Question about Sony BRAVIA XBR46HX909 46 in. 3D HDTV
Connect Asus X58L laptop to sony bravia LED tv using VGA to HDMI cable
Connect Asus X58L laptop to sony bravia led KDL46EX723 using VGA to HDMI cable
  • 125 Answers
SOURCE: no signal sony bravia to dell laptop
Most laptops have a combination of buttons you have to press on the keyboard to get it to output on the monitor output. Try pressing the FUNCTION KEY or FUNC/FN key usually found in the bottom left hand side of the keyboard. Keep that button held down while press one of the number keys. Usually the number key will have a picture of a TV screen on it. Might be number 8 or 9. Press both keys at the same time a you can switch between laptop screen, Sony LCD or you can have both..
Posted on Mar 20, 2009
SOURCE: Sony Bravia television hdmi stopped working
Installing a new software update will this issue. All you need is a compatible USB flash drive. Go to support on Sony.com. Look up your tv model and if there is an update, just follow the instructions to install it yourself. I have a KDL-46S5100 and this worked great. The download and instructions page I used was : http://esupport.sony.com/US/perl/swu-download.pl?upd_id=4769#install
Posted on Oct 10, 2009
  • 630 Answers
SOURCE: my sony bravia has no audio when used as cable tv
Check the connections between the cable box and the TV. If you are using scart check the connector is in squarely if using rgb or composite you need a separate audio connection using the red and white phon sockets.
Posted on Nov 08, 2009
SOURCE: hdmi port stopped working on sony bravia
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
Posted on Mar 21, 2010
SOURCE: i have a 46 inch
i have a 40" model aas well - the only way to turn it off i have found is to restore to factory settings and set the tv up again.
Posted on Sep 19, 2010
Just purchased Asus VE248H monitor. Used a 10 pin connector and was happy, but wanted more. Hooked monitor to pc with an HDMI cable, got HDMI - NO SIGNAL. Screen went dark. Disconnected HDMI, reconnected...
Hi , just access the monitor on-screen display (OSD) menu and ensure Monitor input mode is configured for HDMI ( Asus speak the " desired input source" ) - Input select is accessed under tv with arrow icon : change from vga to hdmi
Mar 03, 2015 | ASUS Ve248h 24-inch Led Monitor
How do I connect my laptop to my led tv?
Is there a HMDI output on your Laptop or a VGA output. Some TV's have a DSUB input source that allows VGA depends on your laptop it could be HDMI if so TV should have an extraz HDMI input on the back and you change the source input on the TV to the HDMI 2 or HDMI 3 source depending on where you plugged in the P.C. . If HDMI you need to buy a HDMI cable.
Sep 08, 2014 | Toshiba Satellite Computers & Internet
Can not connect hdml wire to my philips led tv with my dell laptop. what to do
If your laptop does not have a HDMI port then you need a VGA to HDMI converter. Connect this converter to your laptop and then connect it to the TV using a HDMI cable. You also need to connect the audio out port on the laptop to the audio in on the TV. You can get a combined audio input with some HDMI converters.
Check out this WEB site.
http://www.proaudiovisual.com.au/vga-to-hdmi-converter-adapter-and-upscaler-video-audio-full-hd-1080p/
Mar 05, 2013 | Computers & Internet
My sony bravia model number kdl 46ex723 blinks four times what that mean
Solution for Sony Bravia KDL 46EX723 blinking red light 8 times. Information below is from Sony online support, it worked for me:
Please disconnect the Internet connection from the TV and your TV will work fine.
We are suspecting a network outage issue on Sony device, we are currently investigating this issue. I am really sorry for the inconvenience caused.Unfortunately we don't have any ETA on this,I request you to try at a later time.
Nov 18, 2012 | Sony " 46"" Class - LED - 1080p - 120Hz -...
How can i connect my dell inspiron 640m laptop to my sony bravia lcd tv?
Your tv should have vga port. if not you can buy a vga to hdmi adapter
Feb 19, 2012 | Sony Televison & Video
Does the Sony VGN SF790 support hdmi cables? I would like to connect to my Sony Bravia TV
Hi.
No I'm afraid not. It only supports VGA out. If your TV supports a PC input then a male to male VGA cable will do. VGA does not support audio so you will also need an audio lead to connect to the TV too.
Regards.
Aug 13, 2011 | Sony VAIO VGN-FS790 Notebook
Hi, I am trying to connect my Acer Aspire 5600 laptop to my Sony Bravia (HDMI) TV. I bought a VGA cable to connect the two (because my laptop is not HDMI). Once i have plugged in the VGA cable in both...
The Bravia needs the video input to be changed to PC when you connect a computer to the Bravia.
You still need to press FN + F5 to divert the laptop video data to the video port on the laptop for the TV.
May 22, 2011 | Computers & Internet
Connecting latitude D630 to Sony Bravia
Disconnect all cables and reboot your computer.
Turn off your hdmi TV as well.
When computer is already on, connect the VGA/HDMI cable to your computer and the other end to the TV.
Turn TV on then press Fn+F8 ONLY ONCE.
May 25, 2010 | Dell Latitude D630 Intel Core 2 Duo T7250...
No sound when my computer is connected to my Sony Bravia TV
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
Apr 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony BRAVIA XBR46HX909 46 in. 3D HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
