Question about Insignia Bluetooth Wireless Headphones with USB Bluetooth Adapter
Insignia Bluetooh Headphone won't turn on. but can charge
Started using the headphones with Iphone 3G after 3.0 update. Head phones stop wouldn't power up after I walked away from the headset with Iphone in my pocket. Took the following posts advice and the headphones powered up no problem.
"I followed Idarkstar's advice about plugging the headset in and pressing/holding both volume buttons for 15 seconds. After this, I tried to turn the headset on, and it worked perfectly again. Thanks Idarkstar! - dustinrs"
Put the charger in your headphones and hold both volume buttons
you should see a slight flash of blue light then press the multifunction to turn it on
Posted on Jun 20, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Insignia Master
  • 1,001 Answers
Bluetooth Headphones V3.0 Handsfree Stereo Wireless Headset with Microphone earbuds for Apple and Samsung LG Amazon com Charm sonic Bluetooth Headphones V3 0 Handsfree Stereo Wireless...
Posted on Jan 05, 2017
How to connect Motorola S10-HD Universal Bluetooth Stereo Headphones to Iphone 6 plus? Thanks!
turn bluetooth on ,on both units,search for devices with your phone when it finds head phones click on it and pair them
Apr 08, 2015 | Motorola Mobility S10-HD Stereo Bluetooth...
What is difference between iphone and iphone 3g
  • 3G speed capability
  • The iPhone 3G includes a built-in GPS.
  • The 3G is a bit thinner at the edges and includes a headphone jack that is flush to the side.
. The iPhone 3G differs from the iPhone in that it used 3G networking and included built-in GPS for expanded location based mobile services, and new iPhone 2.0 software
, which included support for hundreds of third-party applications that were built with the iPhone SDK
Jan 14, 2013 | Apple iPhone Smartphone
How do I install my sims card into my iphone 3g?
On the top of the phone there is a small hole next to the headphone jack. Find a paper clip and bend it so that the paperclip is straight. Then insert the paperclip into the hold next to the headphone jack and push lightly until the SIM card try slides out. Then insert your SIM cart into the tray and then put the tray back into the phone.
May 21, 2011 | Apple iPhone 3G Black Smartphone
Iphone 4: I connect to bluetooth headset; walk out of range; then walk back into range...how to have iphone automatically reconnect to bluetooth headset
Sorry to read about your problem, I hope this helps you out.
it will not do a auto connect, you will have to hit your headset button to talk, and then the unit will reconnect. their are some headsets, that will send out a auto connect..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | Apple iPhone 3G
My iphone 3G rings and makes calls out but I cannot hear the caller at the other end unless I use the speaker phone. This has only happened today, never before. Any ideas?
this problem happens when your phone headset socket is damaged, you can try inserting the headphone jack in the socket and pull out repetedly many times to fix this problem.
Dec 22, 2010 | Apple iPhone 3G
I dropped my phone now when people call they can't
  1. Verify there is nothing plugged into the headset port, including headsets, headphones, or adapters.
  2. While on the Home screen, adjust the volume buttons. If you see the icon below, indicating that headphones are attached, there may be debris in the headset port: ts1630_01.jpg
    To remove debris in the headset port, try connecting a pair of headphones to the headset port and then remove the headphones. Repeat this several times.
  3. If you have paired with a Bluetooth headset that is nearby, either use the headset or turn Bluetooth off (choose Settings > General > Bluetooth).
  4. If that doesn't work, try restarting the iPhone. Hold the Sleep/Wake button until "slide to power off" appears. Slide to power off your device. When it is off, press the Sleep/Wake button to turn it back on.
May 30, 2010 | Apple iPhone Smartphone
My iphone will not ring and i checked the orange dot
Some users who have recently updated/restored to the new iPhone firmware 3.0 have reported to have got into a problem where their phone randomly doesn’t ring when there is a call nor does the keyboard or slide to unlock button sound anymore. I got into this problem as well after unlocking and jailbreaking my iPhone 3G with firmware 3.0, my iPhone suddenly stopped ringing on calls randomly, resulting in missing a lot of important calls.
So if your iPhone isn’t ringing sound on calls, or if you are unable to hear the keyboard or slide to unlock click sounds, then try the following fixes before you panic and call Apple support:
Fix #1: Push feature is currently not working properly on jailbroken iPhone’s. If you have installed an application which supports Push Notification System then try disabling the Push feature as it may solve the problem.
Fix #2: Try Resetting the iPhone: Settings > General > Reset > Reset All Settings. This will reset your phone’s setting to factory defaults. Your contacts, calendars photos and any other data will stay intact.
Fix #3: There is a slight possibility that your iPhone’s headphone jack may have got some dust or rust which is causing the phone to think that the headphones are still plugged in when they actually aren’t. Try blowing out air in the headphone jack or try plugging the headphones in and out repeatedly. This trick may solve the no sound problem.
Fix #4: Restore/Update you iPhone back and start afresh: If the above solutions doesn’t help in solving your problem then you will have to start from scratch by first restoring your iPhone to the the original firmware
3.0 from iTunes, jailbreak it using redsn0w and then finally unlock(3G users only) it using ultrasn0w. This has fixed my problem.
Fix #5: Install Insomnia from Cydia: Install Insomnia as your last resort. When you press the power button on the top, iPhone goes into sleep mode after 30 seconds, in the process turning off your WiFi, sound and other stuff. When Insomnia app (available for free from Cydia) is enabled, applications will keep running and sound & WiFi will stay connected when the screen is off. This should fix your problem if all of the above solutions have failed to fix it.
Dec 30, 2009 | Apple iPhone Smartphone
What are the steps to update my iphone
Here is simple guide for those Users who will be first time upgrading their iPhone 2.2 or 2.2.1 to firmware 3.0. The guide is applicable for Upgrading iPhone 2G/3G 2.2 or 2.2.1 to OS 3.0 and also for iPod Touch. Please note in order to upgrade iPhone to firmware 3.0 you must have installed iTunes 8.2.
How to Upgrade iPhone 3G 2.2/2.1 to 3.0 firmware 1. Connect your iPhone 3G to computer
2. Open iTunes 8.2
3. Select your iPhone under Devices in the Source List on the left.
4. In the iPhone Summary pane, click Check for Update.
5. Click Download and Install. Do not disconnect your iPhone until the update has finished
That’s it, Once update is finished your will have iPhone 3G running latest firmware 3.0.
Please rate this solution
RNJ VINODKUMAR
Oct 02, 2009 | Apple iPhone Smartphone
Iphone 3gS OS 3.0
u take to apple store
Jul 27, 2009 | Roadmaster (VR500CSBT)
I have an I phone and use the Z9i headset. I am
I reloaded the latest software update on the Headset 3 times (each time it said it had been updated and reloaded) finally the last reload did fix the problem. Unknown to me why this worked this way.
Jul 17, 2009 | Blueant Z9i Bluetooth Headset
Insignia Bluetooth Wireless Headphones with USB Bluetooth Adapter Logo
682 people viewed this question
Top Insignia Radio Communications Experts
Skyken
Level 1 Expert
woodzowl307
Are you an Insignia Radio Communication Expert? Answer questions, earn points and help others
