Question about Garden
Gas and oil
Shoots out oil and gas from the air filter and exhaust
    Champion:
  • 279 Answers
Oil is overfull!!!!!!!
Posted on Jun 03, 2014
5 Suggested Answers
  • 4 Answers
SOURCE: Gas entered the exhaust system and then oil reservoir. I got the gas out exhaust change oil. Mower runs but in question is gas still entering both places.
the little solenoid on the bottom of your carb is letting gas flow while it is not runnung.therfore gas gets into your oil.About an 80.00 part..or you could just turn your gas valve off when your done mowing.but still you would have to eventually replace that part.hope this helps
Posted on May 28, 2009
  • 81 Answers
SOURCE: 18 hourse power kraft with oil shooting out the air breather
Sounds like you over filled it with oil. Only reason for oil to come out of these places.
Posted on Jun 24, 2009
  • 640 Answers
SOURCE: my troy bilt 4 cycle
Check to see if the oil was overfilled, or maybe stored in a position that allowed the oil to drain to parts that it was not intended.
Posted on Jul 18, 2011
  • 6468 Answers
SOURCE: Won't start...turns over...took. Air filter off and gas and oil mixture shoots up into their once it starts
sounds like the needle valve in the carb is not seating and the fuel is draining into the oil
Posted on May 16, 2012
Why would oil come out exhaust pipe?
Either you may have over filled the oil or possibly you having problems with the exhaust gas blow by. A build up of fluid can cause the inlet system to pressurise and this forces oil vapor in to the inlet system and out through the exhaust.
Jul 27, 2014 | Yamaha Genuine Yfm 350 Yfm 600 Yfm660...
Leaks oil and gas
Your air filter plugged. It can't breathe. The muffler may plugged or little plugged.
Apr 20, 2014 | Garden
Yahoo
This is a "Backfire" check your ignition timing and also check that you engine oil level isn't dropping. It shouldn't be shooting oil out of the air filter. this is usually an indication of a problem in the piston chamber, Either, a holed piston, broken piston rings or a blown head gasket.
Apr 28, 2013 | 2007 Honda VT 750 Shadow
Lawn Boy 10641
see if the oil smells like gas the carb maybe sticking and gas gets into the oil washing the oil out this will make hard starting and smoke if so the needle valve is not sealing if you caught in time without major engine damage a sign is the oil being over full and smelling like gas
Apr 03, 2012 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
. Would too much oil make the bike Deceleration
Only if the air filter has become oil fouled . More than likely this would keep the bike from running too. If you have too much oil be sure to do the sniff test (on the oil fill hole) just in case a carburetor float stuck and filled the engine with gas. This might also cause poor running. If you have oil in your gas be sure to change the oil , check the air filter, and always turn off the gas when you are not riding. If everything is normal , then you probably need to change the exhaust o-rings in the head and the exhaust seal from the head pipe to muffler. By sealing the exhaust system you should eliminate the popping and backfiring from deceleration.
Nov 08, 2010 | 1992 Honda CB 1
Starts but won't stay running, i clean carburator and still have same problem, unit has been used very little, still look new, Thanks,
Have you checked your oil? You need pump oil half way up in reservoir. Open plug on top of pump and check oil. Pump takes SAE 20 or 30
Next, open oil plug below engine and check your oil level. It should come up 1/2 way on dip stick. Engine takes 10W30. Don't turn washer on its side or upside down to drain oil or oil will run into carburetor.
Is the water turned on? Are you holding gun trigger open while starting? Pump needs water flow. DO NOT tie gun trigger open with wire and then start engine. That gun will flip around and shoot a hole in your leg.
If the engine starts, then you have gas, spark and compression
If engine won't stay running, the exhaust port might be clogged, or the carburetor is not letting in enough gas, or gas is not flowing to carburetor.
Check the screen over exhaust port > is it dirty or clogged? Clean with WD-40 or break it out with a screwdriver.
Remove gas filter below gas tank >>> it has a hex bolt >> loosen bolt >> the gas should come flowing out >> put it back if gas comes out
Next remove rubber gas line feeding gas to carburetor >> gas should flow out this line too >> if flows then put it back.
What about your air filter? Take it off. See if engine fires and runs without air filter. Air filter may be clogged.
While air filter is out, you can see open port to carburetor. Spray some WD-40 into carburetor. Fire up the engine. It should spark real healthy on the WD-40. Keep spraying WD-40 into carburetor to see if you can keep engine going. Don't forget to keep gun trigger open so water is flowing and pressure is not building in pump.
If engine keeps going with WD-40 but dies without it, then your carburetor is very suspect. You might need a new one.
If engine will not keep going with WD-40, then the spark is very suspect.
Change spark plug. Try again. If it doesn't fire up after that, you need to take it to the shop for repair.
Oct 09, 2010 | Honda 2500 PSI Gas Pressure Washer
Lots of smoke and oil comming out the exaust . only 1 and a half year old
Has fuel with oil accidentally been mixed to the fuel for this mower? We have had mix oil accident get added it to this lawn mower and it will smoke a lot with 2 cycle oil.
Unless you are certain no oil is mixed with the fuel I would drain and clean the fuel system.
Replaced the spark plug with the new and replace the air filter In addition ensure you do and oil change every 30 hours using a high grade 30 wt oil to include make sure it is not over full.
Hope this tip helps.
r/
David
Feb 06, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Jun 24, 2009 | Garden
The air is coming out of the filter instead of intake . Craftsman Air Compressor 12-gal 1hp model 921.166400
if acualy exhaust / engine pressure is coming out of filter it likely to be a bad valve...does engine blow smaoke or oil? is there also pressure coming out of oil crankcase?....let me know , we'll diagnose it! good luck, marty
Jun 14, 2009 | Craftsman Air Tools & Compressors
Loss of power on acelaration
There's a lot on any car that can cause loss in power.
A few of them are:
Mass air Flow sensor
Bad O2 sensors
Old oil or sludged oil
Bad Gas
Clogged catalytic converter
Loss of cylinder pressure or compression
I would start with the cheapest tests/fixes first
oil: if you haven't already and don't know the condition of your oil, change it. If your oil has sludge in it then you could have a leacking head gasket.
Next up, If your gas is bad fill the tank about half way and use lucus oil octane booster, and for a second half a tank pour in some seafoam engine cleaner. It will clean your fueling system, injectors, and pistons/chambers.
If those too don't help: get a compression test on the cylinders. Not expensive to have done, but could be expensive to fix if there is something wrong or the compression is leaking.
Next, go to a muffler shop and have your catalytic converter checked. A clogged or bad Catalytic converter may trap exhaust and keep it from exiting your exhaust system.
While your there you can have your O2 sensors checked.
If all of that is fine, replace the O2 sensors and the Mass air flow sensor. These components control the air fuel ratio. If they are going out your engine won't ever get the right amounts of gas and air to run properly.
It's a lot, but my general rule of thumb for trouble shooting any issue with a car is to start with the cheapest fix and work your way up.
Jun 03, 2009 | Hyundai Motor 2002 Sonata
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
