Question about Car Audio & Video
Eurovox wiring diagram
Hi, l am removing a eurovox cd/tuner from my 2002 holden rodeo and installing a new kenwood system.l just need to know the color coding fo the old harness so l can match it to the new one.l have the battery,accessories and earth worked out,it's only the speakers l need to know.Colors on the old harness is as follows,blue,blue/black yellow,yellow/black green,green/black white,white/black.Any help would be much appreciated.Cheers,Dougy.
  • 3 Answers
The black stripes are typically the negative wires for each speaker. So your blue will go to one positive speaker output from the receiver, and the blue/black to the speakers negative.
If you want to check them manually, so that you know which speaker should connect to which wire, use the front to back fader, and left to right fader on the kenwood.
Remove the keys from the ignition, and ensure the radio is off.
Tape up all eight speaker wires coming out of the headunit with electrical tape to nothing at all.
Remove the tape from one pair of corresponding colors, and connect it to any single pair of wires that run to the speakers. Tape them separately with electrical tape.
Turn it back on, and set the fader all the way to the front and left. Listen to what speaker it's coming out of. You now know two things. Which color from the deck is the front left, and which speaker wires in the dash goto the speaker making sound.
Turn everything off, and rinse and repeat.
Even easier is to go to a sound shop where they sell harness, or buy one online. Then you just connect per the instructions and you're done. Don't forget to make good strong connections, and tape up everything well.
Good luck.
Posted on Apr 22, 2014
ZJLimited
  • 17970 Answers
SOURCE: I need the color code
This is the wiring list about 2000 Isuzu Rodeo...
ITEM / WIRE COLOR |POL| / WIRE LOCATION
12V / white, white/black |+ | / ignition harness
STARTER / black/white |+ | / ignition harness
IGNITION / black/yellow |+ | / ignition harness
SECOND IGNITION / black/red |+ | / ignition harness
ACCESSORY / blue |+ | ignition harness
POWER LOCK / lt. green/red |- | / DKP white 22 pin connector
POWER UNLOCK / red/blue |- | / DKP white 22 pin connector
LOCK MOTOR / blue/red | | / drivers door harness
UNLOCK MOTOR / blue/white | | / drivers kick panel *1
DISARM DEFEAT / blue | | / passenger kick panel *2
PARKING LIGHTS / |+| green/red | | / drivers kick in a black plug
PARKING LIGHTS / |-|yellow or grn/yel | | / steering column
HEADLIGHTS / red or red/blue |- | / steering column
DOOR TRIGGER / red/green |- | / drivers kick in a white plug
DOME SUPERVISION use door trigger
TRUNK/HATCH PIN / tied in with door
HOOD PIN / green/red |- | / keyless module *3
TRNK/HTCH RELEASE / lt. green | | / keyless module *3
FCTRY ALARM ARM / purple *5 |- | / drivers kick in a white plug
FCTRY ALRM DISARM / yellow/blue *5 |- | / drivers kick in a white plug
DISARM NO UNLOCK / | |
TACHOMETER / black/red | | / dkp, blk 22 pin plug, pin 4
SPEED SENSE / blue/black | | / dkp, blk 22 pin plug, pin 2
BRAKE WIRE / red |+ | / brake switch
HORN TRIGGER / green |- | / steering column
WIPERS / blu/yel & blu/wht |+ | / steering column
LF WINDOW UP/DN / brn/wht - brn/red |A | / drivers window switch
RF WINDOW UP/DN / brn/wht - brn/red |A | / RF window switch
LR WINDOW UP/DN / brn/wht - brn/red |A | / LR window switch
RR WINDOW UP/DN / brn/wht - brn/red |A | / RR window switch
SUN RF OPN/CLOSE / purple - blue |A | / sunroof motor *4
SUN ROOF LIMIT / | | /
RADIO 12V / red/white |+ | / radio
RADIO GROUND / black |- | / radio
RADIO SWITCH / red/yellow |+ | / radio
RADIO ILLUMINATE / green/red |+ | / radio
LF SPEAKER / blue - yellow | | radio or speaker
RF SPEAKER / green - gray | | / radio or speaker
LR SPEAKER / orange - white | | / radio or speaker
RR SPEAKER / orn/blu - orn/wht | | / radio or speaker
Notes:
*1 In a white 10 pin connector
*2 Located up high in a white connector
*3 The keyless module is located to the right of the glove box.
*4 The sunroof motor is located in front of the sunroof in the headliner.
*5 Trigger the power lock and the factory alarm arm wires at the same time to arm the alarm. Trigger the power unlock and the factory alarm disarm wires at the same time to disarm the alarm.
Also, can check HERE
Hope helps.
Posted on Sep 06, 2010
vetteman3002
  • 2299 Answers
SOURCE: I have a 2002 ford
This is the factory stereo colors
Radio Constant 12V+ Wire: Orange/Black (Thick Wire)
Radio Switched 12V+ Wire: Yellow/Green
Radio Ground Wire: Black/Yellow and Black/Green
Radio Illumination Wire: Orange/Black (Thin Wire)
Left Front Speaker Wire (+): White/Black
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Gray/Red
Left Rear Speaker Wire (+): White/Purple
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): White
Right Rear Speaker Wire (-): Gray
Posted on Nov 15, 2010
  • 47 Answers
SOURCE: having trouble wiring in my
Car Radio Battery Constant 12v+ Wire: Orange/Black
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: White/Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Brown/Yellow
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Brown/Yellow
Car Audio Rear Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Door
Left Rear Speaker Positive Wire (+): White/Purple
Left Rear Speaker Negative Wire (-): Brown/White
Right Rear Speaker Positive Wire (+): White/Purple
Right Rear Speaker Negative Wire (-): Brown/White
Posted on Jun 06, 2011
  • 250 Answers
SOURCE: Replacing the Eurovox cd player/radio
Do you have a wiring diagram for the Pioneer Unit, or is this the one you want the diagram for ? Get back to me with a bit more details, e.g. have you got a diagram for the Eurovox? Have you pulled out the Eurovox yet? (I hope not ).
