Question about LG WM1815CS Front Load Washer
Hall sesor on lg wm2487h*ma how do you replace this sesor?
3 Suggested Answers
greenspan
  • 1734 Answers
SOURCE: Need Service manual and parts manual for:
I am sure there is one to download but did not found anything with google...
If search engines are no help, just ask some deep web specialists, e.g. http://manualfox.com - this is a manual search agency and if they don´t find it, it does not exist in the Internet.
Posted on Aug 26, 2009
e-Guru
  • 3917 Answers
SOURCE: My lg WM2487H*MA leaks small
Hi
Remove the dispenser, pour water into the opening and make sure water can get into the machine freely. Inspect the opening for soap build up.
If water goes down slowly then open the washer door and check at the bottom for anything blocking the water inlet port into the washer (socks can sometimes cause a blockage).
If it all checks out ok, make sure the machine is properly leveled and not leaning forward.
Also check the link bellow for more details:-
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6283
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jan 26, 2011
Washing machine Lg 7kg WD 1256 problem LE sign direct drive the cylindre move difficult and stop
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall Effect sensor is used in these washers which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when there is an issue with the motor or when the Hall Effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sensor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Jul 10, 2011 | LG WM2487H Front Load Washer
"LG Tromm WM2277HW will not
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Mar 27, 2011 | LG WM-2277HW Front Load Washer
LE message and appears drum does not turn
LE error code in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Mar 14, 2011 | LG WM-2277HW Front Load Washer
LG washer WMO642HW shows on display window le and i lost my owners manual
Kevin
Mar 14, 2011 | LG Washing Machines
How do i fix the problem when the error code reads LE. in the manual it says to unplug the power and call for service.
Problem:
An occasional LE error but always a slow or no spin.
Solution:
A Red wire going to the Hall sensor was intermittent. You can test this from the main board connector down to the connector on the hall sensor by checking continuity. There is an intermediate connector down by the motor/hall sensor so you can isolate the problem even more. Problem was in the short wire harness that connects directly to the motor and hall sensor. Could not find the open point of the wire so added a new red wire and integrated it into the harness.
A service manual and more LG washer notes are HERE
Jan 15, 2011 | LG WM2487H Front Load Washer
Washer lg is having error LE
Hi, LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad.....
Dec 29, 2010 | Kitchen Ranges
My washer won't spin. Error shows up LE. what can I do.
Hello
Kevin
Nov 08, 2010 | LG WM-2277HW Front Load Washer
LG Wash WM2487H*MA- how to turn the tub clean feature on?
I have had this problem since I bought my washer. Some days the tub clean cycle will work....most days it won't. They have replaced the main board twice and it's still broken. I've had nothing but bad luck with LG appliances. Also bought a lemon fridge that took 4 repairman visits to fix. I will not buy another LG anything!!
Jan 17, 2010 | LG WM2487H Front Load Washer
Need Service manual and parts manual for: WM2487H*MA
http://www.lge.com/us/appliances/washers/LG-steam-washer-WM2487HRMA.jsp
Click on "Support" and you should be able to download the manual.
May 14, 2009 | LG WM2487H Front Load Washer
LG WM1815CS Front Load Washer Logo
16 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
