Question about Frigidaire Dishwashers
Ffbd2405ks0a I can hear motor running but it is not washing
Motor is running but won't agitate and belt is on ? I can hear the motor humming and it will fill up but it wont agitate.
Check drum turning by hand ok not sticky sounds like could be motor if it hums and no turn..
Oct 18, 2014 | Hotpoint Washing Machines
Agitator not turning
do you hear the motor running?if so but agitator isn't moving and hear like a grinding sound and motor running you have a broken motor coupling,watch video
http://www.youtube.com/watch?v=9K1KHEogf3c
Apr 06, 2013 | Roper Washing Machines
If it fills with water but won't wash, is it the timer
hi mary,i just wrote and asked you for the model number,if this is a regular top load washer it could be the timer as long as you don't hear the motor running,if you do hear the motor running you could have a broken motor coupling because the drain pump is on the motor shaft so it will drain,
if you don't hear the motor it could be the timer,when it should agitate try tapping on the timer and see if it works,it has points in it and they can get stuck together or burn out and have no contact like you're saying but it's just a guess without seeing it but if the timer is advancing through with no agitation it could be the timer,did you try any other cycles
Apr 02, 2013 | Washing Machines
Machine won't run on wash and rinse but motor will start and drain the water out
What you hear is the drain pump, remove back panel to see the problem
Mar 31, 2013 | Haier XQJ50-31 Top Load Washer
Buzzing noise
hi, it sounds like the brushes on the motor 2 plastic blockes sit either side of the motor thses are made of carbon and wear down can cause the motor to stop working hope it helps
regards
shaun
Jan 05, 2012 | Washing Machines
Whirlpool washing machine LA5310XPWO wont agitate -- what would cause this and how can it be repaired?
Is this a top or front loader? If it is a top loader do you hear the motor run? If you do the first thing to check is the rubber driver between the motor and the transmission. One way to chek if the motor runs is to fill it with water and put it into spin. If it pumps the water out that means the motor runs. If the rubber driver is broke (happens often) it will neither wash nor spin.
May 20, 2011 | Whirlpool Washing Machines
Drum won't go round when loaded although will rotate by hand
Can you hear the drum motor running when you switch the machine on? You should hear it running and stopping periodically.
If the motor is running but not turning the drum then the drive belt is either broken or has become detached. It can be replaced by gaining access to the back of the machine.
If the motor is not running then it could be one of several problems - programmer mechanism not working, motor burnt out, motor brushes need replacing etc.
Jan 04, 2011 | Hotpoint Washing Machines
Washing machine will not drain
Push down on the lid switch . If you do not hear the motor run , then you have a bad lid switch . If you do hear the motor run , something is in your pump or possibly kinked drain hose .
Jul 06, 2009 | Kenmore 22422 Top Load Washer
Dishwashers Logo
15 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