Posted on Jul 08, 2011
  • 3 Answers
SOURCE: Kenwood kdc-248u. Installing into a
From the installation instructions: Ant Cont - Motor antenna control wire (Not used) P. Cont - Power control wire - To the power control terminal when using the optional power amplifier or to the antenna control terminal in the vehicle. Mute - Mute control wire - To the terminal that is grounded when either the telephone rings or during conversation (this would be to the telephone that is purchased separately.
Posted on Jul 27, 2011
My battery went flat and I jump started my car (Holden VT) now my stereo is locked. Dose anybody know how to unlock it. It's a eurovox radio unit.
Samantha, You need the VIN and the radio serial number. Take those into a Holden dealer to get the radio code and programming instructions from the dealer. They may want a small fee for the #. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forums.justcommodores.com.au/vt-vx-holden-commodore-1997-2002/131983-vt-stock-radio-cassette-player-security-code.html
Radio Security code Street Commodores Online Forum
Go Technologies Eurovox FAQs
Aug 26, 2016 | Holden Cars & Trucks
Hi - looking to fit a Mongoose MAP80 upgrade alarm to a 2011 Colorado dual cab - does anyone have wiring diagram or info for door trigger, arming/lock wire & disarming/unlock wire Thanks
Peter, This is what I found on google search, you can also try google search Mongoose MAP80 upgrade alarm wiring instruction as there is a lot more info. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.mongoose.com.au/vehicle-installation-manuals/MAP80inst.pdf
http://www.mongoose.com.au/vehicle-wiring-holden/colorado_2009_2010.pdf
Aug 04, 2016 | 2005 Holden Rodeo
Brown mute wire for new ken wood in 2002 rodeo, does it go with illumination wire, green/red or red/green?
Hi, i'll need a bit more info to be able to give you an opinion , am i correct in assuming the "new kenwood " is a radio/cd player ? If so do you have a car phone or a hands free kit for your mobile/cell phone ? Assuming the kenwood is a radio the mute wire has to be connected to the car phone/mobile hands free kit , this is usually described in the phone installation directions , how the mute system works is when you recieve a call the signal is sent via the phone system to the radio , which is where the mute wire comes into use .If you have either of the phone set ups i've described post back with there details , make , model etc ,if you do not have this type of system and are using an ear piece then the mute funtion can't be used , i hope this is of some help to you
Apr 06, 2015 | 2002 Isuzu Rodeo
How do I replace front disc pads on a 4x4 drive Holden Rodeo 2002 model
Buy a manual and read it. The manual will have diagrams and tell you the proceedure for repairing the braking system.
Oct 09, 2014 | Holden Rodeo Cars & Trucks
Wiring diagram for eurovox 92056 088
We have no wiring diagrams here at fixya. Sorry
Jul 08, 2012 | Cars & Trucks
Replacing the Eurovox cd player/radio in my VU Holden ute with a Pioneer head unit. Is there a wiring diagram available to match up the wires
Jul 08, 2011 | Car Audio & Video
Stereo wiring diagram for 91 rodeo
i you need is the wiring harnest from walmart, wire up the same colors on back of the head unit to the new harnest, then slap the new harnest to the factory harnest DONT CUT THE FACTORY HARNEST, WILL CAUSE YOU A BIG HEAD ACHE but crutchfield gives out free step by step diagrams
May 01, 2010 | Car Audio & Video
I need a wiring diagram to connect up my kenwood amp, cd player, tuner and graphic equaliser
cd player(tape out)-------equalizer in------equalizer out-----amp line in.
tuner out-----to another line in in amp.
Nov 27, 2009 | Audio Players & Recorders
Need a wiring diagram for the audio system in a 2002 Holden tf Rodeo???
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Red/Yellow
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Car Audio Front Speakers Size: 5 1/4′
Left Front Speaker Positive Wire (+): Blue
Left Front Speaker Negative Wire (-): Yellow
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Gray
Car Audio Rear Speakers Size: 4′
Car Audio Rear Speakers Location: Roof Mount
Left Rear Speaker Positive Wire (+): Orange
Left Rear Speaker Negative Wire (-): White
Right Rear Speaker Positive Wire (+): Orange/Blue
Right Rear Speaker Negative Wire (-): Orange/White
should be the one
Oct 21, 2009 | 2002 Isuzu Rodeo
Eurovox radio/cd stacker in 1998 Holden Astra locked
Radio lock out codes are security related to discourage theft, so they are not published on the internet, if they were what would be the point?? any thief could get the code after stealing your radio. Contact the dealer for instructions and what info u need to get your cars unique radio code. How do I know this isn’t a stolen radio? The dealer will require the serial number off the radio and proof of ownership of the car it came from.
Sep 16, 2009 | Car Audio & Video
Car Audio & Video Logo
287 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
