Question about Maytag PYE4558A Electric Dryer
Maytag dryer shut down. wont start.
Maytag dryer wont turn on. could it be the thermal fuse? it shut down mid cycle with the heat on. what are my options?
  • Shane Moore
    Shane Moore May 11, 2010
    if you turn the timer on, is the dryer dead but the heat element coming on? if so, does the element turn off when you turn the timer to the off position?
TheMobilian
  • 8220 Answers
SOURCE: dryer not going to cool down cycle, thermal fuse failed 2x
Most problems like this arise from air flow problems. You need to break down the dryer and clean out the lint. Including removal of the filter housing.making sure your outside vent is clear as well.If that fuse keeps blowing you especially need to remove and rinse out that filter housing.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 18, 2009
  • 532 Answers
SOURCE: Maytag Dryer quit working mid cycle
sounds like the timer,the only thermal fuse i know of is to protect from overheating which cools and resets itself
Posted on May 10, 2009
canbruce75
  • 1776 Answers
SOURCE: maytag dryer model #mde6657byw wont heat replaced
Check the switch mounted on the motor. Two of the terminals are for the heater element operation. Other causes could be a faulty heat selector switch or timer. These components can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity indicates a faulty switch. These are some items to consider. Hope this helped and best wishes.
Posted on Aug 31, 2009
SOURCE: dryer suddenly shut off mid cycle, had heat, just
check the belt around the drum
Posted on Feb 03, 2010
canwoodjc
  • 3301 Answers
SOURCE: Maytag electric dryer shuts off mid- cycle.
you have a weak or failing thermostat ,, you can check them by doing this Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermostat should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. be sure machine is unplugged before doing any electrical tests
Posted on Jul 06, 2011
GE spacemaker electric dryer PCKS443EBWW. Dryer shuts off mid cycle on timed dry setting. Wait till cool down and will start again. Venting is clear, I vacuumed inside and around motor. Any ideas?!
Mark, Could be limit /over heat/thermal fuse/switch, check or have checked by a good repair Tech., diagnosed and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What to Check when your Dryer Shuts Off Mid Cycle
Whirlpool Maytag Dryer Diagnostic Shuts off mid cycle not heating...
Kenmore Whirlpool Clothes Dryer Repair The Most Common Problem
GE electric dryer overheating shutting down
Jul 10, 2016 | GE Dryers
Maytag dryer stops after few minutes
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle.
Feb 21, 2015 | Maytag Dryers
I have been asked (Im an HVAC technician) to look at three commercial Maytag MDE16csayu elect. dryers that the apt. mang. says "dont work". Just looking for a place to start. I know to check the...
check the belt switch by the motor if it wont start,also the thermal fuse on the blower housing,if the motor turns the drum,but no heat,then the element,high limit thermostat on the element case can be suspect,or the heat cycling ther5mostat on the blower housing and again the thermal fuse located there also can be suspect
Mar 03, 2011 | Maytag MDE16CS Electric Dryer
Maytag Performa PYE2200AYW Dryer Heats intermittently
i had the same problem with my dryer and i installed the wrong thermal fuse for gas dryer which calls for a pink thermal fuse in which i installed and it works fine also check the lint in the front of your dryer. also my dryer which is the same make as yours seems will run on the fluff cycle until i replaced the right thermal fuse. my dryer run exceptionally hot and eventally shut down and it only run on the fluff cycle for any length of time.
Aug 03, 2009 | Maytag Dryers
The Dryer stopped and will not start again
Just had a similar problem with our Maytag Electric Dryer. The dryer shut off mid-cycle and wouldn't start again, but the timer kept running. We purchased a "Thermal fuse replacement kit" at a local appliance parts store for $38 and replaced the fuse ourselves. The dryer is running great! Here's a couple of website links that were helpful in figuring out out how to replace the fuse: http://www.partselect.com/repair.aspx?appliance=dryer&part=replace-thermal-fuse
http://www.davesrepair.com/DIYhelp/DIYthermalfuses.htm
Hope this helps!
Jul 09, 2009 | Maytag PYE2300AY Electric Dryer
Dryer just stopped working in mid cycle.
Verify there is still power at the wall and check the thermal fuse.
Eric
Jul 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
May 10, 2009 | Maytag PYE2300AY Electric Dryer
Dryer doesnt work but i hear the timer working
Change your cycling thermostat. When your cycling thermostat fails, then the reponsibility of your heating element to shut down goes to the high-limit thermal shut off (closest to heat element) and the thermal fuse. Your cycling thermostat should shut down heat element when it detects about 140* air in the blower housing. Yours can't detect that anymore so it lets your dryer heat up and up till you blow the thermal. new cycling thermostat and thermal
Jan 18, 2009 | Kenmore 60172 Electric Commercial Dryer
Dryer does not start - Thermal Fuse is ok.
Good to know, when the appliance does not start at all is always thermal fuse, wiring, door lock switch, or rarely the control assembly.
Have a nice day.
Jan 02, 2009 | Maytag PYE2300AY Electric Dryer
Maytag PYE4558A Electric Dryer Logo
57 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
