Question about Nathan Headgasket Headband With Leds, Black, Large/Xl
Headgasket replacement daewoo nubria
Does the cam pulleys need to come off to remove the head
How to replace a serpentine belt on 2002 daewoo nubria
You will have to release the idler wheel. It is the only pulley wheel that that does not have a component on it. There is a bolt on that which you can loosen the whole belt with to replace it. A crow bar is usually used to adjust the tension back once you replace it.
Aug 30, 2014 | Cars & Trucks
Timing belt diagram daewoo nubira 1998
Here are the written instructions, i do not have the pictures, it is a very good set of instructions and clearly written.
Required tools:
13mm open end wrench 10mm shallow and deep socket 8mm socket long flathead screwdriver 17mm deep socket T50 torx socket 1/4", 3/8ths and 1/2" ratchets and extensions E10 inverted torx sockets 6mm Allen wrench 15mm open end wrench 7mm socket 12mm open end wrench 14mm socket 12mm socket 8mm, 9mm and 10mm Allen head sockets 19mm socket pry bar needle nose pliers
If you are doing this because your timing belt broke you will also need to buy a complete cylinder head, head gasket set, and both idler pulleys. ALL DAEWOO MODELS WILL BREAK THE INTAKE AND EXHAUST VALVES WHEN THE TIMING BELT BREAKS.
Start by removing the air cleaner assembly from the throttle body, remove the air filter and housing jack up the vehicle and remove the wheel, remove the plastic shielding in front of the accessory drive belt assembly, remove the accessory drive belt, place a jack with a block of wood on top underneath the engine oil pan remove the front engine mount, remove the crank shaft pulley ( the 4 Allen head bolts only not the 17mm bolt in the center.) remove the metal plate behind the engine mount bracket on the engine, remove the plastic timing belt cover 3 clips on top 2 10mm bolts on bottom. Rotate the engine until the #1 cyl. is at Top Dead Center on the compression stroke or line up the crankshaft timing mark with the mark on the inner timing belt cover ( notch in cover with notch in pulley) on the camshaft pulleys -- ( intake cam line up the line on the pulley with the line on the inner cover)( exhaust cam line up the arrow on the pulley with the arrow on the inner cover) loosen the 13mm bolt in the belt tensioner and using the Allen wrench rotate the tab until there is slack in the belt. Remove the belt. At this time I would recommend you replace the water pump, both plastic idler pulleys as they tend to overheat and lockup, and the belt tensioner. Make sure all your marks are lined up, you may need a helper to hold the Exhaust Cam in place as it tends to move during belt installation. Put the timing belt underneath the crankshaft pulley, install the belt leaving the intake cam for last and NO BELT SLACK on the right side between the crank and the exhaust cam. Once the belt is installed rotate the crankshaft over 2 revolutions and make sure is rotates freely, and your timing marks are aligned perfectly if not the engine will not run properly, tension the belt as needed. Installation is the same as removal.
Nov 15, 2011 | 1999 Daewoo Nubira
How to fix timimg belt
Required tools:
13mm open end wrench 10mm shallow and deep socket 8mm socket long flat-head screwdriver 17mm deep socket T50 torx socket 1/4", 3/8ths and 1/2" ratchets and extensions E10 inverted torx sockets 6mm allen wrench 15mm open end wrench 7mm socket 12mm open end wrench 14mm socket 12mm socket 8mm, 9mm and 10mm allen head sockets 19mm socket pry-bar needle nose pliers
Start by removing the air cleaner assembly from the throttle body, remove the air filter and housing jack up the vehicle and remove the wheel, remove the plastic shielding in front of the accessory drive belt assembly, remove the accessory drive belt, place a jack with a block of wood on top underneath the engine oil pan remove the front engine mount, remove the crank shaft pulley ( the 4 allen head bolts only not the 17mm bolt in the center.) remove the metal plate behind the engine mount bracket on the engine, remove the plastic timing belt cover 3 clips on top 2 10mm bolts on bottom. Rotate the engine until the #1 cyl. is at Top Dead Center on the compression stroke or line up the crankshaft timing mark with the mark on the inner timing belt cover ( notch in cover with notch in pulley) on the camshaft pulleys -- ( intake cam line up the line on the pulley with the line on the inner cover)( exhaust cam line up the arrow on the pulley with the arrow on the inner cover) loosen the 13mm bolt in the belt tensioner and using the allen wrench rotate the tab until there is slack in the belt. Remove the belt. At this time I would recommend you replace the water pump, both plastic idler pulleys as they tend to overheat and lockup, and the belt tensioner. Make sure all your marks are lined up, you may need a helper to hold the Exhaust Cam in place as it tends to move during belt installation. Put the timing belt underneath the crankshaft pulley, install the belt leaving the intake cam for last and NO BELT SLACK on the right side between the crank and the exhaust cam. Once the belt is installed rotate the crankshaft over 2 revolutions and make sure is rotates freely, and your timing marks are aligned perfectly if not the engine will not run properly, tension the belt as needed. Installation is the same as removal.
