Question about Garden
Mastercraft model 55-682-6 guard return spring
5 Suggested Answers
  • 12 Answers
SOURCE: Mastercraft 10" compound mitre saw model #
Mastercraft's toll free help line is 1-800-689-9928. They will need your product code and are very helpful at getting you replacement parts.
Posted on Aug 31, 2010
  • 30 Answers
SOURCE: Where does the guard return
Hi the small spring goes back inside the guard . It is hard to explain how to do this and quite fidley, i had a similar problem with a dewalt saw when the spring flew out. I have included a Parts Breakdown diagram so you can see where the spring goes (item number 53)ckjoiner.jpg. Hope this helps and you get it fixed.
Posted on Jan 14, 2011
heatman101
  • 43501 Answers
SOURCE: I have a Makita Slide
Click here for an exploded view of your saw...
I think part 79 is the part you are referring too...
It does not look like it will be too hard to get it placed and everything back together...
heatman101
Posted on Sep 07, 2011
B & D #3051 worm drive saw: How do I access the return spring for blade guard?
Link,
Usually you will have to remove the blade guard to get access to that. There is usually a rubber stop with a screw going through it that you will have to remove, and a spiral spring clip on the inside of the hub of the blade guard that will also have to be removed and then you should be able to lift the blade guard off the saw. The spring will hook around the blade guard and the other end will hook to the saw housing. Hope this helps!
Apr 22, 2015 | Saws
How do I replace the blade guard on a Dewalt DC390K saw
Remove the clip behind the back blade flange holding it on to the housing and lift it up of the return spring, replace the opposite way remembering to relocate the return spring. Make sure you get the model number correct as the 390 and 390k are different.
Dec 31, 2012 | Heavy Duty DeWalt 18V 6 12" Circular Saw...
Install spring on 345 guard
As you are looking at the blade side of the saw, the spring hooks through a hole at about three o'clock on the lower guard. It then wraps around the bottom of the guard clockwise and attaches to the upper guard. The hole on the upperguard should be somewhere around ten to twelve o'clock. Move the lower guard to check for binding and full return to the safe position.
Feb 21, 2012 | Saws
Mastercraft 10" compound mitre saw model # 55-6895A , broken plastic safety guard , can it be replaced serial #W034453
Aug 20, 2010 | Saws
Repair spring to lower guard to spring back on dewalt 18v dc390 saw
You may be able to salvage the torsion spring that is there. Sometimes the end will break off and you can bend yourself a new end and just stick it back into the retaining hole in the housing or guard. There may be damage to the guard which will not allow you to just bend the spring to make a new joint. Either way, you need to know what you are dealing with. First remove the blade if you haven't done so already. Then remove the bumper (rubber piece) that stops the guard from returning too far. Next you will need a pick or a small flat head screwdriver. Look around the hub and you will notice a retaining ring. You will have to use the pick or screwdriver to get the ring started. Look for a little tab around the perimeter of the hub. You will have to work that tab out and make sure you keep your pick or screwdriver under it. Then work it around and off the hub. Then you can remove the guard from the hub. The spring is located under the guard and is a torsion spring. Look for damage to the guard and the housing as well as the spring. If there is any question to the integrity of the guard you should replace it. The part number for the torsion spring is 612517-00 ($1.50), the retaining ring is 150383-00 ($1.50) just in case you break it, and the guard number is 611925-00 ($6). If you have any questions please post back.
Oct 28, 2009 | Dewalt DC390K 18v Cordless Circular Saw...
I am missing the part that brings the guard back when you lower the saw blade
I am assuming that you have some type circular saw?
Most popular saws use a spring to return the guard,with the saw unplugged raise the guard and see if the spring is there(you may need to take off the blade) if it is not there,replace with proper spring.one end of the spring will hook onto the fixed 1/2 of the guard the other to the front of the moving guard(consult manual if possible).once this is done insure that the guard mover freely and is not in the way of the blade.Replace the blade in proper direction check guard again for proper travel,make sure everything has been re-tightened .
If the spring is there check for material build-up or debris that is causing
guard not to move,remove blade clean debris or obstruction,replace blade and check for proper operation.Also visually inspect where the moving guard is attached to the saw for any unusual marks or wear this could be a sign that some type of unsafe situation exists,if this happens refer to a pro to fix or buy new never use a saw without a properly working guard,it took 141 stitches to repair my friends leg.
Sep 28, 2009 | Hand Tools
Guard not raising
hello. perhaps this info will assist u.
Locate Nearest Service Center online at makita.com
or Free technical support center (1-800-4MAKITA)
May 27, 2009 | Makita 10" Miter Saw LS1030N
I have a mastercraft mitre saw. The blade blocks midway when I am
The picture I could get only shows one side. From my experience, these guards operate using leverage, where a little motion results in a lot of movement to the guard. That means a little damage or wear in the linkage can make a big difference. A bushing may have shattered, or a pivot hole may be worn out. Reviews of this machine mention dust not going into the bag. Make sure dust is not jamming the guard works. Take care, having to move a guard while the blade is spinning is scary.
Mar 28, 2009 | Dewalt Mitre Saw Workstation
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
