Question about Water Heaters
New Gas Hot Water Tank
Installed Dec 2013---keeps going off--bliking sequence 6X 5X 6X 5X=Failed Ignition Lockout--plumber who installed says it's the way it works--I say it can't be that every few weeks I have to re-set the tank by unplugging-then it starts again---this should not be--I feel there is something wrong that can be corrected---your product was in my home over 25 years before it had to be replaced--I would only go with a Rheem---PLEASE HELP ME! thanks, Ruth Baltzer
  • Water Heaters Master
  • 2,463 Answers
It sounds like its the flame sensor which would send it to lock out . unplugging it only resets it . They do not work like the plumber said .
Posted on Jun 17, 2017
gary1121
  • 332 Answers
SOURCE: bosch 16p gas, keeps going hot and cold
check the thermostat, you will probly need someone that has worked on the same kind of unit, they are not all the same {tankless} I would suggest a repairman,, there is a little bit much to explain how to do it over the internet,
Posted on Jun 23, 2009
  • 9 Answers
SOURCE: 12-year old Rheem residential single-thermostat
TIME TO REPLACE TODAYS ARE MORE EFFICIENT
Posted on Sep 08, 2009
  • 297 Answers
SOURCE: Rheem 50 gallon gas water heater less than one
it could also be the dip tube. this is a tube that is installed at the time the unit is made.it is a plastic tube that is on the cold intake side of the hot water heater.it may have fallen inside the unit or may not be in the unit at all check to see if there is a plastic tube this will help the heater stay hotter for a longer period of time. good luck with your project.
Posted on Sep 29, 2009
SOURCE: Leak from hose that connects the dispenser to the tank
Lowering the temp makes no sense since the enitire purpose of the unit is to provide very hot water. The manufacturer has a "permanent" repair kit (using a different hose) for about $25. You can reach them at 1.888.222.9140
Posted on Nov 30, 2009
SOURCE: Error code 13 (air flow) tankless H20 Rheem
Have 2 of these Rheem units in my house. Both had this same error code within 30 days of each other. And my neighbor has 2 units as well - and guess what - 2 months after mine stopped working because of the code - so did theirs. It is not something that can be fixed. It is a manufacturer's defect - and it looks like Rheem has yet another class action on their hands (like the one for the RTG - 74 PVN). They need to do a recall to repace these units.
Posted on May 08, 2010
Hot water heater water, went out main line of house that enters house
You did smart thing turning off water and gas.
Play it safe.
Your water heater will NOT explode.
Conduct routine maintenance so water heater lasts longer. If plumber says you need new heater, then post question on fixya and include information showing on tank label on side of tank.
Also include why plumber says to replace.
Get another plumber.
Call city utility company to determine source of noise.
Dec 01, 2012 | Whirlpool Water Heaters
Hot water heater pilot is off. It's not gas,
You have tank-type gas water heater:
Open following link to watch thermocouple replacement.
Make sure new thermocouple sits into pilot flame. Instructions for relighting water heater are usually printed on side of tank.
http://www.youtube.com/watch?v=v0aBPsNg6vo
Gas water heaters need working thermocouple, adequate incoming fresh combustion air with no trace amounts of chemical, open vent to outside that drafts poison combustion product upward, clean burner tubes and combustion parts, correct gas pressure with no air in line, working gas control valve thermostat, no lockout condition such as tripped ECO caused by runaway heating and dirty combustion parts, and no lockout condition such as exposure to flammable vapors.
Open following links for troubleshoot resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
http://waterheatertimer.org/images/Test-water-heater-vent-1400.jpg
Jul 29, 2011 | Whirlpool Water Heaters
Had three 50-gal American Standard water heaters installed Dec. 2009 Two upstairs in attic, one downstairs at ground level. Attic location used because heaters being replaced were up there. Upstairs...
Plumber is right.
Problem is not amount of air in attic. Problem is how hot the air is.
Oxygen molecules separate apart in very hot air and pilot light goes out since there is not enough oxygen density to support combustion.
More ventilation is needed.
Plumber is not ventilating expert, and not responsible for attic ventilation that builder failed to install. Plumber should do a survey of location before installation to make sure gasoline vapors are not stored nearby, but summer attic ventilation is gray area until more general-public folks become aware of problem. Hotter summers temperatures will spread that information.
