Lg through the wall air conditioner. turned on first time today but fan will not come on
  • 1 more comment
  • tclarensau Jun 19, 2009
    from one greek to another for 10 bucks I was looking for a more technical answer than worrying about the plug. This ac has worked on this setup for 3 previous summers. so put your thinking cap on and help me out
    Thanks
  • tclarensau Jun 20, 2009
    if I turn on the fan only nothing happens. If I turn it to cool the compressor kicks in and then shuts off I assume because the fan is not working
  • tclarensau Jun 22, 2009
    model# LT1230HR the brand is LG
  • 334 Answers
Ok, fan will not turn on. Need a little more, you have a fan blowing into your room, one blowing across your condenser, outside air, and your compressor. if you turn onto cool,what happens. If you just turn on the fan what happens.
Posted on Jun 20, 2009
  • 1 more comment
  • seth veloso Jun 20, 2009
    Ok, if you have a meter and a model number we can diagnose this thing. llet me know
  • seth veloso Jun 22, 2009
    Hey , click on the link below, it will bring up the service manual for this unit. The motor you need to look into is in the top left corner of the drawing. Let me know if you need a hand .
    http://www.lghvac.com/_common/_Fc_WebFil...
    Sergeant:
  • 321 Answers
Make sure you have the fan set to on and if it is set to on then make sure its even getting power,a power outlet may not be working. so try pluggin it in to anothor outlet[ run a exstention cord to see if its the power outlet.if it still not working return it for a new one and tell them it was not operating., or the company who made may help but im sure they would have you return for a other AC
Posted on Jun 19, 2009
When I try to turn on my LG wall mount unit it will not turn on
Does it give you a code? Try turning only one at a time to see if that works. I would like to help you but need more information.
Sep 18, 2014 | LG LWHD1800R Wall/Window Air Conditioner
Model #LG LWHD1500ER The fan to cool no longer runs on the low speed. It will just humm. On "energy saving mode" the unit does not always turn on to cool. On the "cool mode" when the fan is on high it...
www.appliancefactoryparts.com/content/.../118816.pdf - United States
Above is your service and repair manual, with this you will be able to troubleshoot and repair your Aircon.
I suspect, your thermostat may have a faulty sensor?
factoidz.com/troubleshooting-your-air-conditioning-thermostat/
http://www.inspectapedia.com/heat/Thermostats.htm
Below is a DIY AC, troubleshooting how to. http://www.repairclinic.com/Air-Conditioner-Troubleshooting
Jun 26, 2010 | LG LWHD1500ER Wall/Window Air Conditioner
Air conditioner wont work after winter off
Make sure the filter is clean. When you remove the filter you should be able to see the evaporator coil. Make sure it's not clogged with dirt. If they are clean is the fan and compressor are running. If they are not working and with the cost of repair if no warranty. It's time for a new window unit.
Apr 19, 2010 | LG LB1200ER Air Conditioner
My LG air conditioner is rattling. It is brand new out of the box today. Can anyone help?
Many things can cause this, blower out of balance, loose compressor mounts, (did the instructions specify removing a shipping bolt?) sometimes units are shipped with a bolt to hold the compressor down that has to be removed. If not, I would return it where I bought it..
Jul 27, 2009 | LG LWHD2400HR Wall/Window Air Conditioner
LG split system heater cooler. the heater is not working and fan outside is working
I would check to see if the tech accidently left his jumpers on the unit to keep it running while adding freon. I know it sounds like a simple thing. But all techs have done it at one time or another and that will cause this problem. Due to the fact that you just had freon added there is not a reason anywhere that would cause you no heat unless something was hit when this was being done then something electrical fried
May 28, 2009 | LG LSC091PMA Split System Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
