Question about Philips DVP 520 DVD Player
Philips 520 dvd player not playing disc
Disc is not operting property - it seems not to be spinning.
SOURCE: Unknown disc error
In my dvdr630vr plays only audio cd`s. Same problem?
Posted on Feb 01, 2008
SOURCE: philips dvp 3020 dvd player will not play, the "no disc" sighn keeps coming on.
Try this. Wait for the "no disc" sign to appear, and only after that load the dvd. The 3020 I have works alright when I use this method.
Posted on Aug 20, 2008
danforddan1
  • 192 Answers
SOURCE: philips 622 dvd player
Its time to clean the reader, thats a little laser eye in side the unit. that gets dusty, buy a cleaned disk, follow instructions, I bet ya this helps. DFD
Posted on Apr 11, 2009
  • 3 Answers
SOURCE: phillips portable player PET724
I had the same problem with my PET724. I tried cleaning the lens, letting the battery run dead, even beating on it but nothing worked. When I was cleaning the lens again with some cleaning agent I accidentally slid the laser head as far away from the center as it would go. When I loaded another disc it has worked fine ever since. I have played at least two dozen discs so far with no problem.
Hope this helps.
Posted on Jun 10, 2009
  • 6 Answers
SOURCE: DVD PLAYER DISC TRAY DOES NOT OPEN
tap it gently from the side while pressing the button......or with a knife try to open it gently...while pressing the button....after it,s open..clean the side n the belt..
Posted on Jun 26, 2009
Philips DVP Playing problem
try to clean or change the laser
Mar 11, 2010 | Philips DVP642 DVD Player
My player when loading dvd loads for couple of secs and cuts off
Does the disc spin?
If not you have my problem spindle motor suspected faulty if the disc spins then its not being read, faulty lazer assy Try cleaning the lazer using dry brush disc philips do a good one and also clean the disc you are trying to play if it still doesnt work its a fault
Sep 02, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
AZ5737 philips DVD says NO DISC after inserting the disc.;please help
Clean the lens with a soft cotton cloth but be careful not to touch it with bare hands. Make sure the lens is not soiled with dust.
Note: if it says 'NO DISC" immediately after closing the tray, check capstan motor if spins smoothly. It is the one spinning the disc. Open the unit's casing to have a view of the disc when playing. If it doesn't spin, replace capstan motor.
Check also for abnormal heating of any IC on the module. Replace if there's any.
Aug 30, 2009 | Philips DVP3962 DVD Player
Discs won't play.
please change laser unite then solve your problem
Jul 16, 2009 | Sony DVP-NS575P DVD Player
My dvd palyer shows NO DISC for any disc i want to play.
the laser is probably no good or the tiny motor that spins the disc is no good.there is a clamper assembly that goes in the hole in the disc.turn it and see if it spins freely.there is a bronze bushing on the top of the motor driving it ,and a small drop of light oil on the bearing will make it work again if it is gummed up..if the motor does not get the disc speed from 250 to 600rpm,fast,the laser does generate the proper info and the computer says error.yes the motors can be replaced,but the cost is as much as a new one
Jul 03, 2009 | Philips DVP642 DVD Player
DVD player plays VCD/SVCD but not DVD
there is a problem with the disc motor, replace it
Apr 08, 2009 | Philips DVP642 DVD Player
DVD VIDEO DISC MECHANISM WILL NOT FUNCTION
broken tray belt or belt is off. usually a small motor up front exposing belt to be knocked off.
Dec 08, 2008 | Philips Televison & Video
Phillips pet 706/05 dvd player wont dvd-r-rw
  • Disc not loaded. Load a disc into the player, close the door and press PLAY.
  • The disc used may be defective. The disc used may be defective, try another disc.
  • The disc is placed improperly in the tray. Make sure the disc is properly placed and centered in the tray and if the disc has a label on one side, make sure the label is facing up.
  • The disc is dirty. Use a soft cloth to clean the disc by wiping in a straight line from the center of the disc to the outside edge.
  • Use of DualDisc or Flip Disc which does not meet the Compact Disc Digital Audio Standard. Some music labels have recently introduced the DualDisc for pre-recorded audio and video content. The DualDisc bonds DVD content on one side 'back-to-back' with digital audio content on the other side. However, the digital audio side does not meet the technical specifications specified in the Compact Disc Digital Audio Standard. For this Reason, DualDisc is not permitted to carry the CD logo. Philips DVD and CD players and disc drives fully comply with the CD specifications and therefore may not recognize the DualDisc. Attempting to use DualDisc may lead to playback problems or jamming in the slot loader or drive.
    The DVD video content on the DVD side of the DualDisc should play on Philips DVD players and DVD drives. However, Philips DVD players and drives do not support DVD Audio, and will not play any DVD Audio content present on the DVD side of a DualDisc. Philips will further investigate DualDisc and update this notice accordingly.
Jul 18, 2008 | Philips Televison & Video
UUURRRG
Not spinning disc
If it spins with a little help from yourself replace the spindle motor with improved motor, part number: RXQ0749A
Unable to detect discs
The laser head was the culprit. Replacing it fixed the problem. (Laser head code GRP6278A)
Difficulty reading cd, if it does read the sound is strange and sticks
Replace C101 (1000uF/16v)
Nov 24, 2007 | Philips DVD750VR DVD Player/VCR
I need a motor assembly for a philips dvd player
i used to repair dvd and cd players, the motor wont spin until the laser focuses on the disc, so you could have a faulty laser. also the mechanism sometimes comes as a complete assembly. which will cost more than anew unit
Mar 27, 2007 | Philips DVP5140 DVD Player
Philips DVP 520 DVD Player Logo
22 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
