Question about Honeywell 50250-S 99.97% Pure HEPA Round Air Purifier
Honeywell 50250 won't turn on - Honeywell 50250-S 99.97% Pure HEPA Round Air Purifier
Why dose drum spin when furnace is not on?
Usually the unit is mounted to the cold air return (cold or intake air) and the round hose is then attached to the plenum (hot or discharge air). The humidistat is usually mounted just above the unit onto the meta plenum, unless you have a control somewhere else or your main t/stat has that capability built in. Its usually wired in with the furnace 24Vac control (or whatever yours happens to be) so that the unit only comes only when the furnace is on.
Dec 08, 2014 | Honeywell HE120A Whole House Humidifier
Installed a rth6350 now no power
The RTH6350 is a battery-powered thermostat. Did you correctly install the AA batteries? Press down and pull the battery holder away from the thermostat on the right hand side. Try new batteries. Did you remember to secure the C wire with a wire nut and push it back into the wall. It should not be connected to the thermostat.
If you connected the C wire, you may have damaged the thermostat by providing too much current. Honeywell has the documentation for the RTH6350 on the product page: http://yourhome.honeywell.com/home/Products/Thermostats/5-2-Day-Programmable/RTH6350D.htm . The installation guide is here: https://customer.honeywell.com/request.cfm?form=69-2416ES . See page 23 and subsequent pages for the wiring diagrams.
I hope this helps.
Oct 11, 2014 | Honeywell RTH6350 5-2 Programmable...
Online manual.com
Home Hardware might be able to supply a manual although could be a Honeywell underneath.
Jun 09, 2014 | Danby Dehumidifiers
Model HDH 165 honeywell dehumidifier owners manual
I just got one from a friend of mine and we dont have a manual so i went to the honeywell site typed in the code HDH-165 and it comes back with nothing. kinda frusterating as i need my place to be cool and was told by gettong one of these it will take the mold smell and tthe heat out.
Jul 24, 2013 | Dehumidifiers
Won`t turn on
Dust. See if you can open the unit and blow some compressed air in the unit, trying not to touch any wires. Smell the unit to detect something that might have burnt after reconecting again after such a long time.
Jun 08, 2013 | Kenmore 54701 Dehumidifier
I have a Honeywell Dehumidifier - Model HdH-131 - it has iced up and isn't working properly -
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
May 09, 2011 | Dehumidifiers
Need manual for honeywell dehumidifier model hdh 131
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
May 30, 2010 | Dehumidifiers
Honeywell 50250-S 99.97% Pure HEPA Round Air Purifier Logo
60 people viewed this question
Top Honeywell Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Honeywell Dehumidifier Expert? Answer questions, earn points and help others