Feb 27, 2011 | 2001 Daewoo Leganza
How do you put a timing belt on a 2002 daewoo leganza 2.2 liter engine twin cam and what are the marks?
Here are the full instructions and tools needed.
Required tools:
Jan 07, 2011 | 2002 Daewoo Leganza
I dont know how to set the timing for my 2000 nubria daewoo
You will need these tools:
13mm open end wrench 10mm shallow and deep socket 8mm socket long flathead screwdriver 17mm deep socket T50 torx socket 1/4", 3/8ths and 1/2" ratchets and extensions E10 inverted torx sockets 6mm Allen wrench 15mm open end wrench 7mm socket 12mm open end wrench 14mm socket 12mm socket 8mm, 9mm and 10mm Allen head sockets 19mm socket pry bar needle nose pliers.
If you are doing this because your timing belt broke, you will also need to buy a complete cylinder head, head gasket set, and both idler pulleys. ALL DAEWOO MODELS WILL BREAK THE INTAKE AND EXHAUST VALVES WHEN THE TIMING BELT BREAKS.
Start by removing the air cleaner assembly from the throttle body, remove the air filter and housing jack up the vehicle and remove the wheel, remove the plastic shielding in front of the accessory drive belt assembly, remove the accessory drive belt, place a jack with a block of wood on top underneath the engine oil pan remove the front engine mount, remove the crank shaft pulley (the four Allen head bolts only not the 17mm bolt in the center.) Remove the metal plate behind the engine mount bracket on the engine, remove the plastic timing belt cover, three clips on top and two 10mm bolts on bottom. Rotate the engine until the #1 cyl. is at Top Dead Center (TDC) on the compression stroke or line up the crankshaft timing mark with the mark on the inner timing belt cover (notch in cover with notch in pulley) on the camshaft pulleys (intake cam line up the line on the pulley with the line on the inner cover) (exhaust cam line up the arrow on the pulley with the arrow on the inner cover) Now loosen the 13mm bolt in the belt tensioner and using the Allen wrench, rotate the tab until there is slack in the belt. Remove the timing belt. At this time I would recommend you replace the water pump, both plastic idler pulleys as they tend to overheat and lockup, and the belt tensioner. Make sure all your marks are lined up, you may need a helper to hold the exhaust cam in place as it tends to move during belt installation. Put the timing belt underneath the crankshaft pulley, install the belt leaving the intake cam for last and NO BELT SLACK on the right side between the crank and the exhaust cam. Once the belt is installed, rotate the crankshaft over two revolutions and make sure is rotates freely, and your timing marks are aligned perfectly. If not, the engine will not run properly, tension the belt as needed. Installation is the same as removal. To clarify, on the DOHC engine, the intake cam gear has a line on it, and the exhaust cam gear has an arrow on it. These should be lined up with the corresponding line and arrow on the VALVE COVER, pointing straight up. I just went through this process over the weekend, and spent quite a bit of time looking for these marking as I had removed the valve cover. Once I found them, it was plain and simple. In addition, be sure to not over tighten the belt when reinstalling. The tensioner has markings on it for "old" and "new". DO NOT adjust past "new", as the car will sound like a jet engine, and the belt will not last for very long. One more item that you might as well replace while you are in there is the cam position sensor if you have not already replaced it as there have been issues with them, and the timing housing has to be opened to get to it. The timing is set at: 8 degrees (both manual and automatic transmission)
Oct 23, 2010 | 2000 Daewoo Nubira
How do I set the timing on a 2002 Daewoo nubria?
make sure you align all the marks on the gears that the timing belt runs on.
Jul 11, 2010 | 2002 Daewoo Nubira
Where is the timing mark for the camshaft on a 2000 Daewoo Lanos?
Here is the entire timing belt replacement procedure.
Required tools:
One more item that you may as well replace while you are in there is the cam position sensor if you have not already, as there have been issues with them, and the timing housing has to be opened to get to it
May 22, 2009 | 1999 Daewoo Lanos
Timing belt replace daewoo 1.5 1995
follow this procedure.
Required tools:
Mar 14, 2009 | 1999 Daewoo Lanos
Daewoo lanos timing belt replacement how?
Required tools:
Dec 16, 2008 | 2000 Daewoo Lanos
Nathan Headgasket Headband With Leds, Black, Large/Xl Logo
64 people viewed this question
Top Nathan Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Nathan Health and Beauty Expert? Answer questions, earn points and help others
