Question about SanDisk Sansa c240 MP3 Player
How do i sync my sansa c240
Tried to sync to windows media said it synced but it didn't
ThaMp3Doctor
  • 8596 Answers
SOURCE: Sansa C240 syncing problems
The songs are in the wrong format - read my 2-part article on song formats under my profile for more detailed info
short answer: convert the songs to Mp3 format, and you will have no problems
Posted on Jun 23, 2008
  • 758 Answers
SOURCE: Windows Media player will not "Connect a Device"
To obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer.What i would recommend you to do is to uninstall the device andreinstall it back...to uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardwarethen device manager...look for the sansa device..it usually locatedunder portable device..if its not showing there i would recommend youto look for under disk drivesand see if its there..right click on the device and click onuninstall...after you unintall it unplug your device from thecomputer....Then follow this link below to downloadthe portingkit...http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en.Then check the mode of yuor device to make sure it sunder MTP notmsc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows mediaplayer click on tools, options and click under privacy...clear thehistory and caches...after you finish you can plug the device on theback of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media playerto 11 even though you have done that already..and try to reconnect yourdevice..make sure you have it connected on the back USB>>>
And if that doesnt work try to obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Computerrep
Posted on Jan 26, 2009
ThaMp3Doctor
  • 8596 Answers
Make sure the hold/lock is not engaged.
Try a different USB port.
If that fails:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Mar 23, 2009
Ace12312
  • 30 Answers
SOURCE: I have a SANSA C250 MP3 player. Trying to sync w/ iTunes.
Put on your ipod and put them on your media player by sync. Itunes can work on the ipod so you use itunes on your ipod and get them.
Posted on Apr 06, 2009
  • 54 Answers
SOURCE: Sansa 250 MP3 won't sync songs from my windows media player.
What you need to do is to format the device and try to transfer the songs..there could be an error with the device certificate...
Let me know if you need additional help
Posted on Apr 24, 2009
How to I start the c240 up it My computer doesnt
On Windows XP, when you open My Computer, the Sansa C240 shows up at the bottom, under "Other". Because of DRM restrictions, you cannot copy media files to the C240 using Windows Explorer. You have to use Windows Media Player to sync playlists to the C240 (WinAmp can do it also).
I also suggest that you check out RockBox. It's an alternative operating system for portable media players and they have a version for the Sansa C240. It will give you some additional functionality.
As far as I can tell, to copy files to the microSD card (if you're using one) you have to use a media card reader, then insert the card into the C240.
Mar 17, 2009 | SanDisk Sansa c240 MP3 Player
Tip
Why did my Mp3 Player Add/Delete a File I Didn't Want? Manual vs. Automatic...
Why did my Mp3 Player Add/Delete a File I Didn't Want? Manual vs. Automatic Synchronization in Windows Media Player
by Tha Mp3 Doctor
The difference between manual and automatic synchronization is very important. If you’re ever wondering why you computer added files to your device when you didn’t want it to, or why it deleted files unexpectedly, then there is a good chance that you have automatic synchronization activated. Manual synchronization allows you to only add/delete only those files that you want to keep or discard.
To disable auto-sync in Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/howto/sync_how_to.aspx
To disable auto-sync in Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Run the mouse cursor over the Sync tab – a little black arrow should appear under the word “Sync”
4. Click on the little arrow and a drop-down menu should appear
5. Select “Set Up Sync” in the drop-down menu
6. Uncheck the box that says “Sync this device automatically”
Microsoft’s Directions:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/howto/mp11/sync.aspx
There are many good outside websites out there – many with videos on how to do everything we have described in these pages. Hopefully, this will give many of you a start into the wonderful world of music transfer through mp3 players and Windows Media Player.
on Jun 23, 2008 | SanDisk Sansa c240 MP3 Player
My mp3 says that i don't have anymore space, but it only shows 10
I'm not sure what you are asking, but maybe my experience can help you. I was using Windows 2000 (it has no DRM) and the Sansa C240 was displayed in Windows Explorer like a removable drive. I could copy and delete files in Windows Explorer. I switched to Windows XP and when I connected the C240, no files were displayed for it in Windows Explorer. I realized that XP had DRM and all the media files had to be transfered with Windows Media Player. When I opened WMP, it recognized the C240, but it didn't list any of the mp3 files I had already loaded on the C240. WMP asked if I wanted to delete all the media currently on the C240, but I clicked No. After that, WMP worked like the old files didn't exist. It would only delete files that had been copied to the C240 when it was synced.
I would recommend that you use Windows Media Player (or WinAmp) to delete all old media files on the C240 and use the sync button to copy and delete files from the C240. See Windows Media Player help for details.
Mar 15, 2009 | SanDisk Sansa c240 MP3 Player
Cannot see music files on my comp
try connecting it to another computer to sort out the problem is between your computer and player
Feb 08, 2009 | SanDisk Sansa c240 MP3 Player
Can't delete songs
In your windows media you will see the device name listed..you have to make sure the device is under MTP mode..then click on the player and you will see all the songs...you can just right click on the songs and delete them..if you dont want the device to sync automatically you can click on sync and then click on the device name and click on sync setting..there you can modify if you want it to sync automatically..
Should you have any questions..let me know..
P.S.Please rate accordingly...
Thank You
Computerrep
Jul 19, 2008 | SanDisk Sansa c240 MP3 Player
Jun 19, 2008 | SanDisk Sansa c240 MP3 Player
Sansa
My Directions:
May 15, 2008 | SanDisk Sansa c240 MP3 Player
How can i connect my mp3 player to the computer?
did u try the sync option on mediaplayer my wifes sandisk likes to use mediaplayer if not make sure u have the drivers for it
May 07, 2008 | SanDisk Sansa c240 MP3 Player
Can not view my music files on my laptop (but can on my desktop)
Get the latest firmware upgrade - this player wasn't originally designed with WMP 11 in mind. Also, make sure the laptop has the folders "My Documents" and "My Music" on it - this is primarily where WMP reads from.
Dec 06, 2007 | SanDisk Sansa c240 MP3 Player
Sansa c240 and memory card
When you look at the media player (i assume you're using Windows Media?) you should see a pane on the right side. In blue font near the top it should say "Next Device." Click that and it should bring up the SD card to sync to it...Also, you could get an SD reader and do it that way...
Oct 29, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa c240 MP3 Player Logo
27 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
