Question about Saws
Dewalt dw005 no reverse - Saws
2 Suggested Answers
  • 304 Answers
SOURCE: Hi, i need Dewalt DW005 motor power in amps, i have to use 24v transformer, please help and thanks
Dewalt say NO LOAD AMPS = 5 - 6.8 amps
Go to http://service.dewalt.co.uk/Products/ProductDetail.aspx?ProductID=5841 for full details
Posted on Jun 02, 2012
My dewalt 18v drill wont reverse
most likely the switch is bad . you can find a break down and buy the part from ereplacement.com
Jun 18, 2014 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt dw005
Remove the cap and the circlip underneath and slide it all forward. Pull back plate holding the small ball and remove it. Put drill bit into a vice and pull on the machine. If it still won't come out you might have to tap on the main spindle with a copper hammer to knock the spindle off. Check the spindle for damage before reassembling.
Jan 18, 2014 | Drills
Dewalt 24volt dw005,... as soon as i put a battery into the body of machine the battery starts to smoke ,the drill still works but to me seem's like its got a short circuit .i've took handle o
To be sure it's the switch, check for continuity between the positive and negative contacts at the terminal block, where the battery connects to the tool, with the switch off. There should not be any continuity there, if there is the battery will have a constant draw (short circuit) on it which will cause it to overheat and smoke if left on long enough. The switch is replaceable, it's part number 487136-00 but shop internet stores, the switch is around $75 +s/h.
Feb 26, 2012 | Drills
The chuck on my Dewalt 18v hammer drill will not stay tight. it loosens whether I am in forward or reverse
the chuck on my dewalt 18 volts hammer drill will not stay tight it loosenss whether i am in forward or reverse
Oct 14, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt de9092 - the reverse not engages regularly
sounds like the switch is bad and needs replaced, You can go to Dewaltservicenet.com and type in your model number to find a replacement switch, If you do it yourself make sure to write the wiring down first, the switch might be polarity sensitive.
Sep 24, 2009 | Dewalt 18 Volt Compact Drill Kit
I have a dewalt DW005 24V hammer/plus drill i am having problems charging batteries. the L.E.D lights flashes as though its charging but it has stopped showing continuous light as it should do when fully...
The battery has probably lost it's ability to receive a charge. Is it old? Check the output of charger, should be around 26 volts DC at the output jack.
Jun 25, 2009 | Dewalt DW005K Rotary Hammer
24v dewalt dw005 was using my drill in chisel position for about 25 mins when changed back to rotary hammer it sruggled to get going and was sticking in chisel the lever was fully to rotary.will this...
Hi, You should take it back while the warranty is still fully intact as this is a problem and will not resolve itself.
Good Luck to you, this should Fixya!
Mar 23, 2009 | Dewalt DW005K Rotary Hammer
Saws Logo
24 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
