Question about ION Audio iED01 Electronic Drum Set
Ion idm05 manual assembly
Where are the spark plugs located on my 2003 Saturn Ion
Hi Carol,here's a link on how to replace your spark plugs.
Mar 22, 2013 | 2003 Saturn ION
Manual
Hi Noah,
Here's the manuals download in pdf.
Also you can click here for a video tutorial on the assembly of the Drum Set.
Hope this helps.Thanks!
Please rate this answer.
Nov 21, 2011 | ION Audio iED01 Electronic Drum Set
I have a saturn ion,2003 my drivers side windshieldwiper stopped working. i was told i have to replace the whole wiper assembly.is that right?
I also have a 2003 Saturn ion and currently I am waiting for the wiper transmission assembly its shipping to my house it takes maybe 1.5 hrs to replace my driver side wiper started flopping all around and then stopped come to find out the transmission was broke because it is plastic 70 bucks on Ebay!
Feb 17, 2011 | 2003 Saturn ION
How do you change a brake or 'taillamp' bulb on a 2006 Saturn Ion? The manual is not clear on how to do it. Much appreciated!
Pop your trunk, and you'll see two Torx screws on the side of the tail light assembly. Use your T-15 screwdriver on these.
The tail light assembly should easily slide out at this point. You'll see four connectors: a wiring harness, reverse light, turn signal, and brake light. Disconnect the proper connector, and you'll see the burned-out bulb. Give it a yank, and it will pop right out.
Jul 14, 2010 | 2006 Saturn ION
What is the bolt size on the bearing assembly of an 06 saturn Ion?
If you are refering to the axel shaft retaining bolt, it runs between 1 3/16ths- 1 5/16ths. Metric is 27mm-29mm. Bring a few sockets to be certain.
Oct 06, 2009 | 2003 Saturn ION
How do you get to the front turnsignal bulb to replace on a 2004 Saturn Ion?
Open the hood and look behind the headlamp assembly and you should see some clips / pins. Pull up on the retaining pins and the headlamp should slide forward and out of the way. You will then see the electrical connector, disconnect it. Look at where the signal assembly is and you should see the socket for the bulb, just twist counter clockwise and it will pop out for you to change
Sep 16, 2009 | 2004 Saturn ION
Cannot find the resorvoir for the power steering fluid
Many of these have a Electronic Power Steering Assembly. No fluid is required. If you are having a problem with it you have to take it in to your service center, there is nothing you can service at home.
Jan 25, 2009 | 2003 Saturn ION
ION Audio iED01 Electronic Drum Set Logo
326 people viewed this question
Top ION Audio Toys Experts
Andrew Taylor
Andrew Taylor
Are you an ION Audio Toy Expert? Answer questions, earn points and help others
