Question about Kenmore Sewing Machines
Wont sew thread bunches up
Try to sew but thread bunches up the casing pops up
    Brigadier General:
  • 8,619 Answers
Hi!
I think you are threading the top of the machine incorrectly. Make sure that what I'm saying is correct, use two color threads to sew with- and you will see that it is in fact the top thread that is bunching.
This might be a tension problem. Could be the bobbin is not threaded in the case right. First, check the threading of the bobbin and then check the stitch.
Next, adjust the tension on the bobbin case. There is usually a small screw on the case that can be tightened or loosened. I think you may need to adjust it a bit or adjust the top tension knob, just a small bit at a time. It the top does not change the stitch, then go to the bobbin case and adjust the screw to tighten the stitch a little bit more.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 19, 2009
    New Friend:
    Problem Solver:
  • 13 Answers
HI I HAVE A SINGER BUT I HAD THAT PROBLEM ONE TIME AND I HAD A BUNCH OF THREAD CAUGHT UP UNDER THE BOBBIN PLATE I TOOK A SCREWDRIVER AND TOOK OFF THE SILVER PLATE AND LIFTED THE CASING RIGHT OUT I HAD A BUNCH OF THREAD AND LINT UNDER IT. MAKE SURE TO REMEMBER HOW TO PUT IT ALL BACK
Posted on Mar 23, 2013
I have a Singer 2263 which is old but not used often. I am making aprons for Christmas, I made 3 and all the sudden the bobbin started bunching together. What can I do?
hi Sue.
Why does my bobbin thread keep bunching up? Check Your Tension Settings. Looping underneath the fabric usually occurs when there is not enough tension in the needle thread to pull the bobbin thread. Sometimes thread bunching can be caused by something as simple as the tension dial being inadvertently turned.
Sewing Machine Thread Bunching Up Here Why .
if you go to this link a little pop up will come up just close this down.
or try this one.
How to Fix that Tangled Nest of Bobbin Thread Under Your Sewing
or read up more at this link.
Why does my bobbin thread keep bunching up Google Search
Dec 13, 2017 | Singer Sewing Machines
My Janome 8050 bobbin case is jumping out of place. The thread is wrapping around the bobbin case and getting stuck, bunching up, and shutting down my sewing progress. It ties the needle up.
check for the retainer action of the bobbin case to see in there is a part broken off that holds the bobbin in the case or carrier
from what you describe , with the thread bunching up etc, I suspect that the needle thread tension is too loose and causing the problems
if so then the bunching and problems can be from the bunched thread pushing the bobbin out of position
take it in for a service and if necessary , repair
Dec 20, 2016 | Janome Sewing Machines
I have a singer confidence 7469 quilter, the upper thread keeps bunching up in the bobbin case. I've tried re threading numerous times with no luck.
try changing the needle
make sure the bobbin is turned the correct way in the bobbin case
make sure the thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
Jan 29, 2013 | Singer Confidence 7469 Mechanical Sewing...
I teach sewing. A student had a problem with bunched threads on the underside of the fabric. I have tried figuring it out and every so often the thread stops looping. While sewing on the cg550 singer...
Make sure you have the correct bobbin, 66 class. Check the bobbin case. These machines use the apollo bobbin case that tend to get broken and then the thread hangs up.
Apr 27, 2011 | Singer CG550 Mechanical Sewing Machine
When I sew a few inches, bunches of threads come out of the bobbin case. It's like it gets clogged or something. I'm getting nowhere with this. Help!
If your bobbin is the correct one for your machine and it is wound tight, not loose and puffy, make sure the thread is going the right way when installed (over the top to the left and then placed flat in the bobbin case). Usually if the thread bunches underneath your fabric it means that the TOP thread is threaded incorrectly. Try re-threading the upper thread. Good luck!
Aug 21, 2010 | Brother LS-2125 Mechanical Sewing Machine
The bobbin case on my Singer Inspiration 4210 sewing machine keeps popping up in the back causing my thread to bunch up underneath. I cleaned the bobbin case, but now it won't sew at all; the case keeps...
unscrew the black plate that holds in the bobbin case and move it over to the left just a little bit, but make sure there is still clearance between the lower right corner of the case and the plate. The case should be able to wiggle a little, but not so loose it can pop out..
Jan 17, 2010 | Singer Inspiration 4210 Mechanical Sewing...
The bobbin case on my Singer Inspiration 4210 sewing machine keeps popping up in the back causing my thread to bunch up underneath. What is causing this? Is the bobbin case in wrong? How is it supposed...
From what I gather on other sites, your thread has to be threaded under tension.... You have to make sure you hear a click when your bringing your thread down to the bottom of the "arm". Also, I thought the bobbin case was rather loosely held in its place, I adjusted this by unscrewing the black plate and moving it over just a smidge. The bobbin is supposed to have some wiggle room, but it kept popping up and making the tiny adjustment seems to have done the trick....for now...
Nov 14, 2009 | Singer Inspiration 4210 Mechanical Sewing...
Babylock sewing machine, upper thread is bunching
the tension is wronge has the lower bobbin case been unwound and refilled)(check that this is threaded right as well)
Sep 05, 2009 | Sewing Machines
Thread bunches up on Singer HD-110
my wife's hd110 singer machine is not keeping tension. what can I do/ look at to try and help this
Jul 07, 2009 | Singer HD-110 Mechanical Sewing Machine
Sewing Machines Logo
454 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