Hire local home center to install roof vents AND soffit vents.
Note: You also need soffit vents.
Remember a vent on the roof is like sucking air out of a coke bottle. The roof vent is no good unless air can also enter the attic from another vent located in the soffit.
Another solution is electric water heater for very hot locations.
Or install solar-assisted water heater.
http://www.hotwater.com/products/residential/cirrex_solar.html
Jul 28, 2011 | American Standard 40 G Natural Gas Water...
Water gets cold after 3 min.s
1) You have to give more information to get accurate answer about water heaters.
Is this a gas or electric water heater.
What type of heater: tankless or tank or hybrid or power vent or indirect boiler or instantaneous under-sink or RV heater?
What symptoms have you noticed prior to now? Less hot water than usual?
Have you installed new gas appliance that might affect gas water heater?
Did you paint floor with urethane and gas heater suddenly stopped working?
Is the circuit breaker tripped on electric heater?
With electric heater, did you open top panel and push in reset button?
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
How old is the water heater? What brand do you have and what does label show on side of tank?
Is the water heater also leaking, or is it in good condition?
Add a comment.
2) If you don't want to add a comment for further free help, then take advantage of fixya phone service. For a price, fixya expert will ask you same questions and more questions via phone, and then possibly help you resolve issue.
3) If you don't want do-it-yourself help from fixya, call a plumber and give plumber as much information as possible, and plumber will fix heater or install another one. The more knowledgeable and helpful, the more the plumber will try to help you.
4) Double-check any information you receive from fixya and from professional plumber by posting question on professional plumber's forum like the Tank: http://www.thetankatwaterheaterrescue.com/forums/forum3/
Jan 01, 2011 | General Electric Water Heaters
There is no hot water coming out how do I fix it
1) You have to give more information to get accurate answer.
What type of heater: tankless or tank or hybrid or power vent?
Have you installed new gas appliance that might affect gas water heater.
2) If you don't want to answer questions for further free help, then take advantage of fixya phone service. For a price, fixya expert will ask you same questions and more questions over the phone, and then possibly help you resolve the issue.
3) If you don't want do-it-yourself help from fixya, call a plumber and give him information listed in questions above, and plumber will fix heater or install another one. The more knowledgeable and helpful you are, the more the plumber will try to help you.
4) Double-check information you receive from fixya and from professional plumber by posting question on professional plumber's forum like the Tank: http://www.thetankatwaterheaterrescue.com/forums/forum3/
Jan 01, 2011 | Whirlpool Water Heaters
My plumber refers to the gas hot water heater that he wants to install as a "Standard" water heater. Do you think he means "American Standard"? Mac
i think since "tankless" water htrs entered the market...your plumber referring to a standard w/h means a storage tank wtr htr(stores 40 or more gals) ..most popular brands are a o smith rheem bradford white
Nov 28, 2010 | American Standard 40 G Natural Gas Water...
250sx quit working. Gas o.k. water flow good, throws ea code after 3 start attempts. 1. where is the ionization electrode, and is the fan supposed to come on before ignition? Fan comes on afterea code....
The gas pressure must be increased at the regulator from 9 inches of water column to about 12.5-13 inches of water column. The CO2 levels need to be adjusted for each installation. The air intake MUST come from outside the same wall as the exhaust. I have never seen any manufactures tankless unit installed properly. Plumbers do not read the manual.
Jan 24, 2010 | Bosch & Tankless LP Hot Water Heater
Rheem Pronto Hotwater Heater Error
Unplug unit from wall. Disconnect remote wires from circ board, and let unit set for about 5 minutes. plug back in. run water and see if unit comes on.
Jun 16, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Ihave a new water heater.Worked for 3 days.Now back to Ice baths
All new tank-type gas water heaters for the home are designed with Flammable Vapor Ignition Resistant systems. It sounds like the unit has shut down because of a venting problem. If it is a Rheem or Ruud (General Electric for Home Depot) you have to reploace the heater. Other brands alow for resetting this safety device. Don't take chances with gas if you are not absolutely sure of what you are doing - have a professional licensed plumber check out the problem.
Jun 04, 2009 | Water Heaters
Water Heaters Logo
83 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
