Question about PLOOM Pax Vaporizer
Temp control not working - PLOOM Pax Vaporizer
I have a 2003 chevy 3500 dump, and the heat will only work on the passenger side it has duel climate control and if I lower and then higher the temp it will work for like 5 seconds any thoughts oh the...
Drivers side temp door actuator inop. defaults to cool temp. Possible control not sending correct information to the drivers side temp actuator.
Nov 12, 2013 | Cars & Trucks
1994 pontiac boneville blower fan motor dont work on high
Automatic or manual heater control. Automatic is the one where you set the temp to a certain degree and it maintains that temp. Manual has the temp control on a dial or levers.
Apr 05, 2013 | 2001 Pontiac Bonneville
Bosch oven temp control
If the temp control works for all other settings, it is working for hot air grilling as it using the same stat....when hot air grilling function is used the grill comes on and when it reaches temp the element switches off and the fan switches on. Once this has happened the element and fan will alternate during the cooking period. The fan and element DO NOT operate at the same time.
Mar 23, 2013 | Bosch Ovens
How do I test the temperature control module for a kenmore freezer model 253.9284013
You need a multi-meter to do this. The temp.control is just a switch that closes on temperature rise and opens on temperaure fall (or when it reaches the desired temperature). Using a meter set on ohms coneect to the 2 prong ends of the temp. control. Set the temp. control on off. You should not have any ohms because hte temp. control is open (no continunity) now set the temp control to 2 or 3 and it should close (the meter will read ohms or continunity)
if it does then the t'stat works. The only other exception is the temp. control will sometimes (this is rare) not properly sense temp. for example, it fails to sense zero degrees and it will either stay on too long to shut off too soon. I only seen this happen like twice in 20 years. but more or less this is how you do it!!!
hope this was helpful
Mar 14, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Temp control on 99 dodge intrepid not working
try a new compressor or take it into the dealer
Jul 27, 2009 | 1999 Dodge Intrepid
Temperature control of refrigerator/freezer not working
Let me know if the compresor and the condensing fan motor works beacause most of the times the problen is not in the temp control.But if you whant tomake sure that the temp control works or not you can pull the two wires out from the temp control and put a jumper wire between them and if starts cooling you just need to replace it
Apr 21, 2009 | Refrigerators
Freezer Temp Alarm
Temp alarm come on, yet temp (fan blowing and cold air) working. Turn the temp control just a notch up and immediately the temp lite goes out. Later it will start up again. It seems the freezer is working fine, just the temp moritoring system is malfuncting.
Sep 06, 2008 | Freezers
Temperature Control Problem
is washer less than a year old? if so call reapir ..there was an issue with the temp controls on a small number of those machines they use an electronic control in what looks like a mechanical switch..if over a yr old could still be a temp switch but be sure hoses are connected correctly and on a rinse cycle the water does come in hot ..don't worry too much about wash cycles temp is controlled to to prset temps and is based on final water temp in tub after fill not incoming water temp
Aug 06, 2008 | Whirlpool WTW5500S
PLOOM Pax Vaporizer Logo
Top PLOOM Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a PLOOM Health and Beauty Expert? Answer questions, earn points and help others
