Question about General Garden
General 6670gp pressure washer no high pressure
How do I connect detergent tank to pump? This is a g3000 washer
G3000 is not much help. I have a car with an engine, can you help me get parts for it?
In general it is not a good idea to run solvents and cleaners through the pump. It tends to destroy the pressure seals ( people are often creative in what they use as cleaners) To protect the pump there is usually a siphon fitting on the high pressure side of the pump. There is usually a hose that you stick into your detergent. You then put in a large capacity cleaning nozzle and the detergent is sucked up the hose and out the low pressure cleaning nozzle. When you put on the high pressure spray nozzle the siphon valve seals and it does not draw detergent through the hose.
Oct 08, 2014 | Karcher Garden
What oil to use
Your manual will say to use General pump oil GP100..or whatever DeWalt's number for that may be. See dewalt.com for their proper part number. From the pictures of that model I see on line, that is a General Pump and they have recommended Non-detergent 30w standard motor oil in the past. We like to use a non-foaming full synthetic 20-50w racing oil on these high RPM pumps.
Oct 20, 2012 | Dewalt DXPW4240 4200 PSI Direct Drive...
Problems with general ts1021
remove head and replace packings also inspect o'rings around brass and plungers for damage
Oct 12, 2012 | General TS1021 - Pressure Washer Pump-Bare
I have a PW1600 Power washer. the High pressure hose connector is cracked. Can that be replaced? AND if so how do you remove it from the gun and hosing.
I don't know what brand it is, but in general the hoses can be replaced. There are fittings and hoses available. the fitting for most PW's are interchangeable. try looking at stuff here. (they do not necessarily have the best prices or stuff they just have good pictures) http://www.northerntool.com/shop/tools/category_pressure-washers+pressure-washer-accessories
Jul 05, 2011 | Black & Decker Garden
Our GE washer model #: WCVH6800J1WW is overfilling and it won't wash anything we have already replaced the pressure switch and the control pannel and still nothing. Please help.
When you replaced the pressure switch, did you fully test the pressure switch hose?
Here's a similar posting that explains a potential issue and how to troubleshoot:
http://www.fixya.com/support/t8933273-general_electirc_washer_model
I highly recommend doing a diagnostic test because it's free and easy. Most of the time, the washer will self-diagnose. Check out that posting for instructions on how to do the tests.
Feb 26, 2011 | General Electric WCVH6800J Front Load...
The nossle that connects the hose to the unit keeps flying off. Where can I buy a NON PLASTIC part that will hold?
It is easy to NOT get the connector attached properly. The O ring and the end MUST go into the connector a reasonable distance so that the retaining ring will have MANY threads engaged.
The hoses are NOT servicable in general and usually have to be replaced as the pressure is so high that liability of supplying DIY connectors precludes offering them.
Oct 13, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Power washer problem - water is spraying into my soap dispenser
this can happen if you use the wrong soap, you must use pressure washer cleaner, it does not foam.
Aug 08, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Honda p/washer won't **** up cleaning chemicals cleaned filter,still no go.
In general, pressure washers will draw detergent from the reservoir only when the spray nozzle is set to low pressure. At high pressure a non-return valve closes to prevent water flowing back in to the reservoir. If you've got the spray nozzle set to low pressure and still have the problem, it may be that the spray nozzle is partially blocked - you can try clearing it with a length of wire.  Failing that, the non-return valve is probably stuck (and that may need professional attention).
Apr 17, 2009 | Honda Garden
Garden Logo
Top General Garden Experts
dennys23601
Brett Duxbury
Brett Duxbury
Are you a General Garden Expert? Answer questions, earn points and help others
