to pick up the thread.
Posted on Apr 20, 2009
  • 136 Answers
SOURCE: will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
Posted on Jul 04, 2009
  • 26 Answers
SOURCE: My Janome needle thread will not pick up the
Your Machine is out of time, you probably broke a needle or sewed over a pin. take the machine to your locsl deler to be re timed. about 90.00
Posted on Aug 06, 2009
Re Janome 7330 bobbin winding problem. Thread jumps out of the top guide when bobbin is winding. I've tried everything; different speeds, main spool upright,tightening the screw on the thread guide.
Take a look at this video. There are others too. That is a really unusual way and nothing like the Singers, and Pinnocks that I have used. If you want to see other videos, there are a few. Google 'Janome 7330 bobbin winding', and then click on the Video tab. Let me know how you get on?
How to Wind Bobbin on Janome
Dec 04, 2015 | Janome Sewing Machines
My Janome 3018 will not wind a nice tight bobbin. They are loose and spongy. This machine is brand new. I have double checked that it is threaded properly and the thread is in the correct place and
You are not exactly threading the machine when you wind the bobbin. So follow the directions for winding the bobbin, make sure the thread fits under the little revolving wheel, and make sure that the stitch part of the machine is disengaged.
Jan 01, 2015 | Janome Sewing Machines
How do you properly wind bobbins with mercerised thread or satin finished cotton thread?
are you using the same thread in bobbin as you are trying to sew with, I found that to be important. If this does not help I would contact customer service for the machine and ask them for advice.
Jul 19, 2017 | Sewing Machines
Bobbin not winding tightly
Consult your owner's manual. Possibly, you are not threading the bobbin winder correctly. The thread does go through a tensioner somewhere along the way that creates tension on the thread.
Janome MEMORY CRAFT 9700 Instruction Book Threading For Bobbin Winding
Or perhaps the tensioner is not working properly.
If neither is problem, then you can always pick up a stand-alone bobbin winder (Amazon, JoAnn's, etc) for ~$30. One brand is called Sidewinder. These bobbin winders are marvelous because you can wind bobbins without unthreading your machine. It also saves wear and tear on your machine.
Or take your machine for service.
Mar 28, 2012 | Janome Memorycraft 9700 Computerized...
The bobbin winds really loose and uneven and then gets caught up when I'm sewing. I've checked I'm threading it correctly when winding... seems to be worse with polyester and embroidery thread. Help!
You need to keep tension on the thread spool as you wind the bobbin to avoid this from happening. Also, is there a little tension device to take the thread around between the spool and the bobbin winder? Some machines have a little silver button tensioner purely for bobbin winding to keep the thread flowing smoothly.
But I always do the following anyway just to ensure a smooth bobbin. Take the thread from your spool, through the eyelet or tensioner, then back to the bobbin and put the tail end up through a hole in the top of the bobbin. Now put the bobbin onto the winder and click it against the stop. Place the curved handle of a pair of scissors onto the top of the thread spool and apply some gentle pressure to stop the spool from bouncing and jumping while winding off. Keep doing this through the winding process.
Start the bobbin winding mechanisim, its a button on my Janome 6500, yours might be a little different. HOLD the thread tail until you've got coverage over the whole bobbin area catching the starting point. Stop, trim the thread tail off top of the bobbin with scissors, then restart winding again. Watch as the thread winds and give it a nudge with your finger tip to the top or bottom so the bobbin winds evenly across the whole spool's width.
Best analogy here is when you wind the garden hose onto the reel, if it goes on all over the place you never get the whole length on neatly, but if you wind it on neatly in an even tight coil across the spool, then back again, then repeat, you get a tidy hose. But just wind madly, it all builds up in the middle, you can't get it all onto the reel, and it won't pull out nicely next time you need it. Same thing with your SM thread.
Polyester and silky embroidery threads will be worse too as they are silky, so if the thread hasn't been wound on smoothly and under tension, then it will "collapse" with gravity, then when you use the bobbin, the thread is going to be caught on itself, will feed unevenly and be stretched, then loose, giving you less than perfect stitch tension.
My other bobbin tip is store the bobbins in a plastic bobbin tray so they are lying on their edges and under a cover. Keeps them neater and they are less likely to unwind stray threads around your sewing cabinet if you store them on the spool pins build onto the cabinet door - and it keeps the thread dust free. But I do not keep thread on bobbins for long, prefer to wind a fresh one off a new spool when I start a project and can usually complete a garment with a 3/4 filled bobbin, use the remaining few metres for handsewing, then junk the rest. Then I put the thread spool that is left back into a sealed takeway container to keep it away from UV, dust and moisture.
I hope this assists you with your machine and certainly if this doesn't resolve the bobbin issues, then I'd suggest you visit your dealer and ask them to demonstrate the technique on your machine to see if there is a technical issue with it.
Apr 10, 2011 | Elna Xplore 8600 Computerized Sewing...
I have a Janome 10000 and I am trying to wind some bobbins so i can get started on a project, however the winder is winding the thread very loosely and I know it will just knot up if I try to use it that...
Double check the threading of the machine when winding the bobbin. Or as a last hope measure when winding tensiojn the thread thru you fingers just before its at the winder.
Derek
Jan 17, 2011 | Janome Memory Craft 10000
Janome MC11000 - my bobbin case becomes dislodged
My bobbin case was jumping all the time...had it in for repairs and would bring it home and even though the tech had attached a test sew piece with different colored bobbin and top thread I could not get it to sew without the bobbin jumping. I thought that he had lied about that being sewn on this machine...finally, I found that you should start with plenty of thread in your hand when threading machine...so that once you feel it click into the tension...DO NOT PULL the thread, it pops it out of the tensioner...just loosely thread and hold tension with your thumb and forefinger while using the needle threader.
Feb 14, 2010 | Janome Memory Craft 10000
Using Singer 7470 for the first time, and my bobbin thread is bunching terribly. There is a loud sound from the bobbin chamber, as if the mechanism is bouncing around??? How can I fix this bobbin issue?...
1. Take bobbin out and re-insert and thread.
If that dosen't work, try:
2. Take bobbin out and bobbin case, clean area and re-insert bobbin case and bobbin.
3. Re-thread the top thread that goes to the needle. (Sometimes the thread dosen't hook to the "Thread take-up"(page 6 on manual). It pulls the bobbin thread and the bobbing becomes loose inside the bobbin case.
4. Wind a new bobbin (Sometimes a bobbin might wind thread to lose) Do not wind thread to the edge of bobbin.
If that dosen't work, you should take it in to be serviced...Somenthing might become loose that only a technitian can correct.
Also check manual for troubleshooting.
Good luck.....
Chickiefl
Apr 15, 2009 | Singer 7436 - INGENUITY
Clear bobbin out of thread
Memory Craft has a bobbin winder on top of the machine.  It works beautifully, but wind it on slowly for better sewing function.
Jan 08, 2009 | Janome Memory Craft 9000 Computerized...
Bobbin winder has no tension
are you sure you have the thread over the right place? it should be from the spool to the small metal wheel on the top of the machine and nothing else, also make sure your using a janome or s-class bobbin ( also it should be a plastic bobbin if it loads from the top of the machine and not the front ) when i fill a bobbin i also start out slow sometimes keeping my finger loosley on the thread itself before it winds on the bobbin to give it more stability.
Sep 23, 2008 | Janome 8080 Computerized Sewing Machine
Sewing Machines Logo
12 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
