Question about Stihl Garden
No gas to primer carberater diagram - Stihl Garden
  • Stihl Master
  • 1,807 Answers
Which model.? Check for holes in the primer bulb or in the fuel line, could also be a damaged carb diaphragm
Posted on Feb 27, 2016
Replaced primer bulb & fuel lines. bulp is not filling with gas. Fuel lines are installed on the correct nipple
Provide your lines are correctly plumb then check the carburetor internal filter screen. If it is clogged the primer will not work. On some of the Walbros and Zamas they use an extra tight filter screen that clogs very easily when you have bad fuel lines. These extra tight filter screens can not be cleaned; only replaced.
Here is a basic line plumbing diagram just for reference. If you carburetor has the primer built-in just the primer in the diagram as a line.
May 14, 2015 | Garden
I have a Honda lawn mower mod.hrr it will not
It sounds like the carb choke is not working. If your model has a primer bulb, check it for cracks or holes, as this will let your engine draw air instead of fuel into the carb fuel section and keep it from running. Good Luck
Sep 04, 2014 | Garden
How do you rebuild carberater on a 4 cycle 29cc weed trimmer
There is not much to it. There should be information stamped or printed on the side of the carb - maker and model#s. Take this information and do an internet search with it. You should find a rebuild kit for around $10. The kit should come with a diagram and directions. Take the carb apart, clean as necessary, reassemble with the new parts and you are good to go.
May 14, 2014 | Craftsman 29cc 4Cycle Straight Shaft...
Stihl chain saw diagram primer bulb
need new carb... Primer plate is bad. They will run without it working. Your idle problem is separate from this issue. Fresh fuel/oil mix might help. Some Stihl carbs we just replace because they are cheaper than trying to rebuild...
Nov 12, 2013 | Craftsman Convertible 25cc. Gas Line...
Fuel line diagram poulan wild thing 40cc
I can't give you an actual diagram but a I can try to explain how it should go. There is a line with the filter in the tank that goes to the bottom of the carb, there is another line from the carb that goes to the in port of the primer bulb, the out side of the primer bulb will go back down into the fuel tank. The primer will pull gas from the tank through the carb into the bulb then return the gas from the bulb to the tank
Feb 01, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need a routing map of the fuel lines for the wildthing 2375
There is no diagram that shows this, however i can tell you where they go, the fuel hose from the tank with the fuel filter on goes to the fuel inlet on the carb, the nozzel nearest to the pump side of the carb ( cover held with one screw ) the pipe from the carb nearest to the metering side ( cover held with four screws ) goes to the suction side of the primer ( short nozzel on primer ) there is then a pipe from the pressure side of the primer ( longest nozzel on the primer ) back to the tank ( just pushed into the top of the tank ), just remenber the primer pulls fuel from the carb, and dumps it back into the tank.
Mar 02, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Homelite chainsaw gas line diagram witch one goes where have the primer bulb
Take the primer bulb off.Look on the back side of it.Most will say tank and carb.If not try putting them on if the bulb doesen't get gas in it.Change them around.
Feb 27, 2011 | Homelite ZR10926 16" Chain Saw
Which fuel line "port/inlet" on the Walbro wt-380 goes to the fuel tank? It's on a Craftsman 25cc Gas "Weed Wacker" Line Trimmer purchased in 2002. It has Walbro WT-380 carburetor with external primer...
Usually the line with the filter on it that comes from the tank goes to carb. inlet first which is most likely close to the bottom side of the carb.nearest to the engine,then the outlet or return line on the carb.goes to the inlet side of the primer and the outlet side of the primer goes back to the tank. The primer draws fuel through the carb to the primer to the tank if its not? then correct the line connections until it does
Jun 25, 2010 | Craftsman 25cc Gas Line Trimmer
I can't start my powerwasher. Where is the choke?
This Power washer has a 3.75 hp Briggs and Stratton Engine. It does not have a choke but does have a primer bulb. You must depress the primer bulb at least 3 times to start the engine. The primer bulb is on the side of the carb. It can be black or red. If your still unable to locate the primer bulb please provide your ENGINE model number and I will provide you a link to a diagram for the location of the primer bulb.
Thanks for using FixYa.
Kelly
May 29, 2010 | Briggs & Stratton Gas Pressure Washer...
I'd like to have a little diagram of the correct possition of the gas hoses coming from the gas tank to the primer and carburator for a Sears Craftsman 26 cc blower 150mph 340cfm
unfortunatly there arent any diagrams, my best advise would be to install the fuel lines leaving excess to trim off as you route them betwixt and between. remember that the fuel lines complete a circuit and that the primer bulb does not pressure up the carb, all it does is circulate fuel through the system and makes a loop
hope this helps and good luck
Nov 20, 2009 | Craftsman Garden
Garden Logo
21 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
