Question about Compaq 7500 17" CRT Monitor
Display problem i have a compaq 7500 moniter.after power on booting is going on but there is no display in moniter.but if i press the power button of my monitor.sometimes display coming sometimes not......is it the problem of my motherboard or my monitor problem.
  • sandipan4cse Jun 20, 2009
    Motherboard Description
    MIS name: MS-6577 M-ATX Rev. 3.1 (Giovani), Rev. 4.0 (Giovani2)
    Compaq name: Giovani-GL6, Giovani2-GL6
    CPU
    • Socket 478 for Intel P4 Williamette and Northwood processors
    • Supports Intel Pentium 4 processor up to 2.8 GHz
    • Supports Intel Celeron processor up to 3.06 GHz (Prescott based Celeron with 533MHz FSB)
  • 121 Answers
Well this seems the problem of your motherboard but still i will be needing more information about your system.If you need help you can visit me at----http://techbuddies-robin.blogspot.com/2009/06/free-computer-related-technical-support.html
Posted on Jun 19, 2009
I have desktop pc motherboar asus m2m ddr2 ram display not come extra display card attached but display not com in moniter when press on keyboard num lock o n off system boot ok but display not come in...
re-boot pc. Go into setup (F2). Go to your video settings and make sure your video card is selected as your video device and that setting are correct for its operation.
Dec 04, 2012 | Computers & Internet
Compaq CRT Monitor 7500 does not support hd videos. The system starts re-boot when HD videos are played. HD Videos that play on youtube dont play when downloaded in system. I dont get where is the problem?...
yes see if proper original drivers are installed or not .it can be solved by installing an AGP card into an AGP slot use 8X AGP card for better result .this happens because inbuilt display cad has no sufficient memory on the motherboard
Apr 05, 2010 | Compaq CV 7500 17" CRT Monitor
ATI vga driver and compaq N610c
plz i want compaq Evo N610c vga driver
Dec 04, 2008 | Compaq Evo N610C Notebook
COMPAQ 7500 monitor, MenuBar/Brightness Bar, Keys not working
replace Menu buttons (Microswitches) and check 5v path
check dry points.
Oct 11, 2008 | Compaq 7500 17" CRT Monitor
My monitor is not working..
Check If the Monitor has Power,
If yes,then Check if it has the Display,(if No, then Check the Power cable try and Reseat them)
If yes then try to boot into BIOS.(If no then try to Reseat the VGA cable)
If you are able to boot into BIOS your Monitor is Fine.
Jun 06, 2008 | Compaq CV 7500 17" CRT Monitor
Screen will not power on
hai
check the smps it may be the problem or check your moniter by removing the data cable from the cpu for the OSD display
also check the ram
Apr 24, 2008 | HP Compaq nc6000 Notebook
Display
Check Power supply(220/400v cap)
Mar 29, 2008 | Compaq 7500 17" CRT Monitor
Compaq FP 5315 Moniter
Have you checked the computer bios?
In case an item was changed in the BIOS, such as the primary display device setting, use the following steps to reset the BIOS back to its default configuration:
  1. Turn on the computer and press the keyboard key that enters the BIOS Setup screen key when the keyboard light comes on. The key to enter the BIOS should be one of the following:
    • HP and Compaq desktop computers that came with Windows Vista, press F10 .
    • For HP Pavilions desktop computers that came with Windows XP or previous versions of Windows, press F1 .
    • Compaq Presario desktop computers built after 2002, press F1 .
    • Compaq Presario desktop computers built prior to 2002, press F10 .
  2. Wait 5 seconds.
  3. Press the F5 key to restore the default settings of the BIOS.
  4. Press Enter to accept the change and wait five seconds.
  5. Press the F10 and then the Enter key to save the changes and exit from the BIOS.
  6. The monitor should now display the first screens received from the computer (the logo screens). If not, find and download the latest BIOS update if one is available for your computer.
  7. If a BIOS update was not available or the monitor is still blank, continue to the next step
Reseating loose internal components
If the PC case was recently serviced or moved, a card, cable, memory module, or processor may have become loose. When this happens, the PC might make a beeping sound when turned on. Use the following steps to check for loose components: WARNING: The edges of metal panels can cut skin. Be careful not to slide skin along any interior metal edge of the computer. CAUTION: This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
  1. Unplug all cables except for the power. Write down each cable location if you do not already know where it connects.
  2. With the power cable removed press the Power button on the front of the PC for 5 seconds.
  3. Remove the screw(s) that retain the panel or cover from the rear of the PC. c00371492.jpg
  5. Gently press down on the outside edges of cards and memory modules that are inserted into the motherboard to better seat them. Do not press too hard.
  6. Gently press down on the connectors of the flat ribbon cables to seat them.
  7. Replace the side panel and screw(s), reconnect the PC cables, and turn on the PC on.
  8. If the monitor still displays a black screen, the video hardware may be faulty and needs to be replaced or serviced. If the monitor displays the first startup screen but does not display Windows, continue to the next step.
Try this and if it doesnt work. please post again.
Oct 21, 2007 | HP Compaq FP5315 15" LCD Monitor
Compaq Armada E500 PC Notebook Display Completly Out
Hi Jeryl; Im sorry to have to te3ll you but when the power went out it sent a surge to the external monitor . This blew the monitor which in turn blew your video display. This is a not so uncommon problem with laptop displays. They are very fragile. Especially when it comes to power urges. The only way you can fix this is to replace the monitor. Even this may not fix the problem. It could be any one of a few thousand parts inside your laptop. Best advice would be to let your local repair shop do the repair. Hope this has helped. If it has please accept this answer. Thank you; HELP2DIY
Jun 30, 2007 | Compaq Armada E500 Notebook
Computers & Internet Logo
201 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
